Results 1 to 25 of 55
Thread: HOW TO: Reset Early Airbag/SRS light. No Special Tools!!!
    Apr 2009
    Vancouver Isl, BC, Canada
    98 Euro M3, 04 M3, 06 M5
    This only works on Early E31, start of production to 09/93 With SIEMENS 5WK4 027 (65771382905) modules. This module is also found in some E23,e24,e30,e32,e34, and e36, procedure should work for those as well. This worked for mine even when DIS/INPA/Autologic, and all those others failed to communicate.
    1. Turn the ignition switch to the off position.
    2. Install a jumper from in pin #15 of the engine diagnostic connector to
    ground.(Since this is awkward to do in the timing given in this procedure, i used a small screwdriver and tapped into pin 6 at the orange x74 connector behind the glovebox, either will work)
    3. Turn the ignition switch to the on (run) position but, do not start the car.
    4. wait five seconds
    5. disconnect the jumper.
    6. Wait another five seconds.
    7. Reconnect the jumper
    8. After five seconds
    9. disconnect the jumpers.
    10. Wait five seconds
    11. Turn the ignition switch off.
    12. Start the car. The air bag warning light should clear after approximately 10
    seconds. If the light does not clear repeat the procedure. If, after three attempts,
    the light does not clear, there is most likely a problem with the air bag system
    which needs to be repaired.
    Current:
    - 09 335i MSport, FBO.
    - 98 Euro M3, Estoril Blue
    - 04 M3, Carbon Black, 6 Speed Coupe
    - 06 M5, Black on Black, Full Leather.
    - 73 3.0CS, Tagia Green, 5 speed M30b35 converted
    Ex's: 1984 325e, 1988 325IX, 1992 525I, 1995 540i/6, 2002 330i, 2005 330xi, 1992 850i, 2003 330i #1, 2003 330i #2, 2002 330ci, 2004 330ci, 2007 328CI, 2007 335i, 2001 M3, 2006 M5 6 speed
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    That's one I haven't come across before, thanks!
    My BMW Repair YouTube Channel
    Calgary, Canada
    '91 E31 850i,'05 E53 4.4
    Quote Originally Posted by legoman67 View Post
    4. After five seconds, disconnect the jumper.
    5. Wait another five seconds.
    6. Reconnect the jumper to ground pin #6 (or from pin #15 in the round OBD port under the hood???).
    7. After five seconds, disconnect the jumpers (I'm assuming you mean only one jumper either Pin #15 of the round OBD port under the hood, OR the alternative Pin #6 of the orange x74 connector behind glove box, and not 2 jumpers?.
    Legoman, can you see what I wrote in color and clarify for me please. Just wanna make sure there is only one jumper wire needed.
    either the #15 pin in the round OBD port under the hood, OR the alternative pin #6 of the x74 orange connector under glovebox.
    Cheers
    I remember doing something with a wire and the OBD port to reset the oil/service interval light too.
    I swear, my cars are like a girlfriend.
    Sometimes its a rough ride, sometimes its smooth motorin'.
    Sometimes she doesnt like how i treat her and sometimes i dont like how she behaves.
    BUT at the end of the day, she loves it when I am inside her.
    Apr 2009
    yes, only 1, they are both the same wire, just different points to reach it at, i edited to first post to eliminate confusion
    Current:
    radlaw's Avatar
    radlaw is online now SoCalEights Member BMW CCA Member
    Feb 2010
    Poway (San Diego), CA USA
    1995 BMW 840Ci
    legoman: how did you ever come up with this solution? It couldn't have been trial-&-error!
    Apr 2009
    Quote Originally Posted by radlaw View Post
    i found it in an old PDF file that was for another car, i just modified it slightly to correct the pin numbers and plugs.
    Current:
    Mar 2011
    Damascus, Maryland USA
    E31/E32 VWs Tesla
    Send me the instructions you have, maybe I can translate (electrially).
    It would be great to do this kind of thing with a $1.49 16-pin PIC microcontroller, a $0.49 7-segment display, and a $0.75 1"x1" piece of proto board.
    '89 735i, '91 850i, '81 MB 380SLC (For Sale), Tesla Model 3, and VW Passat TDI -- Yes, I still repair General Modules, DM for info!
    Aug 2011
    Charlotte, NC
    1991 850i manual
    After start up the SRS light on my car (CB42262 Prod 02/91) blinks for about two-3 minutes and then stays on permanently while the car is running...is it supposed to? If not should I give this a try? I presume the light should be off.
