Results 1 to 4 of 4
Thread: Tail light gasket replacement
    Aug 2013
    Florida
    Coupe
    Well, I noticed that I got some slight water leakage after some heavy rain here in FL. The culprit seems to be the tail light gaskets. I was looking at realoem, but there appears to be two different gaskets. I was wondering which is the correct one to seal off rain.
    Aug 2013
    Florida
    Coupe
    bump
    Lawrenceville, GA
    6 BMWs.
    Where is the rain pooling? It's possible the leak is at the antenna grommet and/or 3rd brake light gasket. I've very rarely seen the tail light ones fail.
    1996 323iT, Montreal Blue/Anthracite cloth, M Sport
    2000 Z3 M Roadster - Titanium Silver/Imola Red/Black
    2004 330Cic - Steel Blue/Gray, Sport
    Aug 2013
    Florida
    Coupe
    Quote Originally Posted by amancuso View Post
    It's definitely the passenger side tail light. You can pull the bulb assembly out and see water. Antenna and 3rd brake light are ok. It pools up in the little compartment on the passenger side. Where the slip in storage thing is.
    I might just take it apart, clean the dirt out, silicone the gasket back to the light, and gummi-pledge (spelling?) every seal. Or, i might find a damaged seal.
