I built a bunch of these a little bit ago. Great to test for boost leaks, also will work on a non F/I car, testing for vacuum leaks.
Silicone adapter is 3 in inside diameter (E36 throttle body is 3 inch outside diameter).
On a turbo or supercharged car with a 3 inch air filter, remove air filter. Connect silicone adapter to intake pipe. Connect regulator to air compressor, and slowly (turn dial) and pressurize intake system to roughly 20-25 psi. Once pressure stabilizes. (Will take a min or so) grab a squirt bottle with soapy water mix, and spray down entire system. Bubbles = leaks. You will find small bubbles around throttle body
1996 332IS
Built 3.2
Technique Tuning 80# tune.
1/4 mile 10.84 @ 136.72
WWW.CESMOTORSPORT.COM
Does the unite come with the valve also ..
1996 332IS
Built 3.2
Bump for a sweet looking product. Good job Butters I may pick up a 3.5" or 4" version of one of these soon
1996 332IS
Built 3.2
1996 332IS
Built 3.2
Paging frank....
Very interested in a 4" tester, have any available?
1996 332IS
Built 3.2
I am definitely going to need one! I will PM you soon. Thanks
1996 332IS
Built 3.2
next week. Im getting one! that is my bag baby!
Up
1996 332IS
Built 3.2
Bump cause Cragg56 is hogging the entire section. ; ) with good reason.
1996 332IS
Built 3.2
I've got a great turbo kit that someone could buy along with this to put this to good use.
1996 332IS
Built 3.2
Get one of the most amazing pieced together turbo kits to date FREE!! with the purchase of one extremely expensive boost leak tester
Payment sent! Thanks!
1996 332IS
Built 3.2
PayPal sent
Diagnosis pending.
1996 332IS
Built 3.2
