Brought my '07 335I coupe into the dealership to get the fuel pump replaced under the extended warranty...... This is what they came back with. How much should this cost realistically at an independent mechanic? Any other thoughts? Help.....
CUSTOMER QUOTE
__________________________________________________ ______________________________
OPERATION: 1351518 Fuel Pump, r&r 335i/335xi 07/10 Engine Bay
QTY PART NUMBER PART DESCRIPTION PART PRICE EXT PRICE
1 BM13-51-7-616-446 EXCH HIGH-PRESSURE P 299.97 299.97
1 BM11-61-7-547-242 SET OF PROFILE GASKE 37.56 37.56
LABOR $: 538.02
PARTS $: 337.53
GOG $: 0.00
MISC. $: 0.00
TAX $: 27.85
SUBTOTAL $: 903.40
OPERATION: BR-322 FRONT BRAKES AT 2MM. RECOMMEND IMMEDIATELY.
335i 2007 Up To 2-07
1 BM34-11-6-794-917 REPAIR KIT, BRAKE PA 163.28 163.28
1 BM34-35-6-789-440 BRAKE PAD WEAR SENSO 23.27 23.27
1 BM83-12-2-296-187 BRAKE PAD PASTE - 5 1.30 1.30
2 BM34-11-6-855-000 BRAKE DISC, VENTILAT 183.29 366.58
1 BM34-35-6-779-356 CLIP FOR BRAKE PAD W 1.17 1.17
1 ZLBULKBC2 BULK BRAKE CLNR 2.75 2.75
LABOR $: 246.79
PARTS $: 558.35
GOG $: 0.00
MISC. $: 0.00
TAX $: 46.06
SUBTOTAL $: 851.20
OPERATION: BR-321 REAR BRAKES AT 1MM. ALMOST METAL ON METAL 330i/335i 06/09
1 BM34-21-6-791-938 REPAIR KIT, BRAKE PA 110.65 110.65
1 BM34-35-6-789-445 BRAKE PAD WEAR SENSO 24.42 24.42
2 BM34-21-6-855-004 BRAKE DISC, VENTILAT 150.24 300.48
LABOR $: 246.79
PARTS $: 439.60
GOG $: 0.00
MISC. $: 0.00
TAX $: 36.27
SUBTOTAL $: 722.66
OPERATION: OILSER6 Oil Service OEM 335i/335is 07/13
1 BM11-42-7-566-327 SET OIL-FILTER ELEME 9.92 9.92
7 BM07-51-0-017-954 MOTOR OIL SAE 5W-30 7.44 52.08
MISC CODE MISC DESCRIPTION QUOTE MIN QUOTE MAX PRICE
HW HAZARDOUS WASTE 3.00
LABOR $: 29.83
PARTS $: 62.00
GOG $: 0.00
MISC. $: 3.00
TAX $: 5.12
SUBTOTAL $: 99.95
OPERATION: FBS BRAKE FLUSH - SHOWS DUE PER CBS. VERY LOW/DIRTY. All
2 BM81-22-0-142-156 BRAKE FLUID 10.37 20.74
HW HAZARDOUS WASTE 6.00
LABOR $: 110.50
PARTS $: 20.74
GOG $: 0.00
MISC. $: 6.00
TAX $: 1.71
SUBTOTAL $: 138.95
OPERATION: MSPR6 REPLACE SPARK PLUGS - DUE AT 45K. 335i/335is 07/13
6 BM12-12-0-037-244 SPARK PLUG, HIGH POW 31.58 189.48
LABOR $: 234.32
PARTS $: 189.48
GOG $: 0.00
MISC. $: 0.00
TAX $: 15.63
SUBTOTAL $: 439.43
OPERATION: ACMF REPLACE MICROFILTER - SHOWS DUE 2012
335i/335is/335xi 07/13 Activated Charcoal MF
1 BM64-31-9-313-519 MICROFILTER/ACTIVATE 68.74 68.74
LABOR $: 68.75
PARTS $: 68.74
GOG $: 0.00
MISC. $: 0.00
TAX $: 5.67
SUBTOTAL $: 143.16
OPERATION: BR-323 REPLACE ALL 4 PADS/ROTORS/BOTH SENSORS
2 BM83-12-2-296-187 BRAKE PAD PASTE - 5 1.30 2.60
LABOR $: 495.56
PARTS $: 995.20
GOG $: 0.00
MISC. $: 0.00
TAX $: 82.10
SUBTOTAL $: 1572.86
OPERATION: 17TIRE2 REAR TIRES 1MM FROM WEAR BARS ON INSIDE.
