Page 5 of 6 FirstFirst 123456 LastLast
Results 101 to 125 of 136
Thread: M50 turbo project finsihed
  1. #101
    Manchester, N.H.
    96 332IS 6466 turbo
    Quote Originally Posted by chris72798 View Post
    I wanted like 600-650 hp. You think that can be accomplished with a good enough gasket?
    or gasket spacer i should say and 93 pump not e85. e85 isnt easy to get for me
    600-650 can be done with CES cutring and spacer, stock internals, and water/methanol system.
    1996 332IS
    Built 3.2
    Technique Tuning 80# tune.
    1/4 mile 10.84 @ 136.72
    WWW.CESMOTORSPORT.COM
  2. #102
    Jan 2016
    NJ
    1993 E36 325i Sedan
    Do you really think meth is a must? I don't have a problem with meth just wondering.
  3. #103
    greenville, nc, usa
    Turbo E36, V8 E39
    With pump gas i would def say meth is a must.
  4. #104
    Jan 2016
    NJ
    1993 E36 325i Sedan
    Thanks so much for the help guys. You've been great help, really appreciate it. So glad I will be able to make the power I want with out breaking the bank too bad.
  5. #105
    Jan 2016
    NJ
    1993 E36 325i Sedan
    One more question for you actually. The SC61 is a journal bearing right? I have someone I know selling I believe it may be the same turbo he didn't give me any specs other then a journal bearing precision. I've heard some horror stories about them and don't know if I want to buy it from him or go with a ball bearing. Also don't journal bearings make less power because there not as easy to spin the turbine?
  6. #106
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    600-650 rwhp seems like a lot from a 2.5L on pump gas plus meth. Maybe with a larger turbo, but then you have more lag.
  7. #107
    Manchester, N.H.
    96 332IS 6466 turbo
    Yeah, my statement is for a 3.2L.
    1996 332IS
    Built 3.2
  8. #108
    Jun 2005
    New England
    Awesome car man looks great. Kinda jealous at the moment. I have an honest question for you and anyone else who turboed an m50. I have a 93 325i that I plan on turboing in the next few months. I was planning on doing s52 cams, arp head studs, and mls gasket. What's is the most amount of power I can crank out of it with that little motor work? Oh and I also need to rebuild my vanos as well but that's just maintains work.
    I think chris72798 has a 93 325i with 2.5L M50TU. S52 cams, 0.140 MLS and a whole lot of boost might get 600-650 rwhp but not sure a whole lot of boost goes well with pump gas plus meth. Maybe. The little motor won't make much torque so the rods are not so much of an issue. I would think a big turbo would be needed, which means response would not be so good.
    Seems to me like nicely built 3.2L are making 650 at 25 psi on pump plus meth with midsize turbos like 6266 or GTX3582R. A bigger turbo should do it with a few psi less, but also with less response. Put the bigger turbo on a little 2.5L and it would be an all top end car with a small power band.
  9. #109
    Jan 2016
    NJ
    1993 E36 325i Sedan
    Yes it's a 2.5. And I don't mind a big turbo it's not a tra me car just a fun weekend car
    Eventually I may 3.2 swap it but not at the moment
  10. #110
    Jun 2013
    A Beach in Fl, US
    Z3 Turbo Ferrari 328gts
    I have a SC61 for a spare and it's twin ball bearing with the big shaft.
    2001 Z3M S52 OBX T4 Top Mount, GTX3582R T4 1.06, 66MM Compressor, 3 Inch IC Pipes,HPX, Wiseco 8-1, Ported Head, Carrillo Pro​ Rods, CES Cut Ring, 3.5 Exhaust, ARP, Big FMI, Turbonetics Gate Fender Exit, 2 Walbro Pumps, UUC 6 Puck Ceramic, Aluminum Flywheel. With working A/C.
  11. #111
    Jul 2013
    Tacoma, WA
    E36 M3 turbo, E90 M3 ZCP
    How is the F1 stage 4 holding up in this car? I didn't see anything about swapping clutches, or did I miss that. I didn't think it would hold this level of torque...