    Off -topic- sort of? I got a nice tutorial from Iceman (Brian) and he demonstrated his diagnostic tools on friday in Wichita. He used his tools to help me diagnose a potential cause of my rich running passenger bank. Great guy! I have a better idea of how DIS/INPA work...and am curious about crankshaft rotational information. How can we M70 owners get more diagnostic info about (cylinder specific) the crankshaft dynamics. The "rough" crankshaft information. Just curious!
    1991 BMW 850i
    2007 Honda Odyssey
    2017 Hyundai Elantra
    2013 Honda CRV
    2003 MotoGuzzi 850 Jackal
    Apr 2009
    Quote Originally Posted by acheson850i View Post
    The light should not stay on. It should go off within 10 seconds of the car starting.
    Remaining on means there is a fault code stored in the module. Most likely from removing the steering wheel without taking proper steps to avoid triggering it. This procedure should work for you.
    Current:
    Aug 2011
    Charlotte, NC
    1991 850i manual
    Thanks ...its on my list. I have larger "cats to skin" at the moment(e.g. finish putting in air collectors, front UCA's rear ball joints...etc). I am on my way home to CLT. Glad I took the car...for Wuffer's sake it is gonna be my daily driver!
    Aside: After Iceman(Brian cleared codes with his DIS/INPA) and we drove the car for awhile I had 1444(ok) and 2247. Today I have 1247 and 2247. Car is running on all 12 ...new sparkplug set new d side MAF and water temp sensor. Need to swap O2 sensor leads. Lots of smoke on startup out right side exhaust and definitely running rich on that side...conclusion was that O2 sensors may have been swapped and the EML (?) is trying to compensate and is adjusting fuel/air mixture of the throttle bodies...throttle bodies were refurbished by Tom Carter. Brian introduced me to Gerry Veer who was looking for the BMW procedure to adjust the wipers in the DK rotors before reinstalling them. Seems like I saw a thread here related to that....Ilike your wheels on your car. I bought some 17 inch used TSW Hockenheim's and new tires and will be installing those when I get back to CLT. Thanks for the procedure. I want to make a trip out west in my 8...so it would be great to meet up sometime!
    "Why should I do anything for posterity? What has posterity ever done for me?" Groucho Marx
    1991 BMW 850i
    2007 Honda Odyssey
    2013 Honda CRV
    Apr 2013
    Dallas Texas
    1993 850CI
    This is very timely as my SR light just started blinking. Can one of you post a diagram of engine diagnostic connector or the one behind the glove box or some pictures showing the jumpers please? My production date s 05/93 so this should work. We have had our old girl or over 20 years, drive it daily. I appreciate your help very much. PAH850Ci in Dallas.
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    Here's one with numbers:
    ....and the connections are shown in here:
    http://www.meeknet.co.uk/e31/e31_93.pdf
    Apr 2009
    the X74 plug is an 8 pin orange plug that plugs into the SRS module(1 of 2 that plug into the module, the other is a 6 pin). the module is located behind the glove box. You have to remove the kick panel, under tray, and upper and lower glove boxes to get to it. Unless your dash is already a part, or you are familiar with removing the glove box, i would just get a buddy to work the ignition for you while you do the jumper from the diagnostic plug pictured above.
    Also in response to earlier posts about reading the codes. It doesnt actually state how to trigger the blinking, it just says it can be done:
    You can retrieve the fault codes from a Siemens controller if you wish. The controllerwill blink out a series of codes through the SRS light in the Active Check Control panel.
    The first number that it blinks is the number of stored codes. Next, will come a long
    blink. Then the fault codes will be blinked. The fault codes are separated by a long
    blink. Each fault code is blinked as four digits as follows:
    1. Light flashes 1 to 4 times for the first digit.
    2. 3 second pause.
    3. Light flashes 1 to 4 times to indicate the second digit.
    4. 3 second pause.
    5. Light flashes 1 to 4 times to indicate the third digit.
    6. 3 second pause.
