1996 332IS
Built 3.2
Technique Tuning 80# tune.
1/4 mile 10.84 @ 136.72
WWW.CESMOTORSPORT.COM
1996 332IS
Built 3.2
Free bump for a quality piece.
Up
1996 332IS
Built 3.2
Up
1996 332IS
Built 3.2
Have any left? I need the 3.5"
No problem.
1996 332IS
Built 3.2
1996 332IS
Built 3.2
Have full stock of 3" 3.5" And 4" testers available.
All $69 shipped.
1996 332IS
Built 3.2
69.69$?
1989 535i - sold
1999 M3 Tiag/Dove - sold
Mine has worked great Butters. So happy I got one when I did. Thank you.
Now available 3" , 3.5" and 4" in stock.
1996 332IS
Built 3.2
Just received my 3.5" from Butters. Piece looks great, I benched it myself and it held with no issues!
1995 M3 coupe GTX3582R powered
2011 M3 sedan ZCP
Did you say you could make one to fit all three sizes? Or would you? I should say. But I'd like one with all three size options if you would sir. Big props and thanks for all of your contribution the boosted BMW scene here.
pm sent for 4"
Current Moneypits: e36 m3/4/5 turbo techno violett - bagged V70R wagon
1961 bagged Cadillac deVille - IG @bryang513 - project 'merica e30v8
Bump as I made some more of these. They are a little different from the original as shipping was killing me due to weight of the steel units. So, I'm making them out of Aluminium now. Have 3" and 4" available. These will not have the silicone. You just adapt to your silicone coupler.
Here is a foggy pic of a 3" one. Can do them for $50-55 shipped depending on location. Since I don't know what compressor fittings people are using, I'm including fittings for that as well.
Sent from my E6782 using Tapatalk
1996 332IS
Built 3.2
Should be included with every tune purchase
1989 535i - sold
1989 535i - sold
My boost leaker tester flies out the silicone boot at 15 PSI, like a rocket.
Busted my nose open but was glad I has no leak
Im interested please PM me.
