Results 1 to 22 of 22
Thread: Side View Mirror Glass Replacement (Heated).
    West Michigan
    98 540iA (Prd 11/97)
    A common ailment for the E39 heated side view mirror is a problem created by a failure of the external (ambient) temperature sensor. Whether due to sensor decapitation or electronics fault, this issue causes the heated mirrors to default to "on" even in balmy conditions. The result is a brown, burnt condition around the edges of the mirror. The solution is to purchase replacement glass and DIY.
    Here's the result of the problem.
    Remove the adulterated mirror by tilting the mirror inward as far as it will go and pry the mirror off with gentle but firm pressure until it pops off.
    Once removed, you'll see how the wires are connected to the mirror.
    Wiggle the connectors off using a gentle back and forth motion.
    New mirror.
    Reconnect the wires.
    Pop the mirror back into place. Be careful to make sure the mirror is aligned correctly for seating.
    End results. A clean, new look.
    Santa Cruz Mountains
    00Sport/03M-Sport 540iA
    Nice job Bro...looks new again!
    West Michigan
    Quote Originally Posted by ViolinARC View Post
    Thanks. It's been bugging me.
    Raleigh, NC
    2001 M5
    How do you know if you have a heated side mirror? Just pop them out and see for those two wires? My driver side mirror has that little burning patch to the sides.
    West Michigan
    Quote Originally Posted by auaq View Post
    That's one way. Another is to plug the last 7 digits of your VIN or your car's production date and specifics in at realoem.com and check.
    Raleigh, NC
    2001 M5
    Yeah, I could've done that but was too lazy to open another tab, type in last seven, and keep on searching .... Was hoping to simply pop off the mirror and confirm, but now you have made me do some work.
    So, if you have heated side mirrors does that mean it only comes with heated seats and or heated steering wheel?
    Jan 2013
    2003 BMW 530i Sport
    Just a tip for those that are thinking about doing this:
    1. Be sure to get the correct mirror (driver mirror is flat in order to judge proper distance while passenger is aspherical to gain a wider field of view), but either one can be installed. Just be aware.
    2. I'd order the Euro Aspherical mirrors if I was going to replace. OEM is best. I got some cheap Chinese knock offs and the glass fell off of it when the temps fell below zero.... My brother was lucky though and his are perfect. Go figure.
    Heated mirrors are pretty much standard. Absolutely no relation to heated seats (Cold Weather Package) or the 4 prong (boat) heated steering wheel.
    Oct 2013
    Atlanta, GA, USA
    '01 540i6, '03 X5 4.6is
    Great DIY.
    Mods, please move this to DIY section so we don't lose. :-)
    2001 Aspen Silver 540i6 - 180k mi - 3" DUDMD Tune, aFe Intake, M60 Intake Manifold, Eibach Anti-Sway Bars (F&R), e60 SSK
    Sep 2012
    Lexington, KY
    99 540it Wagon
    awesome! my driver side mirror has burnt edges as well. nice to know they may be heated.
    Jan 2012
    San Diego, CA
    too many
    I replaced mine with the European e39 mirrors (they are tinted blue for glare, heated, and convex at the outer edge)
    http://www.ecstuning.com/BMW-E39-540...rors/ES251460/
    Function wise, they are WAY better than the American ones.... and they don't have the writing that tells you to be careful for cars in the mirror!
    The best part is, no more blind spot! (i had a blind spot problem before doing this changeup)
    PS if you look at RealOEM, they show all the different mirrors for the different continents... I tried to order the middle eastern passenger side because it had cool-looking middle eastern writing on it but dealer told me they are not allowed to order that one
    agentrnge's Avatar
    agentrnge is offline BMWCCA Member - NJ BMW CCA Member
    Lincoln Park, NJ
    2003 540i/6, 2001 740iL
    That looks easy enough. Thanks. Got the same junk on my mirrors. I'll be doing this shortly I think.