    7. Light flashes 1 or 2 times. (once = Short-time fault; twice = Long-time fault)
    The table below provides the fault descriptions for early Siemens controllers
    Here is the table:
    Blink Code-Fault-Fault Description
    111 1 Front Sensor Left Closed 1 time
    211 2 Front Sensor Left Closed several times
    311 3 Front Sensor Right Closed 1 time
    411 4 Front Sensor Right Closed several times
    112 5 Front Sensor Left Closed permanently
    212 6 Front Sensor Right Closed permanently
    312 7 Front Sensor Lead Left Leaks against positive
    412 8 Front Sensor Lead Right Leaks against positive
    113 9 Front Sensor Lead Left Leaks against ground
    213 0A Front Sensor Lead Right Leaks against ground
    313 OB Front Sensor Lead Left Short circuit against positive
    413 OC Front Sensor Lead Right Short circuit against positive
    114 OD Front Sensor Lead Left Short circuit against ground
    214 OE Front Sensor Lead Right Short circuit against ground
    121 11 Front Sensor Lead Left Break
    221 12 Front Sensor Lead Right Break
    321 13 Front Sensor Lead Left Excessive resistance
    421 14 Front Sensor Lead Right Excessive resistance
    322 17 Ignition Capacitor 1 Insufficient capacitance
    422 18 Ignition Capacitor 2 Insufficient capacitance
    123 19 Transition resistance to ignition capacitor 1 Excessive
    223 1A Transition resistance to ignition capacitor 1 Excessive
    323 1B Ignition Circuit 1 - Driver Airbag Leak against positive
    423 1C Ignition Circuit 2 - Passenger Airbag Leak against positive
    124 1D Ignition Circuit 3 - Passenger Airbag Leak against positive
    224 1E Ignition Circuit 1 - Driver Airbag Short circuit against positive
    324 1F Ignition Circuit 2 - Passenger Airbag Short circuit against positive
    424 20 Ignition Circuit 3 - Passenger Airbag Short circuit against positive
    131 21 Ignition Circuit 1 - Driver Airbag Leak against ground
    231 22 Ignition Circuit 2 - Passenger Airbag Leak against ground
    331 23 Ignition Circuit 3 - Passenger Airbag Leak against ground
    431 24 Ignition Circuit 1 - Driver Airbag Short circuit against ground
    132 25 Ignition Circuit 2 - Passenger Airbag Short circuit against ground
    232 26 Ignition Circuit 3 - Passenger Airbag Short circuit against ground
    332 27 Ignition Circuit 1 - Driver Airbag Break
    432 28 Ignition Circuit 2 - Passenger Airbag Break
    133 29 Ignition Circuit 3 - Passenger Airbag Break
    233 2A Ignition Circuit 1 - Driver Airbag Insufficient resistance
    333 2B Ignition Circuit 2 - Passenger Airbag Insufficient resistance
    433 2C Ignition Circuit 3 - Passenger Airbag Insufficient resistance
    134 2D Ignition Circuit 1 - Driver Airbag Excessive resistance
    234 2E Ignition Circuit 2 - Passenger Airbag Excessive resistance
    334 2F Ignition Circuit 3 - Passenger Airbag Excessive resistance
    434 30 Failure Warning Lamp Short circuit
    141 31 Failure Warning Lamp Broken filament
    241 32 Control Unit Internal fault
    341 33 Firing Order Correct -
    441 34 Ignition Current Flowed
    Current:
    San Ramon, CA
    850Ci, M5, Model-S P85D
    I am still working on reading codes, the instructions i found for that are not clear. I will update with that later.
    Here is what I know:
    My 1990, E34 M5 has the same SRS control unit. My 1988, E24, M6 had an earlier model Siemens SRS controller that uses the same code reader/reset tool.
    I purchased the BMW SRS code reader/reset tool (88 88 6 621 290) that works on the Siemens SRS controller a long time ago because it was the only way to reset the Siemens SRS control in the early days (1990's).
    The Siemens SRS control causes a lot of consternation when it was first introduced because it was the first SRS control that required special tools to reset.
    Yours is the first post since I have been involved with BMWs since 1990 that indicates the Siemens SRS controller can be reset without special tools.
    As for reading the SRS flash codes; there are only 2 document that I am aware of, produced by BMW, that explain how to read the flash codes and only one document that defines the flash codes.
    The manual for the 62 1 290 SRS reader/reset tool only has the explanation of how to read the SRS flash code.
    The E30 Repair Manual (01 51 9 770 561) includes the SRS Troubleshooting in the Group 32 Steering and Wheel Alignment section.
    https://www.bmwtechinfo.com/repair/main/Index_cd3.htm
    This manual on page 32-55.1 includes the Siemens SRS Control - HOW TO Read the SRS light flash codes and a section on flash code conversion into fault codes and fault code definitions.
    The SRS flash/fault code list posted here is a more comprehensive list that what is in the E30 Manual and includes SRS codes I have yet to find in any other official BMW document and believe me I have just about every official document produced by BMW.
    Just Having Fun,
    Rod...
    Apr 2009
    Quote Originally Posted by m6bigdog View Post
    Just Having Fun,
    Rod...
