Page 2 of 3 FirstFirst 123 LastLast
Results 26 to 50 of 55
Thread: HOW TO: Reset Early Airbag/SRS light. No Special Tools!!!
  1. #26
    Jun 2001
    Reston, VA
    88 M5 FOR SALE, E92 335i
    Just confirmed this worked on an E30 318is!! Thank you SO MUCH!!
  2. #27
    May 2012
    Bethesda
    91 535i
    This worked for me first time! very very very happy. SRS came on due to instrument cluster removal w/o battery disconnect and key turn on (i knew better but long story). followed these instructions using a button switch and wires - hardest part is keeping track of what you should be doing. FYI my car is a 1991 535i (E34, M30), US. Thanks for posting this!
  3. #28
    Jul 2012
    exeter nh
    1991 BMW 850i
    I can verify that this procedure works on my 91 850i. I did some repairs on the gauge faces and triggered the srs light. I tried counting the seconds 4 times with no joy. Then I tried with a stopwatch and bingo, light went out. Timing is specific!!
  4. #29
    Sep 2017
    WY
    friend's 2003 525IT Wag
    The above procedure for re-setting the SRS light et cetera works on my 1992 325i e30 Cabriolet, Siemens module 5WK4 026 (BMW part number 65771382904). To reset the SRS light, I rigged wires from pins 1 and 6 in the diagnostic connector under the hood to where I was sitting in the driver's seat. I then installed a switch to connect and disconnect pins 1 and 6. I too used a stopwatch and was very precise when opening and shutting the switch. Counting aloud did not work.
    I can also read codes via the under the hood diagnostic connector (shorting pins 1 and 6) and watching the above-the-rearview mirror SRS light blink. See detailed instructions at https://www.r3vlimited.com/board/sho...d.php?t=173007 .Like others said, for re-setting the SRS light et cetera one has to clear the cause of the fault first.
    I found that the reason I was getting codes, and the SRS light was lit, was that the 1992 BMW's airbag needed replacement. This causes code ""Driver's airbag power supply wire faulty." For this scenario, I used a dummy resistor and reset the SRS light using the following steps:
    -- Disconnect the battery.
    -- Remove the small cover on the bottom side of the steering column.
    -- Disconnect the airbag connector that is underneath the small cover.
    -- Purchase a resistor of 3.6 ohms, 1/4watt from a local electronics shop. I think other sizes between 2 ohms and 5 ohms will likely work as well.
    -- Install the resistor in the connector's female end. This fools the diagnostic module into thinking a working airbag is installed. It clears the fault the diagnostic module was seeing.
    -- Reset the codes using the procedure given in the first post of this thread.
    After the initial six second lamp test, the SRS light stays off. I am now shopping for a new airbag. Or I may try to take the old one apart (carefully) and see if there is anything obvious.
    Here's a writeup of my troubleshooting approach: https://sites.google.com/site/hondal...roubleshooting . It does not use any of those expensive, special "BMW Special Tools."
    Great work, legoman67.
  5. #30
    Jan 2016
    Venice, CA
    1991 850i
    I am going to attempt this to clear my SRS light. I am an electrical novice so please forgive me. Unless there is a jumper somewhere I can buy, I figured I'd make one like some others have with a switch. What size are the pins?
    '91 850i 6spd
  6. #31
    Oct 2016
    Upper Darby, PA
    92 BMW 525i, 91 BMW 318i
    Just worked on a 92 525i. Thank you Legoman
  7. #32
    Jan 2016
    Venice, CA
    1991 850i
    What did you use for the jumper?
    I tried it yesterday and it did not work for me. I took long wire, put one end of raw wire right into pin #15 under the hood. Ran it to an on/off switch to control from the drivers seat and then to the ground post in the engine bay.
    I just twisted the wiring together, and haven’t tried soldering it
  8. #33
    Campo, CA
    525i, K12RS, 07 750Li
    This just worked for me as well, 1991 850i 6-speed. I accidentally disconnected the SRS connection and had the light on for awhile. I used a test light inserted to pin 15 and ran the clamp end to the ground post on strut tower drivers side. Use a watch unless you have a very good internal clock
  9. #34
    Jan 2016
    Venice, CA
    1991 850i
    Does anyone know if this process of reading the codes is the same process for the E31? Is the E30 have the same diagnostic connector as the 91 850i? Does the SRS light in the gauge cluster flash for codes?
