Matt Cramer
1997 BMW 328i convertible, 1972 Chevy C10 pickup, 1966 Dodge Dart slant six
BMW - where "Why doesn't everybody build cars the way they do?" meets "Why can't they build a car the same way everyone else does it?"
who offers the best pricing for the AEM Infinity? Also, does anyone know if a harness PNP is available for m50?
So I've been thinking this over and over after selling my EMS-4 for roughly what I paid for it.
It's between the Infinity 6 with 9 Analog Ins and 9 outputs (I'm guessing some are hardwired like the bigger Infinity's, no wiring schematic released ATM) and Infinity 8 with 17 Analog ins and 12 outputs.
Basically I can run the engine with the Infinity 6 and do a little datalogging inputs (oil press, EGT, drivetrain temps, exhaust back pressure, brake pressure frt and rear etc), but things get pretty tight on inputs the more and more I look at it. The full blown 8 of course gives me more than enough capabilities to do anything I'd want to do on my 4 banger and more.
So I guess it comes down to what I envision the usage of the standalone being. It can be something like a factory ECU that maybe monitors one or two other things and is easy to change engine parameters, or it can become a more full blown datalogging tool for a track car - which explains the brake pressure sensors. I think I'd rather pay the extra $700ish to get the capability to do the later without running out of inputs/outputs (more inputs really).
What's everybody else's take on it? Do you want to get a standalone up and going as cheap as possible to run the engine and that's it, or slowly add more sensors and have something that can really monitor everything going on with the car?
This would be a pretty simple decision for me for MY car... I'd for got the bigger/better one.
Yea, I'm really leaning that way as well. But $700 to "justify" spending on other stuff sure sounds nice too. Track cars are freakin' expensive...
It depends on the software for datalogging. Some dataloggers are set up better to overlay all the track related data it seems. When looking at track data you don't need to see all the engine parameters. Of course on your log you can just highlight what ones you want to compare in the viewer too.
If the ECU can do everything its nice to have it all in one unit. Unless you get crazy with chassis based sensors running everything from the ECU is the most practical choice.
True, I believe track map data would require an AEM AQ-1 and a bit more hardware. Not impossible, but the outlay is starting to grow when talking about that.
I do have a STACK dash with predictive lap timing that's a pretty good real-time tool for driving improvement on track.
The main thing with some more sensors on the car is just generally knowing what's going on with it. I know it's one of those things I'm not going to be checking my diff temp every time I go out after looking at it a few times, but until you have that data it's a big mystery. When you do have the data it then becomes a "well that was obvious" 99% of the time. But it establishes a baseline.
That's the only way I think I can be happy with the Infinity 6 is having a couple of "temporary inputs" that I cycle sensors around to various parts of the car to establish baselines and get a better understanding of the entire system.
Sounds good to me, thats what I would do. Unless you are really competitive in a class, you dont need all the available sensors.
For a track day hobbist, its all about learning about the car and having fun. Besides, you can run a few track days for the cost of all the additional sensors for a full chassis setup
I'm an instructor, so track time is pretty cheap, just me getting slung around by n00bs.
I figured all the "nice to have" sensors would amount to around $250-400ish(4x thermocouples, about 5-6 extra pressure sensors). To put it in perspective, that's only 2 tires... not much (yea, it's an expensive hobby...).
That said, the Infinity 6 doesn't save an absolute ton when I look at the additional sensors. I talked to a friend and he was pushing me to get the more $$$ system... as I do like to tinker. I'm going to really list out needed analog inputs and go from there. I was thinking the outputs would kind of constrain me, but looking at it again it'll probably be fine with the 9.
I went with the overkill option just a couple months ago. I did it mostly for troubleshooting and failsafes.
I noticed today (probably been there for a while) that AEM has a set of setup and wiring instructions specifically for the E36 M3:
http://www.aemelectronics.com/engine...-downloads-92/
Jeff | '94 BMW Alpina B3 | '06 BMW 325XI Wagon
I was meaning multi axis accelerometers, yaw sensor, damper travel, ect for a chassis setup
Which some of those could be used on the Infinity, but for the accelerometer and GPS position I'd need the AQ-1 which is about $420-440ish full in (box and harness). Not impossible to fit into the budget, but I'm not exactly sure it's all worth the cost... The Infinity and AQ-1 should be able to talk to each other over AEMnet, so it'd be possible in the future if I really wanted to.
Which thinking about it... supposedly the AQ-1 and Infinity 6 could be daisy chained together. That'd give me plenty of analog inputs to play with (9+4), an accelerometer, and the ability to add fairly cheap GPS module for track mapping.
Maybe that's a smarter decision... go with the Infinity 6, and add the AQ-1 to get an "inbetween solution," as far as inputs go, but then have an accelerometer and the ability to add GPS to the mix.
These are a few new Infinity features and accessories out for all the track guys out there (GPS/vehicle position module) is SUPER helpful at the circuit!
I've been using the Infinity ECU's now for a while both on street cars and strictly track cars, amazing plug and play e46 M3 options and not a bad price point if i don't say so. Last E46 i tuned on Infinity: https://brewedmotors.com/blog/bmw-m3...-ems-and-etune
Old thread. As an update, I went with an Infinity 506 (used to be just Infinity 6). It's got plenty of I/O for how much time I actually want to pour over data. I'd rather just wrench on it to be honest.
I've been really happy with the system, absolutely no complaints, and all the failsafes really do save your ass. Had a binding EFR WG actuator when things would get hot, and it saved me from repeated overboost that I couldn't even see on my boost gauge (yep, that's how quick this thing will come back into boost!).
Money well spent, I'd make the same decision today.
I have an infinty ECU on two of my cars and have tuned about 12 of them now and I love them. Incredible control and the ability to do everything I want.
Attention TURBO LOVERS, Great book -----> How to turbocharge and Tune your Engine
Favorite Automotive Tuning Articles on the Internet: Engine Tuning Articles
My Car: Custom Build Lotus Super 7
Yea, the infinity is nice. I need to get back to making things work. Life has a way of getting in the way but I can give it a thumbs up.
For $100 bucks go with a 6 and pick up 2 more user outputs.
Anyone has experience with Infinity 8 on S54? Waiting for the cams to come in, and Ill put my AEM in use finally, after a year of hibernation. Just looking for advise on how to move the peak torque more towards the 5.5k-6k rpm, and I expect my peak hp to be at 8200 or around there. It`s my track car and I have no use fo power down low while on track paired with a 4.10 diff
There is a plug and play for the s54 I think. Allot of the IO is over CAN I believe.
Thanks fellas!
I`m using custom equal pressure headers 3-1 @ 2.5" Y section 2 into catted 3.5" to the back. I think it`s fairly large exhaust. I will report back once I have the cams installed and do the first run on the dyno