    It is unclear what vehicle the directions i have were originally written for. not an official document.
    Current:
    San Ramon, CA
    The BMW OE reset tool 62 1 290, for the SIEMENS 5WK4 027 (65771382905) controller also works with the Siemens controller in the E23, E24, E28, E30, E31, E32, E34 & E36 vehicles up to 9/1991. Some of these cars also used a Cipro airbag controller but I believe the E31 only used the Siemens SRS controller.
    On the E31 this model Siemens controller was also only used up to 9/1991. Unsure what controller is used after 9/1991 , however the Peak R5/SRS scan/reset tool works on my 97, 850
    It is also my experience that the Peak R5/SRS scan/reset tool is unfortunately not compatible with the Siemens 5WK4-025,027 or 035 controller.
    Atlanta
    1993 BMW 740IL
    Question on this? I've read that pin 19 is ground so it stands to reason that you could use the jumper to connect pin 15 and pin 19 and that would work?
    1993 740IL
    Apr 2009
    Quote Originally Posted by Mello740 View Post
    yes, that would work
    the later airbag modules (09/93 and up from what ive read) have no issues communicating with all the usual diagnostic tools(DIS, INPA, Autologic, PEAK, ETC).
    The only 2 units i have heard of that will reset the early 5WK4 airbags are the factory tool you mentioned, and shogun's specially developed tool.
    Current:
    Duesseldorf, NRW, Germany
    '90 850iM70B54, '91 850i
    didn't work on my 04/1991 850i
    And the system should be ok because there was no issue before I swapped the wheel.
    Apr 2009
    The timing is very specific. I actually used the stopwatch on my phone to do it.
    Quote Originally Posted by wokke View Post
    Current:
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    didn't work on my 04/1991 850i And the system should be ok because there was no issue before I swapped the wheel.
    Wolf, in case you need, I have some BOA on stock, that definitely works on your E31.all BMW from 1987-2006, plus Mini and Rover from 2001 for airbag/srs/oil/inspection/annunal inspection (clock), has connector for 20-pin round diagnosis port plus OBD
    Update: all reset tools sold
    Last edited by shogun; 11-15-2021 at 01:33 AM. Reason: update, all reset tools sold
    I ordered the tool from shogun and succeeded on two 850s. My own one plus a customer car having had the same issue like me.
    Also the SI rest works flawlessly. Thanks for pointing me to that product Erich.
    Iceland
    BMW 850
    Hey guys.
    I was wondering about one thing.
    I changed the steering wheel to a non airbag one and have the airbag light on.
    Got the reset tool from Shogun. Has anyone been in this situation? Will it take the light out?
    Jan 2005
    Japan
    The reset tool will be shipped to you this week, but in my opinion you will not be able to permanently reset the airbag light, as the airbag module has the fault that the steering wheel airbag is missing, not working ot whatsoever. I either will go out when resetting, but will go on again when you start the car or it will not go out at all. My tool is not to trick the airbag system, it is just to reset the airbag light after a fault has been repaired.
    The owners manual for the reset tool clearly mentions:
    Note: the SRS system on your BMW needs to be functioning properly in order to reset the airbag/SRS light. If the system detects a fault on any of the systems sensors a reset without replacement/repair of those failed components is not possible.
    I assume the only possibility might be to simulate that the steering wheel airbag is still there, at your own risk of course. Maybe similar to the seat mat occupancy sensor simulator for the passenger seat. Often the sensor mat is defective and the light comes on and people install this simulator under the seat.
    But I have no idea how such a simlator for the steering wheel airbag should be.
    Dec 2004
    CT, USA
    e28, e34, e39
    Update:
    I figured I'd try one last thing.
    So I made this little jumper with a switch and connected it to pin 15 (RXD) and pin 19 (ground).
    Then I followed this procedure using my stopwatch app on my phone.
    2. Install a jumper from in pin #15 of the engine diagnostic connector to ground.
    7. After five seconds, disconnect the jumpers.
    8. Wait five seconds after disconnecting the jumpers.
    9. Turn the ignition switch off.
    10. Start the car.
    The air bag warning light should clear after approximately 10 seconds.
    If, after three attempts, the light does not clear, there is most likely a problem with the air bag system which needs to be repaired.
    IT WORKED!
    The SRS light solidly came on with the ignition and then went out. Silly me, I saw this process a while ago and dismissed it since I read everywhere that you needed special tools and software to talk to the SRS module.
    I'm still in WOW, I can't believe it mode.
    cheers