335 Continental ProContact SSR 225/45R17 91H Two
2 BM36-11-0-414-665 TIRE 225/45R17 CONTI 252.94 505.88
2 BM36-12-1-116-326 RUBBER VALVE 9.20 18.40
2 ZLSS29 TAPED WEIGHTS 5.00 10.00
LABOR $: 50.00
PARTS $: 534.28
GOG $: 0.00
MISC. $: 0.00
TAX $: 44.08
SUBTOTAL $: 628.36
OPERATION: AL4WD RECOMMEND ALIGNMENT WITH REAR TIRES. AFTERMARKET WHEELS
WILL REQUIRE SPECIAL ADAPTERS AND INCREASED RATE.
LABOR $: 209.95
PARTS $: 0.00
GOG $: 0.00
MISC. $: 0.00
TAX $: 0.00
SUBTOTAL $: 209.95
OPERATION: 2434021 TRANSMISSION SEALING SLEEVE HEAVY LEAK ZF Exc 335d 06/13
1 BM24-34-7-588-725 SEALING SLEEVE 29.60 29.60
1 BM24-11-7-571-235 GASKET, OIL PAN 45.38 45.38
1 BM24-11-7-520-714 O-RING 9.20 9.20
3 BM83-22-0-406-929 1/2 LITER OIL 25.00 75.00
1 BM24-11-7-520-713 SCREW PLUG 14.49 14.49
LABOR $: 512.02
PARTS $: 173.67
GOG $: 0.00
MISC. $: 0.00
TAX $: 14.33
SUBTOTAL $: 700.02
OPERATION: 3112148 THRUST ROD BUSHINGS LEAKED OUT
325i/328i/330i/335i/335is 06/13 Both
2 BM31-12-6-763-719 HYDROBEARING 71.68 143.36
2 BM33-30-6-787-062 COMBINATION NUT 8.52 17.04
2 BM31-10-6-767-496 LOCKING NUT 9.88 19.76
LABOR $: 345.13
PARTS $: 180.16
GOG $: 0.00
MISC. $: 0.00
TAX $: 14.86
SUBTOTAL $: 540.15
OPERATION: 1142021G OIL FILTER HOUSING GASKET LEAKING
335i/335xi 07/10 A/T W/ Sport Package
1 BM11-42-7-537-293 GASKET 25.20 25.20
1 BM11-42-7-525-335 GASKET 25.20 25.20
LABOR $: 832.14
PARTS $: 87.96
GOG $: 0.00
MISC. $: 0.00
TAX $: 7.26
SUBTOTAL $: 927.36
OPERATION: 3133002 REPLACE BOTH FRONT STRUTS. L/F LEAKING HEAVY. R/F STARTIN
328i/335i/335is 07/13 Sport Suspension Both
2 BM31-30-6-775-098 GUIDE SUPPORT 160.58 321.16
6 BM31-31-6-769-731 SELF-LOCKING COLLAR 3.10 18.60
2 BM33-32-6-760-668 SELF-LOCKING COLLAR 4.08 8.16
1 BM31-31-6-786-003 LEFT FRONT SPRING ST 340.28 340.28
1 BM31-31-6-786-004 FRONT RIGHT SPRING S 340.28 340.28
2 BM31-33-6-767-333 ADDITIONAL SHOCK ABS 37.15 74.30
LABOR $: 749.80
PARTS $: 1102.78
GOG $: 0.00
MISC. $: 0.00
TAX $: 90.98
SUBTOTAL $: 1943.56
OPERATION: AFR6 REPLACE AIR FILTER WITH NEXT OIL CHANGE.
