Results 1 to 25 of 50
Thread: Sunroof will not open
    Feb 2002
    Northern Virginia
    2000 Z3 M Coupe
    As the title states, my roof will not open but the motor operates as normal. Have any of you experienced this? If so, can you tell me what part has failed?
    Thanks.
    2000 Z3 M Coupe
    Apr 2012
    Houston, TX
    2002 M Coupe
    Quote Originally Posted by Motorsport3 View Post
    As the title states, my roof will not open but the motor operates as normal. Have any of you experienced this? If so, can you tell me what part has failed? Thanks.
    My first coupe had this issue, so this could be what's happened to yours.
    The sunroof motor is mated to an assembly with two plastic lifting arms inside, and one of those arms broke causing the glass to stop lifting even though the motor still worked.
    Not sure how it broke or if that's the only possibility here, but it's what came to mind.
    Sent from my iPhone using BF.com
    ___________________________________
    Always looking for my next
    ///M Coupé...
    Aug 2013
    San Francisco CA
    00 Imola E/S TS M Coupe
    Sunroof Delete to solve the problem?
    Feb 2002
    Northern Virginia
    2000 Z3 M Coupe
    Nah. I'm part of that small minority that digs the sunroof vent. I definitely have to fix it.
    2000 Z3 M Coupe
    Jun 2010
    Toronto
    2000 M coupe
    I have the same problem. Only one side of the roof gets pushed up when I try to open the sunroof. The other side doesn't move, causing the sunroof to twist.
    I think the solution is to order a new set of sunroof kinematics (p/n 54108410693) and replace the broken slider system which is independent from the motor.
    Apr 2012
    Houston, TX
    2002 M Coupe
    Quote Originally Posted by BIGSOOJ View Post
    Hah, it worked out that way in my case.
    ///M Coupé...
    Feb 2002
    Northern Virginia
    2000 Z3 M Coupe
    Quote Originally Posted by Swaybars View Post
    Thanks!
    $230 poorer but at least I'll have my vent back.
    2000 Z3 M Coupe
    Mar 2012
    Chicago, Illinois
    2000 BMW Z3 COUPE 2.8
    The part is hard to find. Hopefully you have luck.
    Sent from my Lumia 928 using Tapatalk
    Feb 2002
    Northern Virginia
    2000 Z3 M Coupe
    Quote Originally Posted by 2santiago View Post
    Already ordered.
    I won't have it until April though.
    Already ordered.
    2000 Z3 M Coupe
    Mar 2012
    Chicago, Illinois
    Until April? Ouch. Where did you order from?
    Houston
    S54, S55
    Where? I've been waiting for this part from Turner for about 1.5 years
    Feb 2002
    Northern Virginia
    2000 Z3 M Coupe
    I ordered through BMW of Atlanta.
    2000 Z3 M Coupe
    2002 Smurf Hearse
    Curtis, had the same issue on my Coupe. As stated already, it's the kinematics. The arms of mine were fine, it was the rotating rod that broke and separated from the arm on the passengers side. I had picked up a used sunroof, so I just had to swap over the kinematics. It's a nuisance, but not particularly hard. Watch out for those blasted E clips that hold the kinematics to the glass. They fly like the wind, and are tough to relocate.
    jeremy [AT] coupecartel [DOT] com
    1 of 1 | 2002 Laguna Seca Blue/Black M Coupe | LK61201
    "I don't know the key to success, but the key to failure is trying to please everybody.."
    Feb 2002
    Northern Virginia
    2000 Z3 M Coupe
    Hopefully mcoupemindy will have another Z3 fix it day this year and I can tackle it with the help of folks who are in the know.
    2000 Z3 M Coupe
    2002 Smurf Hearse
    If your comfortable with DIY, you can tackle it. Just take your time. I can walk you through what I did, if you like. Shoot me an email if so.
    Feb 2002
    Northern Virginia
    2000 Z3 M Coupe
    Quote Originally Posted by Jeremy View Post
    As soon as the parts are delivered, I will take you up on that.
    2000 Z3 M Coupe
    Feb 2002
    Northern Virginia
    2000 Z3 M Coupe
    Back to the drawing board.... sunroof kinematics (p/n 54108410693) are available again and now cost $700
    http://parts.bmwofsouthatlanta.com/p...108410693.html
    SHIT!
    2000 Z3 M Coupe
    Jul 2004
    Houston, TX
    36 Cylinders
    SHIT!
    You still got yours at $230? If not, you should find some of the forum members dismantling a few coupes, in the classifieds section.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Feb 2002
    Northern Virginia
    2000 Z3 M Coupe
    I've sent an email to see if they would honor the price advertised when I ordered. Something tells me my email will go ignored.
    2000 Z3 M Coupe
    Houston
    S54, S55
    $700??
    Considering sunroof delete option.
    mcoupemindy's Avatar
    mcoupemindy is offline Senior Member BMW CCA Member
    Supporting Vendor
    Jan 2005
    Haymarket, VA
    '99 M Coupe
    Wholesale is >$600 for that part number. I just checked. Supply and demand rule these parts.
    Oct 2007
    Canada/Germany
    E30 M3|ACS S3|Hartge H5S
    I would think that if you ordered & rec'd confirmation at that advertised price and were just waiting due to backorder they should have to honour the price as ordered/sold. Keep on them about it.
    Quote Originally Posted by bmxmett318 View Post
    FYI: On my 95 M3 I run an AFE intake and my car sounds like "Chewbacca." lol
    Feb 2002
    Northern Virginia
    2000 Z3 M Coupe
    I can't believe it. It's done and I will have brand new sunroof kinematics today. Because I placed my order on 2/9/14, Get BMW parts.com honored the price of $191.54 + 15.90 S&H = $207.44!!!
    Current price of kinematics... $652.78 http://www.getbmwparts.com/parts/200...t=Slide%20assy
    2000 Z3 M Coupe
    Oct 2007
    VA
    00 Mshoe
    Supporting Vendor
    Jan 2005
    Haymarket, VA
    '99 M Coupe
    That's awesome.
