Page 2 of 2 FirstFirst 12
Results 26 to 32 of 32
Thread: Compact WiFi Diagnostics
  1. #26
    Nov 2005
    Satellite Beach, FL
    2000 BMW 540iT Dinan S2
    I was checking on amazon and they didn't appear to include the 20 pin adapter. Is there one not from Carly that would work?
    - 2000 540iT Dinan S2 -2000 Z3 -
  2. #27
    Dec 2007
    Queensland, Australia
    E70 3.0sd E21 323i
    Yes, I believe that Carly do supply a hardwired 20pin adapter for Android. Have a look here http://www.ivini-tech.de/en/adapter/...or-bmw/a-1008/
  3. #28
    MINIz guy's Avatar
    MINIz guy is offline #buttstuff2k14 BMW CCA Member
    Bear, DE
    rolls coal
    Dave,
    Do you think this will 100% replace the need for the old mess of cables to run INPA or DIS?
    My Dell D630 is starting to show its age. I have it running a ADS cable with INPA and DIS V44 flawlessly, but like you said, it is a slow system. I've upgraded the CPU and RAM already. Next up would be to add an SSD and upgrade to Windows 7 from Vista, but if I can get Carly to replace the need to keep using my cables, I'll just let this D630 go out to pasture and get a modern laptop without the need to hunt for one with a RS-232 port.
    I have a variety of cars I need to use this app on. My E36 328i, and my parent's E53 X5 and E71 X6. Been getting by with INPA on the older BMWs, but I know I'm gonna struggle trying to keep up with the E71 and this app seems like a good solution.
  4. #29
    Dec 2007
    E70 3.0sd E21 323i
    I have already upgraded my DELL with a SSD but now only use it very occasionally for NCS and PA Soft. Carly has just kept getting better and in light of the convenience of being able to carry a wireless adapter in the glove compartment it has rapidly become my first choice for diagnostics and some coding. I have also purchased Carly for Mercedes and am waiting on the iOS release of Carly for VW. I still have DIS v39, v44, v57, a couple of versions of INPA as well as ISTA but not having to carry an ADS/OBD interface plus K+DCAN, my laptop and cables is a real winner.
  5. #30
    Nov 2005
    Satellite Beach, FL
    David MC, thanks for the coupon code! Just ordered it - can't wait to get this running.
  6. #31
    The Netherlands
    DE-spec E36 328i/M3 cab
    Can’t find much, so bringing this back.
    Does anybody know/tried if the Carly wifi adapter allows wireless diagnostics using a (mini) laptop with DIS/Inpa? I.e. can DIS/INPA connect through this wifi interface?
    IG:
  7. #32
    The Netherlands
    Anyone?
    Also, would the Carly for BMW adapter als only works for K line modules?
    IG:
