Results 1 to 25 of 34
Thread: Euro s50b32 e36 vs us s52b32 e36
    NY AZ
    E36T, V8 E53, E70 D
    NY/FL
    '08 G35S, '98 M3/4/5
    Nice! Honestly im not surprised at the results either. I used to be dead even with my friends euro s50 swapped e30.
    Infiniti G35S Turbo BMW M3/4/5 Ninja ZX6R 636
    Penn State University '08...better than your school since 1855
    Sigma Lambda Beta International Fraternity Incorporated
    UTI Class of '10, BMW "STEPchild"
    Acurazine.com Mod Squad
    Jul 2012
    Huntington Beach
    96 M3 Coupe
    Good runs, 2nd race seemed more representative of what I expect would happen more consistently, looked like you might've jumped a hair on the first one.
    Looks like the S52 is making more torque, you pull ahead on the hit each time and then maintain your spot. Pretty impressive considering you also have the taller diff.
    @M3AMI
    96 BG/Magma Lux
    Mods. Lots of Mods.
    NY AZ
    E36T, V8 E53, E70 D
    well power to weight my car has the advantage
    Nov 2007
    Northeast
    Car
    The difference taking the hit makes!
    Nice races, I'm assuming you have a passenger too?
    NY
    skateboard
    What gearing did the euro have, and is it a properly maintained example?
    ― George Orwell
    NY AZ
    E36T, V8 E53, E70 D
    it has a 6 speed with a 3:51 , and yes well maintained
    NY
    skateboard
    Quote Originally Posted by omarmarji View Post
    How much lighter is ur car? The only way you win is if the driver sucks at life. Even driver and even weight you would lose every time ..... Weep Not over my words
    ― George Orwell
    NY AZ
    E36T, V8 E53, E70 D
    no rear seats and brides upfront for me. he had a passenger but still, onlyway he would pass me is when i run out of gears
    Hawaii to Las Vegas, NV
    '06 4Runner| 77 930| E36
    sick! i always wondered what i would have done with stock euro motor car. sedan FTMFW!! i know your car should be close to 28XX lbs which helps!
    Powertrain: Big Bore 87mm S50| Boost Logic Gen 2 Mani | BorgWarner S366 | CP 8.5:1 pistons | Eagle Rods | O-Ringed block | Tial 50mm | Precision 46mm | LINK G4 standalone | ZF| F1 stage 3 clutch/15lb ltwfw| UUC Black TM/E| Vorshlag MM's | 3.23LSD w/AKG race bushings| AKG race subframe bushings| 'Bear Motorsports' Re-enforced subframe | Walbro 525lp fp| VPD pulleys| 4'' DP into 3.5 straight pipe"||
    Handling: FK konigsports| '95 M3 strut mounts| Rogue Engineering RSM's| UUC RTAB's| 20mm front spacers| 2915lbs Full interior
    Aesthetics: M3 bumpers| 18''x 8.5/9.5 BBS LMs| ZKW's| 50w 6000k HID| Smoked Corners| 50% wndshld/5% all around| M3 sedan seats F&R| Black headliner| Black/Grey suede door panels| ZHP knob| M3 steering Wheel|
    NY
    skateboard
    Hrrmi so you most likely are lighter by 200l-300lbs plus he had another human in the car. Makes sense
    ― George Orwell
    NY AZ
    E36T, V8 E53, E70 D
    but i had casper in the car with me :/
    May 2012
    NY
    05 RSX-S
    I think the second run shows the camera car is definitely the faster car, it just seems to lose steam on the shifts....I wanna say the winner here is really because of the driver, even from a roll it matters.
    05 RSX-S - 2XX/1XX - All Motor/Xenocron Tuned - YonkersRacing - 12.94 @ 111.29 Drag Radials ​#3beep40rollcrew
    Manchester, N.H.