    '91 850i 6spd
  10. #35
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    The E30 has 2 kinds of diagnostic connectors depending on built year, D-Type with 15 pins up to around 1987, and then the 20-pin connector https://www.e30zone.net/e30wiki/inde...iagnostic_Plug
  11. #36
    Jan 2016
    Venice, CA
    1991 850i
    Thanks Shogun. Looks like previous poster did this on a ‘92 so the 20pin connector. But the pin# layout in the link you provided is different than the one on page one of this thread that Timm posted. Is the layout vehicle specific. Either way, shorting Pins 1 and 6 don’t work on my car. On timm’s image, I have no #6, and on the e30 image in the link you provided I have no #1 pin.
  12. #37
    Jan 2005
    Japan
    If the pinout is slightly different and depends on year and model, has to be checked, check in the ETMs http://wedophones.com/BMWManualsLead.htm
  13. #38
    Jan 2016
    Venice, CA
    1991 850i
    Quote Originally Posted by shogun View Post
    So helpful Shogun. Thank you
    The options don’t match, so I wonder if there is another pin sequence that would do the same. The 92 325i used pin 1 and 6, 6 being “SRS connector”
    Options:
    92 325i cab
    1 Ignition coil
    6 SRS connector
    91 850i
    1 Ignition coil
    7 Service interval reset
    11 Voltage: ignition switch in start
    12 Alternator change indicator
    13 Speedometer signal output
    14 Voltage: hot at all times
    15 Diagnostic datalink
    16 Voltage: ignition switch in run and switch
    18 Program select for DME control unit
    19 Ground
    20 Diagnostic Datalink
    '91 850i 6spd
  14. #39
    Eddington, Maine
    89 E32 90 E30 74 E3 83 E
    The procedure did not work on my '89 E32 735. UN-grounding pin 15 the first time puts the SRS light into diagnostic mode where I was able to pull the error codes by counting the flashes. I'm fairly confident that the errors are no longer valid since I know how I caused them and have since fixed the issue, but I'm stuck unable to clear them.
  15. #40
    Jan 2005
    Japan
    see how demetk made it with a switch https://www.bimmerforums.com/forum/s...3#post28926233
    "This procedure actually worked on my 89. Tap into the white/yellow receive wire at the srs module. Maybe take a look at the ETM for your car and see if you can do anything with the white/violet wire at the srs module that is usually connected to pin 20 of the datalink connector. I'd be tempted to install a datalink connector and connect power, ground and the white/violet wire in the correct places. Maybe a reset tool will then work. On my 89 535 I was able to perform a manual reset of the srs light by switching the srs to ground a couple of times in a specially timed sequence that I found on the net. On my car the srs wire was connected to pin 15. " https://www.bimmerforums.com/forum/s...&highlight=srs
  16. #41
    Mar 2014
    Toronto, Ontario, Canada
    E34 M5
    So, I've read a bunch of posts about this SRS light reset trick without tools and with Shogun's tool etc... I have a 1993 E34 M5 that I bought with a non airbag steering wheel. The SRS light had never been on until I screwed up while taking the cluster out without having disconnected the battery first. (I know, I'm a dumbass.) It's flashing now... Getting to the point: Will the jumper trick reset the light? I understand I'm not trying to trick the system, just to reset it to how it was when I bought it. I've no idea how it didn't flash with the non airbag wheel to begin with. Otherwise, can I disconnect the "big orange connector" under the dash with no ill effect?
  17. #42
    Dec 2020
    New Smyrna Beach, FL
    1991 850i
    Had blinking SRS light, removed steering wheel to straighten it out, whomever had it off previously installed it upside down. While doing this I found SRS plug inside column was disconnected so I plugged it back in. Now I'm doing this jumper wire reset procedure from pin #15 under the hood to pin #6 at SRS 8 pin plug under the glove box. Question is, what color wire is pin #6? TIA
  18. #43
    Dec 2020
    USa
    E31
    Quote Originally Posted by legoman67 View Post
    This only works on Early E31, start of production to 09/93 With SIEMENS 5WK4 027 (65771382905) modules. This module is also found in some E23,e24,e30,e32,e34, and e36, procedure should work for those as well. This worked for mine even when DIS/INPA/Autologic, and all those others failed to communicate.
