Can you give me the cad files and the exact materiel used please? give me all the details I need, size, materiel color etc. i have never printed 3D before, so trying to get an estimate locally and then I can get a quote to make them..
its the am yet? yes it is, 2am. time for more!...waiting....
Good fabrication skills man. I like the finished product.
Life is like a car wash and I'm on a bicycle.
a small contribution, I think that adding a side sheet or groove would be the best thing to do, that way it will eat / sit over covering the existing "rib" and add some more stability to the overall design. Forget about the 3rd sketchup design, it does look more aggressive idea however doesn't feel right with the e36 M3 shape and curves .
Something like the carbon fiber looking one(3rd in the pictures) that has a grove to sit over the existing diffuser rib, would be the best and look most OEM.
Would this work for the rep m3 diffusers that are made for non m3 cars? If so then I'll buy some from you...like now
Ok guys, I'll finally update (Wikerman I'll pm you later).
First let me mention the problems:
1. Surface finish isn't great. The heat plate the parts sit on makes that face pretty rough. Supposedly, acetone will lightly melt the surface and smooth it out (will test after Thursday).
2. Profile isn't perfect to the diffuser.
-I put too much angle on the bottom (opens up too much on the horizontal surface), will adjust with some washers and see how it improves)
3. One of the three parts is warped, not sure why (the guy said he could make a new one if needed). It's the far left in the bottom pictures.
4. I designed the parts for M6 hardware...but I need to change it to 1/4". The hardware store locally only has english in this aspect ratio.
Now onto pics. I'll even include bad pics that show the problems above My goal is to see about fixing the profile issue and possibly the surface finish issue for the next set of parts.
This is the top 'good' side.
Here you can see the 'bad' side on top.
Here you can see the missmatched profile. This is because the horizontal surface on the bottom where the bolts are is at the wrong angle, pulling this profile away from the diffuser.
i already saw those pictures earlier
I have a solution, you need to scrap this design which "sits" and touches the ribs and you need to use your 3rd design, this one below.
See how it eats up your ribs, which the current design only touches? thats what you want and essentially your diffuser becomes one with your ribs and bumper. And unlike the old design, not only this new one will pass the 5 feet test but the 1 foot one as well as look more nice and oem/professional that way as well. So use that design after you get the measurements and fitting right, make the ends a bit longer and have a groove cut in the middle.
I edited this in paint to clearly show what I mean. Observe this picture for better understanding. The Blue portion is estimated where the grove will be cut to sit over the ribs. notice my points in white writing and the small illustration in the box. See the Blues are your Diffusers, and the Black are the M3 Bumper ribs. See how the ribs go inside the diffuser. thats whats needed.
Also maybe ditch the 3m tape and get some black silicone that they use to attach your windshield glass and stuff like that, just a small portion on the diffuser will create a rubber like attachment to the bumper and ribs and reduce any vibration as well as being easily removable if needed.
Now let me address some of the other issues.
Maybe a different materiel or printer but to be honest it could be sanded down smooth with a belt sander and painted or just sanded up to 1500 - 2000 grit and it should be enough. My rear diffuser looks faded anyway so I wouldn't mind having it painted along with these.
I think you are really close perhaps 3 more prototypes at best to perfection, next time only have 1 printed at a time, that way you can test its fitment profile and if you dont like it you can adjust and reprint another one. that way you save on time/costs/wasted resources and save the planet and the bees and bs like that. once you got the perfect snug fitment, work on using better materiel/printer and give me (and the other guys) the file so we can try and make some locally.
Wikerman, I like that idea however I want these to be able to be cut from a 2D CNC laser, so they can't have the groove the rib. The best idea is to add a sidesheet, however I honestly don't think they look that bad as is. I will probably cut some side sheets out to test that idea and glue them to the sides, in essence doing the same thing
I also like the idea of silicone, but I want these somewhat removable. Honestly the tape is probably overkill as the bolts hold the part on very tight.
Thanks for all the feedback!
For the future:
1. print out 6 side sheets to test on current proto parts.
2. Fix profile and print out 3 more proto parts (I will use the other more aggressive style for these). Also print out 6 side sheets pending results of #1.
3. Profit
Good point, But I wanna 3D printed option I found a company locally and they have the 3d equipment, with the grove and all it would look so much better the gluing stuff around lol. Maybe we could cut the grove with some hand tools like a hand held rotary drill set..
But to be honest using sheets is not a bad idea either. It could really work and solve the rough edges/surface issue. Okay man, I think your should incorporate the usage of the sheets however you must use somewhat thick enough, maybe 2 - 3mm thick sheets on each side and precision cut on the 3d/2d mill. So they appear to be one piece like it came that way from the factory and not something some ricer kid has been going around gluing on to his car.
After you get it all measured up and when I get the final product I personally would use black silicone as it will dampen the vibrations, its not really permanent, just rubberized adhesive, I installed some rear 3rd brake lights with it, and it can be pulled right off the rear windshield. Just the idea of tape makes me go yuk.
Print a set of the normal ones too, the aggressive ones look kinda bad on the paper, but maybe they would look better on the car in real life. waiting to see more soon and hope to hear back from you once everything is complete....I am going to meet around the first week of next month. So I want to show these off.
Actually for you I could probably just add the sheets and make it one part for 3D printing. Let me get the profile dialed in then we'll go from there.
I just sent my printer the STL file for the side sheets. We'll see how those look.
Thanks man Yea having the 3D option for the STL files with the sheets on the side in one piece for a 3D shop to print them out would be like BOSSCAR
a little off topic, ever thought of making something for the front of the m3/m tech e36 bumpers? I have been thinking of getting a velocity splitter or making something out of the whats called the "HD Garden Lip(?)" or designing my own from a sheet of dibond and a jigsaw but never got around to it.
Man the detail, good job. What did you use for the 3D modeling? C4D?
1993 325is 5speed mauritiusblau-metallic(in project mode)
Updates Please
Thanks! Creo 2 (used to be ProE)
Sorry! Been busy, waiting to get the side sheets from the guy. After that, I'll have him do another set or two with some changes as mentioned (I like having one set of parts designed for a 3D printer (more variation) and one set for a 2D part, like from a sheet of ABS).
I'll post pics when I get stuff, the car is filthy (had a bmw meet on a rainy day ).
Have been waiting the whole week for something, I know adding this to my car will give me the ultimate reps, aero drag and drif powar and makes girls attracted to me +2 which would make my attractiveness back to Positive 1! ... Okay maybe I get non of that but I really like the concept and wanted to try your final product on mine, hope its finished soon so i can print them out and put them on my car before I go to meet up some friends and bmw owners.
rain makes my car look more glossy and shiny. when you finish it make me that model please that makes it one part with the sheets and everything for 3d printing
still waiting...but more pics of the first proto.
Lookin good and subtle. Wish I had a M rear bumper.
Not bad looking even the first protos... nice work. actually they look kinda oem, would be nicer when you have the sides to make them look flush with the rest of the diffuser.
whats the hold up? why is it taking this long? I was hoping it would be all done by now.
its never too late for things like this you know.
You just had to think of this when I finally feel satisfied with my AC-S diffuser.. When I see the final product I might just buy the M-tech styled officer for non-m if it fits haha.
When can I buy this?
I can't imagine this will have any aero benefits, you're not creating any more of a "reverse wing" down there. So this is a "just for looks" thing right?
I have no problem with that, just trying to understand if I'm missing something
Jeff | '94 BMW Alpina B3 | '06 BMW 325XI Wagon