    96 332IS 6466 turbo
    Quote Originally Posted by Yonkersracing View Post
    Barely. Unless Corky
    1996 332IS
    Built 3.2
    Technique Tuning 80# tune.
    1/4 mile 10.84 @ 136.72
    WWW.CESMOTORSPORT.COM
    NY/FL
    Idk, it looks like the second run was a legit example of Omars car being faster. Hit it at the same time and the camera car never passed or caught him.
    May 2012
    NY
    05 RSX-S
    Quote Originally Posted by Da Infammus 1 View Post
    He would pull him while in the gear tho and then fall back on shifts, IMO.
    Not trying to take anything away from Omar, I like his car.
    May 2012
    NY
    05 RSX-S
    Lol
    Outer Heaven
    '92 TRM E36 / '05 325ci
    Custom ring gear? Never heard of a 3.51 in 212, 210, 188 or 168 rings.. If custom ring gear, PM ME! I'll give you free diff parts. Good ones, too. You're right with each other. He'd beat you like little orphan annie, if he were running a six speed and a 3.51 with an S50b32 to your 3.38 paired to an S52. The six speed is irrelevant to the gearing matter. The only difference is sixth is an over drive gear (.82), compared to the USM ZFs. Euro Ms with S50b32s and manual transmission ran 3.23 210mm ring gears. No ring gear comes to mind in the 3.5x range, actually.
    He'd have more power AND shorter gears than you. Your car would be quicker with a 3.51, if it existed, right? It looks like he has a 3.15 or 3.07, based on the way you are hanging together. Probably a 3.15 if he has a full interior and a passenger.
    NY AZ
    E36T, V8 E53, E70 D
    not sure whats the dea with his diff buts its a 3.51 lol but yea he had full interior and passenger. im nearly gutted, his car will only pass me once i run out of gears. i bought slicks so we will try this again from a first gear and from a dig
    Outer Heaven
    It's not a 3.51. If it were a 3.51, the above video would mean that his S50b32 is making less power than you, even with a 4-5% increase in torque he gets from running a 3.51 to your 3.38. That and BMW nor ZF ever supplied a 3.51 for any bmw diff case.
    You take the same car. Yours is a little lighter, but you have longer gears and less power. He's running a 3.15. Ask him what he runs for speed at 3k in fifth. Otherwise, you have a super E36. It can beat euro dual vanos M3s with shorter gear ratios. It's ass-backwards lol.
    NY AZ
    E36T, V8 E53, E70 D
    it def doesnt have the 3:15 gears in it, gearing would be way to long...
    SD, Cali, USA
    1995 M3, 1985 745i , S13 240sx sr20det
    As in corky thatcher? Are you even old enough to have watched that show?
    95 BMW M3 Alpine-
    <GO...JIC Cross Coilovers- UUC RCAB, AKG FCAB, Rogue Engineering TM bushings- AA Gen3 Exhaust- Dinan F&R Strut Bars- Dinan F&R Sway Bars- X-Brace- Mishimoto Rad- BBS RK 17x8"- TRM Chip- Dinan BBTB- DIY CAI- JP Performance Headers- 21.5 injectors- JB Racing Flywheel- Bimmerworld TB boot- 540i MAF><SHOW...OE euro clear exterior lights- Depo w/ HID- Hurricane Alcantara interior- Stereo (Kenwood,Sony,MB Quart,Rockford Fosgate,JL Audio)- Black kidneys- Euro 3 Spoke- ZHP Knob- AutoDim Mirror>
    Manchester, N.H.
    96 332IS 6466 turbo
    Quote Originally Posted by CMG View Post
    Unfortunately I am. No worries, life goes on.
    1996 332IS
    Built 3.2
    NY AZ
    E36T, V8 E53, E70 D
    am i old enough? lol
    Feb 2012
    Huntsville, Alabama
    2007 BMW 335i Sedan
    It does. Those were the wonder years
    335i with a PT5858 stuck on it.
