Hello everyone,
I'm new to this forum.
So I decided that my e60 2006 needs a CIC. Got a used one from a e70. Fitted it, all went well. Now I'm running into an issue with ncs expert. I managed to change build date to #0909 and add $609, $6VA to VO and FA_Write to CAS and SG_Codieren CIC. Now cic shows the correct vehicle info(from e60, before it showed e70), but theres no sound. I know that I must also code LMA, but heres the problem - after coding CAS and CIC I can't read vin/fa no more, getting error: Vin Faulty, COAPI-2062, ERROR_INCORRECT_ECU_LEN. Did I fck something up?
Also my cic is has a sirius radio, should I be adding a extra $ code to VO?
Update: That error was from low battery.
Still no sound from radio/cd/pdc. Changed CIC from top_hifi to hifi, didn't do the trick.
What else need I code to get sound?
Any help would be appreciated.
Mark