    You mentioned they overcook due to the sensor misreading and keeping them heated all the time. Is the sensor in the glass, or something central, connected to the ambient air temp sensor? Point is, will the new heated glass get cooked in time as well?
    geargrinder's Avatar
    Mar 2010
    AndoverRockport MA & Intl
    E46 M3Cic6MT, E39 540iT
    Quote Originally Posted by BavarianE31 View Post
    Put me in yer bro's category - I got the Taiwanese reps for my M5 mirrors and they've been great. Heated but not auto-dim. Inexpensive but Euro-aspherical. I posted a thread about 'em someplace, would recommend.
    Quote Originally Posted by fullthrottle540 View Post
    Those are the good ones, nice. I didn't mind the 540 blind spot too much before the M5 mirrors though, the M5 USA mirrors are criminally negligent in how bad they are... those REALLY benefit from the Euro style aspheres.
    2003 M3CicM6 TiAg
    1985 Euro 300SL
    2008 Audi A3 2.0T DSG (hers)
    1999 Cherokee Sport 4L (trailer-hitched in-law-loaner bomber)
    And a recent former:
    Some Stuff FS
    Jan 2012
    San Diego, CA
    too many
    Not sure how the BMW is wired up, but I know that my Infiniti only heats the mirrors when you use rear defrost...
    But then again, that would be too simple for BMW... i wouldn't be surprised if it was in fact hooked up to the ambient sensor through the main computer
    Mar 2012
    Lansdale, Pa
    6/98 BMW 540 6sp VF S/C
    Quote Originally Posted by agentrnge View Post
    Its the ambient temp sensor under the front bumper.
    My old driver mirror did the brown edge thing as well, but my ambient temp sensor was always working, so they can become de-silvered by age too.
    I did the Euro mirrors on both sides. Very nice, but takes a few drives to get used to the new driver side mirror. The outer aspherical edge makes "objects are closer than they appear" effect kind of strange at first, but all good after adapting to it.. Really helps remove blind spots. Great upgrade.
    Jan 2012
    San Diego, CA
    too many
    Quote Originally Posted by philly98540 View Post
    Agreed - it took me a couple days to get used to it, but very worth it....
    Anytime someone new drives my car, they always exclaim at how odd the mirrors are to them...
    Raleigh, NC
    2001 M5
    But ... it hurts my eyes with those magic mirrors ........ just saying.
    Nov 2010
    Ohio
    BMWs & MINIs
    We have them in stock for 77.00 per side. They are a nice upgrade.
    -Sean
    -Sean from The BMW/Mini Part Store-
    [Website]http://thebmwminipartstore.com/
    [Email] thebmwminipartstore@gmail.com
    West Michigan
    I believe this is correct. I think the heated windshield wiper spray nozzles are also controlled by the reading from the ambient temp. sensor.
    Raleigh, NC
    2001 M5
    Wow, I'm impressed to know more fancy stuff like heated wiper spra nozzles on our cars. More reason to love BMW and E39.
    Nov 2011
    Milwaukee, WI
    2003 530i
    Thanks! I've been meaning to replace my mirrors for a while now and this thread kicked me into action. I ordered the Euros mainly because of the blue tint which hopefully will make them easier on the eyes at night. However, even if it makes no diff, the blind spot feature will be worthwhile.
    San Carlos, CA
    2003 530iA
    I almost bought a non OEM set off ebay, but will be holding off until I just get the real deal. No faster way to make a vehicle feel cheap than putting on bad mirrors.
    2003 DINAN 5 | M54B30 | Titanium Gray Metallic | Stage 3 Engine Software | High Flow Throttle Body | Cold Air Intake | Free Flow Exhaust | Performance Automatic Transmission Software | Front Strut Brace | OE 18x9 BBS RS745 Style 42 on 265/35-18
    MY BUILD THREAD: [Click]
    FOR SALE: Ti Grey Metallic standard rear bumper [Click]
    Aug 2016
    Virginia,USA
    528i, 525iT, M5, x5 4.8
    Just replaced my drivers side with this DIY, easy peesy!
    thanks for the effort!