    1. Turn the ignition switch to the off position.
    2. Install a jumper from in pin #15 of the engine diagnostic connector to
    ground.(Since this is awkward to do in the timing given in this procedure, i used a small screwdriver and tapped into pin 6 at the orange x74 connector behind the glovebox, either will work)
    3. Turn the ignition switch to the on (run) position but, do not start the car.
    4. wait five seconds
    5. disconnect the jumper.
    6. Wait another five seconds.
    7. Reconnect the jumper
    8. After five seconds
    9. disconnect the jumpers.
    10. Wait five seconds
    11. Turn the ignition switch off.
    12. Start the car. The air bag warning light should clear after approximately 10
    seconds. If the light does not clear repeat the procedure. If, after three attempts,
    the light does not clear, there is most likely a problem with the air bag system
    which needs to be repaired.
    Which pin is the correct? The 15 or the 14? In another forum is stated that there was an error on pi selection.
  19. #44
    Dec 2020
    USa
    E31
  20. #45
    Del Mar, CA
    91 850i, 01 740i, 06 760
    Here's a simple schematic that will simplify the SRS read/reset (switch selected) for early E31 (mine is a 91 850i with Siemens 5WK4 027). This connects to the diagnostic port in the engine bay.
    To read SRS codes this simply holds RxD low for a few seconds (when ignition is turned on) and then releases. If you then wait about 20 seconds the SRS light will flash out the codes which you can decode with the info in this thread.
    SRS reset holds RxD low (when ignition turned on) for 5 seconds, releases it for 5 secs and then pulls it low a 2nd time for 5 seconds and then releases. After about 20 seconds you can turn off the ignition, remove this circuit and SRS should be reset.
    You could of course do this manually as suggested in the first post.
    I've used this a few times on my own car and it works well. The pot allows adjustment to exactly 5 seconds (I'm not sure how critical this is).
    It's not my neatest work... I threw it together with salvaged parts.
    I was hoping to communicate directly with the SRS module since it has TxD/RxD but the Siemens 5WK4 027 is not compatible with Inpa or DIS. It does not appear to use the same wake up protocol as the EML, DME, EGS as I tried every combination and none produced a response. I'm sure it is possible but I can't find any details on the protocol for this ECU so have to make do with flashing codes...
  21. #46
    May 2020
    Poland
    E32 1989 730iA M30
    Since I do experience some issue with my srs light I am expert in resetting procedure
    IMO even 6 sec will not work. I have wires connected to diagnostic port with switch on the end so I can make a bridge from the cabin. I have also stopwatch running to be exactly on time. After resetting I wait around 10 seconds and start the engine.
  22. #47
    Dec 2011
    CSRA, SC
    850Ci, Excursion
    Just tried a few more times this time using a stop watch. Still no luck for me. Just been driving around with the warning light on...not sure what I'm screwing up. I'm all for free fixes but at this point can I pay for a tool to plug in and easy button this away?
    I'm sure if I took it to the local BMW dealer they wouldn't even know what the car was and probably only know how to replace valve cover gaskets on N54 motors anyway.
    For reference I also triggered the light by pulling my steering wheel to get the cluster out. I'm sure there's nothing actually wrong...
  23. #48
    Dec 2011
    CSRA, SC
    850Ci, Excursion
    Can "the Peak tool" do it? Can one even buy them anymore?
  24. #49
    Oct 2007
    Henderson, NV
    145 cylinders of power
    Quote Originally Posted by LappingLuke View Post
    I have a Peak tool, not sure if it can reset the SRS but I can try and report back. My SRS light is on and this timing reset did not work on my 11/93 production 1994 MY 840Ci
    Random Sig below (refresh to see new image)
  25. #50
    Jan 2005
    Japan
    Peake Research R5/SRS Airbag SRS Scan/Reset Tool as well as the cheap SRS B800 Made in China work on newer BMW's from 1994-mid 2000, so probably not on E31, E32, E34. Different p/n of the module (?)
    I tested the B800 tool on a 1993 E32, did not work, but it worked on my 1998/02 E36 M3, could read SRS fault codes and delete the fault (passenger seat occupancy sensor)
