Results 1 to 4 of 4
Thread: Coil spring for a levelling device?
    Aug 2020
    Finland
    1988 635CSi, 1995 525i
    Hi from Finland,
    I have a 1988 L6 with a levelling device, and it seems that coil spring 33531134195 is impossible to buy, even itīs not stated as "Delivery discontinued by the factory".
    http://bmwfans.info/parts-catalog/E2...vice#1134195_4
    37121126652 is still available which has been used with Euro versions, but itīs lighter (4.8 lb) than -195 (5.2 lb).
    http://bmwfans.info/parts-catalog/E2...e_2/#1126652_4
    Does anybody knows if -652 can hold L6īs heavier back with itīs additional AC?
    -195 has also information: "For vehicles with national version Australia", but maybe it is because same rear AC as US L6?
    Boston, Ma
    86 635,72 E3, 88M6,73 E9
    You should create a WTB...want to buy thread. Most have removed these systems so there are a bunch sitting around I bet. In fact someone gave away the entire system for an M6 a while back.
    Also, not sure who made these but MB used the same system so perhaps you can find a MB equivalent.
    Also you reference holding the weight of an L6.....the springs are for that and do differ for L6's weight. I would try to find the damping rates of both shocks, that's what you need to compare.
    Finally, for the price of the shock, you can almost pay for a setup to eliminate the SLS system. I drained all the pump oil and disconnected the electrical connection to the sensor/arm and capped off the lines to the shocks and replaced with Bilsteins and BMW springs. The system is all there if a purist wanted to re-install it.
    Good Luck
    Rob E3
    Mar 2008
    Napa, Ca
    1987 M6
    If all else fails, it is often possible to purchase custom wound suspension springs from any number of online retailers.
    Jose
    1987 M6
    Livin the dream!
    Aug 2020
    Finland
    Quote Originally Posted by RSheiman View Post
    Thank you Sir for the good answers!
    I`ll try to find that information somehow, but before than that, I think it's easier to make water to wine..
    I would like to keep the system as it is, and yes, Iīm the purist!
    Selling the car on year 2525 would be harsh if you have tampered the system.
  1. rear coil springs
    By eeviking in forum 1991 - 1999 (E36)
    Last Post: 05-19-2004, 02:05 PM
  2. coil spring compressor size?
    By andylv in forum 1992 - 1999 M3 (E36)
    Last Post: 01-12-2004, 10:30 PM
  3. M-technic II coil-springs
    By 1nicebimmer in forum 1983 - 1991 (E30)
    Last Post: 12-16-2003, 09:09 PM
  4. Wich coils springs can fit E46 325IX 2004?
    By mz3bo in forum 1999 - 2006 (E46)
    Last Post: 10-21-2003, 10:19 AM
  5. '97 M3 struts and coil spring compressor for sale
    By hozehead4 in forum 1992 - 1999 M3 (E36)
    Last Post: 05-19-2003, 07:34 PM