1 BM13-71-7-556-961 AIR FILTER ELEMENT 39.93 39.93
LABOR $: 53.75
PARTS $: 39.93
GOG $: 0.00
MISC. $: 0.00
TAX $: 3.29
SUBTOTAL $: 96.97
TOTAL LABOR $: 4723.35
TOTAL PARTS $: 4790.42
TOTAL GOG $: 0.00
TOTAL MISC. $: 9.00
TOTAL TAX $: 395.21
ESTIMATE TOTAL $: 9917.98
Here is a good idea, find an independant or do some of the work yourself. Over in the E-9x there are a lot of DIY's for replacing thing like air filter, and you won't be paying somebody 50+ bucks for something that takes 5 minutes or less.
Since you have all the part numbers, you can purchase it for about 15-20% less at most of our forum sponsors, like RM European AP, just plug them in and I think you will be suprised at how much of a mark-up that dealership is putting on those parts.
Or you can look around at like Amazon.com and get quality filters like Mann for about 1/2 the price that the dealership want. Do some homework and research the parts.
Darin
Current:
Past:
79 525 euro Green/Green RIP
M-Flight Member
Get recommendations for independent BMW shops (indy) in Austin from the local chapter of the BMWCCA. Every chapter has a website.
Yeah, that's crazy, but it's just dealership markup and labor rates.
Good pads are around $100 per axle and a set of rotors should be around $350-400 tops.
Set of tires mounted and balanced, will run about $1k.
Oil & filter, air filter, cabin filter - about $100.
Set of plugs, maybe $50
The trans seal and struts, you may want to have an independent mechanic do if you're not up to it.
PM me for info on properly working AC and CEL for your S54 or M54 swapped car.
First of all, subtract $1600, because someone added the brakes in twice.
Get your tires from TireRack, have them shipped to a TireRack installer, and you'll get better tires for much less money. Buy yourself some W, Y, or Z rated Michelins or Continentals.
Unless the tire wear is distorted, like the shoulder being bald, there's really no reason for an alignment.
Buy polyurethane control arm bushings from Bimmerworld or Turner, and you'll never need bushings again.
Go to an excellent BMW-specialist independent shop - Austin will have a dozen (likely more than Dallas or Houston!). Your work will be half the price.
I think I could install a complete set of 4 Yellow Bilstein HD struts & shocks on your car for the price you've been quoted for 2, using all new OEM hardware and mounts, at the Euro independent where I work.
So why isn't the fuel pump free? Wasn't this under extended warranty?
I have never really figured out why the factory says the OFHGasket on your car takes so much time; but as a pro, I admit I like that, because it helps make up for all the jobs that don't pay enough.
Chris Powell
BMWCCA 274412
TOTAL GOG $: 0.00
TOTAL MISC. $: 9.00
TOTAL TAX $: 395.21
Jezzzuzz Kryst!
That is literally money you can spend down paying for a brand new M5 with first month payment! This must be BMW's secret for selling a lot of new cars.
Roughly 50% of BMW's are leased, so that is one reason for a rather extensive "used" market, which most people don't take care of those cars.
I wonder why you revived a 5 year old thread?
Darin
Current:
Past:
M-Flight Member
The brakes are insane! The OE kits for front and rear are only like $400 on FCPEuro and ECS Tuning. $100 for the air filter too lololo
5 year old thread.
Brakes listed twice.
Yes, BMW labelled parts are more expensive than OEM.
That said, when you go to an independent, you are usually charged dealer list price on parts.
You can always find someone cheaper than the dealer, or cheaper than a BMW specialist independent.
Best of all, if you have experience and the appropriate tools, do it yourself.
Or, take it to a chain store like PepBoys, and let them use garbage Chinese brakes and tires and struts, and have a kid who doesn't know his ass from a hole in the ground do the work.
Chris Powell
BMWCCA 274412
