99.999% of the time, images missing from posts is due to the image no longer existing on the host site. This can be caused by the host site purging the image, or the person responsible for the image removing it (often forgetting they'd posted it elsewhere) while organizing their hosted images, or if the host site moves images around giving them different URLs than what they used to have, or some other odd occurrences.
I wasn't aware there is more than one interface (other than mobile and desktop). Please explain what you are referring to, how one accesses this alternate mode, what the advantages are, and what the disadvantages are (other than apparently not being able to copy and paste photos)?
Thanks. I looked up BBC and read all about it. Pretty straight forward, but looks like work to code something in. I switched to the standard editor, and am using it as I write.
I still appear to be able to simply copy an image and paste it in (this one from my Picasa account). What am I missing here (ok, besides photographic artistry)?
What you're describing simply isn't possible. Are you sure you're not copying the image URL (completely different from copying the image itself) and pasting the image URL into an image insertion widget?
I just tried what you describe and it's not happening. You might have a browser plugin or something fancy that lets you do this?
No, I just right click on the image itself, select "copy image," and then right click on my post where I want it to be, and select "paste."
Voila--this one is from Google images. I'm using Firefox and the only plug-in is AddBlocker Plus (highly recommend). Seems to work every time and no matter which computer I'm using (home, work, laptop).
Point at the first icon, the "A". If it says "Switch to Source Mode", then you're in WYSIWYG mode. This setting seems to override the default settings in the user panel.
/.randy
No me gusta.
'02 M Coupe, Estoril Blue on Estoril
'02 M Coupe, -???-Who knows-???-
‘02 M Coupe, Alpine White on Black
'06 M Coupe, Interlagos Blue/Black Carbon Leather
’99 M3 Coupe, Technoviolet/Black
’04 VW R32, Reflex Silver/Black Cloth
The load times are getting worse, I think. Terry, do you know if the powers that be are working on this problem?
I don't know but I'll snoop around for other complaints. To make sure I understand the issue, the slow load times are only when uploading images to BFC forum, correct?
Terry
Stuff. I got stuff.
I hope this is not considered off topic. One persons sig link always sets off my computer virus protection. Has that happened to anyone else?
So I just went over to the Testing forum. I uploaded a 209K image, as a thumbnail, almost instantly but saving the post was slow. Is this the issue or is it when actually attaching the images?
Thanks,
Terry
Stuff. I got stuff.
The slow attachment loading is one of six issues described in detail in post #7.
As an example, try post #1458 here which has an image attached. Click the thumbnail to load the image. It should take less than 1 second to load, certainly less than 2. Start counting. When you pass 2, you know you have a problem.
To test again, try the attached image in the next post. Again, start counting.
Both images are 800x600 compressed jpegs. They should take milliseconds to load. If they load in less than 1 second for you, it's because you have them cached in your browser already. Go to post #14 to find attachments you've likely not cached. Time those.
Seven seconds to load on my desktop. Won't load at all on the tablet app.
No problem here, but then I don't allow Microsoft products on the net here. Got a pointer to the sig in question? Send it in a PM if you want to keep it non-public, and I'll dig into it.
/.randy
4 seconds on iPad over local wifi.
T
Edit: I found two similar sized images and they loaded in 14 and 3 seconds. They should have been about equal.
Ben, how much of this is relative to the host server used? If it takes having BFC use a different server, pretty confident that ain't happening.
T
Stuff. I got stuff.
I would expect the BFC host server is the one being used when pics are attached to the post. I think part of Ben's point is that the default now is to attach to the post, and this is potentially overwhelming the BFC servers. It seems to me the load times just keep getting slower for viewing images that are attached. To be clear, this does not seem to be a problem on embedded links to external hosts.
Ok, I am finally getting it. Using that icon is the problem. We need an IMG icon or the QUICKIMG icon moved to the front page without needing to select Advanced. Seems a reasonable request, I'll see what the opinion is with admin.
BTW, I NEVER use that icon, always type IMG commands or use QUICKIMG icon.
Terry
Stuff. I got stuff.
It's also the default behavior of that icon that is an issue. It should default to not hosting the file. Not attaching images.
As for "moving" it. I don't think it needs to move (personally). It seems fine where it is? If you use the Standard Enhanced editor, it's right there where it always has been. Those using the Standard Base editor, and the WYSIWYG editor, I have no idea where it should be. I've never used those for any real length of time.
Ben,
I really think the majority of our community isn't just stabbing at the first/default because it's first. I'm not quite convinced swapping those choice's locations will meaningfully reduce forum-hosted photos. Education is the key, get everyone signed up to reliable hosting services and get them comfortable using them.
Terry
Stuff. I got stuff.
I dunno, Terry. Before the Great Software Update of 2013®, one could still attach images. Hardly anyone did, though. Now it's the default behavior and image attachment is used much more. I have a hard time believing that changing it to the default and the dramatically increased usage is a coincidental and not causal relationship.
This is coming from someone who actually likes the change; I just don't like the excessive load times.