    1995 M3 coupe GTX3582R powered
    2011 M3 sedan ZCP
  12. #112
    greenville, nc, usa
    Turbo E36, V8 E39
    Clutch is holding well. Only had the stage 3 with stock dual mass flywheel and pressure plate t he first go round, but with chromoly flywheel and stage 4 I've had no problems
  13. #113
    greenville, nc, usa
    Turbo E36, V8 E39
    Finally got that new (to me) turbo on, downpipe is currently getting o2 bungs welded.
    Sent from my SAMSUNG-SM-G920A using Tapatalk
  14. #114
    greenville, nc, usa
    Turbo E36, V8 E39
    Borrowed my buddies lightweight wheels for springfest. Motegi mr120 18x8.5 et 20, 18x9.5 et32. The precision turbo feels alot better than those janky 50 trims, just need to retune a bit. At first i was seeing 15-14afrs at wot, added fuel from 3k-7k and got them down to 13-12afrs, haven't had time to dial it in better, just dont get into boost. Cruising still 14afrs. 20psi to come soon. Now to decide on methanol......
  15. #115
    greenville, nc, usa
    Turbo E36, V8 E39
    Dialed in my tune, or should i say street tune, and hit 20psi last week😆, seeing 11.5 afr at wot. Taught myself how to brake boost in 2nd doing 30mph, and now i want a 3.23 lsd
  16. #116
    greenville, nc, usa
    Turbo E36, V8 E39
    Quote Originally Posted by nryee530 View Post
    Nice, did you use the 2.5 or 3" DP with that manifold?
    I started out with a 2.5 dp, but now im running a 3". Theres enough room to run one, just had to massage the strut tower a little more
  17. #117
    greenville, nc, usa
    Turbo E36, V8 E39
    Finally got an lsd put in from a 95 m3, so swapped output flanges and driveshaft, easy install!
  18. #118
    Vancouver, B.C., Canada
    '97 M3
    Quote Originally Posted by usherboy83 View Post
    Finally got an lsd put in from a 95 m3, so swapped output flanges and driveshaft, easy install! Sent from my SAMSUNG-SM-G920A using Tapatalk
    Did you replace and loctite the LSD carrier bolts in the diff? They have a tendency of falling out and killing the diff, especially on the '95 3.15:1's.
  19. #119
    greenville, nc, usa
    Turbo E36, V8 E39
    Quote Originally Posted by chikinhed View Post
    I did not, for now, but i upgraded the front bolt lol. I plan on doing a full reinforcement and bushing job, but i needed to swap the diffs in a real time pinch, but thanks for the heads up, ill get that done, should take no time.
  20. #120
    greenville, nc, usa
    Turbo E36, V8 E39
    Finally finished my wheel refinish. I found a set of z3 style 19 fronts 17x7.5 et 41 for $100, then a couple months later found a set of e39 style 5s, 17x8 et 20 with 2 wheels bandly bent for $100. So i decided to make a staggered set. At first i was going to use the style 5 faces, but decided to do style 19s instead. Style 5s are everywhere.
  21. #121
    greenville, nc, usa
    Turbo E36, V8 E39
    Got some photos of the car set for Springfest, the one big show i can make each year and a couple on the raggedy mobile dyno. LTW rep wing, bbs style 19s installed, and raced my cousin in laws tuned 08 gt500 on the way back home.
    Vid sucks, and the music got distorted when sent thru messenger. Turn vol down lol.
    https://cloud.tapatalk.com/s/59a922ab...2062627415.mp4
  22. #122
    Oct 2016
    Philadelphia, PA
    E36 2JZ
    Your car looks gorgeous bro. The video makes me wish we had straight open roads like that here in the Northeast. Nothing like enjoying a job well done 👍
  23. #123
    greenville, nc, usa
    Turbo E36, V8 E39
    Quote Originally Posted by JOutterbridge View Post
    Thanks. Its still a work in progress.
  24. #124
    greenville, nc, usa
    Turbo E36, V8 E39
    Moved the wastegate to get a better downpipe. Now, to find a fabricator since mine quit his job and cant be found.
    Her current look. Shes down for a few changes and routine maintenance.
  25. #125
    greenville, nc, usa
    Turbo E36, V8 E39
    Before front lip change
