Given the price of a new SAP, valve, and hose, I would definitely be interested in looking at this for my M62TU.
S54 swap DME flashing - $100
S54 swap CAN interface board (for proper A/C & check engine light) - $275
e36 SAP sim/secondary air pump simulator: $75 - standard or $170 - plug & play
e36 post-cat O2 sims: $115 shipped, plug & play
This is awesome!! PMing you about a simulator for my wife's e39 with an M54
I am interested, please PM me
02 M5 (less than 45k miles), 09 328, 07 X3, 10 MB C350, '02 530 AA Stage2/intercooler, 04' 330, jaguar 3.0AWD
All PMs replied.
I can build a sap sim for any e39. I just need to know if each of the pre-cat O2 connectors has the large letter A, B, or C on it and the wire lengths. This is a M62 diagram someone else made - http://e36-electronic.com/photos/wirelengths.png
I don't need a diagram, just the lengths, and (for plug & play) the O2 connector letter.
Pricing is the same as E36 sims.
Received my sensor already, looks like excellent craftsmanship.
To anybody looking to do these to an E39 540/M5 with SuperSprint headers, make sure you get the longer wire length at the o2 sensor end.
Stancing is for drivers trapped in an abusive relationship of their own lives.
Question about the Vacuum valve the the exhaust hardlines run to, can it be deleted?
Im am specifically talking about #7-1
http://www.realoem.com/bmw/enUS/show...diagId=11_6092
Can I delete all that vacuum line, I have had the SAP deleted with ebay headers for over a year and im sure it throws a code, but that isnt a concern to me.
ALso where does the vacuum line #19 go?
Thanks.
Part #7 must remain electrically connected but can be disconnected from vacuum. If you are getting rid of the hard line (#10) I'd suggest a vacuum cap in place of part #9. You could also replace #4 with a cap and get rid of all vacuum lines running to the solenoid valve.
I believe #19 goes to the fuel pressure regulator.
2003 540MSPORT #861/1265 -GF71249 .Black Sapphire Metallic/Sandbeige.Dinan intake~M60 manifold
Spec racing stage 2+ clutch and custom light flywheel .M5 rear LSD 3:15~M5 driveshaft ~Rogue Octane SSK
36K ENGINE SWAP!!!.~Rogue thrust arm bushings~Rogue studds~Dinan strut bar
EIBACH front/rear sway bars with BEASTPOWER brackets~CDV delete~Redline fluids/Racing blue Ate~ APEX EC7 RIMS SQUARE 18 x 10's~M Pararallel rims 9.5 all around~285 30 18 rears~265 35 18 fronts~ENKIE 18x10's square with Continental Slicks 275's square~RE 11's, 595 RSR's~BC racing coil overs 8k/6K~Steel braided brake lines~Powder Coated valve covers-A1 headers 100 cell cats, performance resonator and 4”cross tips, CUSTOM BBK - MASSIVE HATS AND BRACKETS - AERO-6 WILDWOOD-, ANODIZED CALIPERS STAINLESS STEEL PISTONS THERMAL TREATED, CUSTOM WILDWOOD ROTORS 14.50”
For anyone else who would like to do a SAP delete for their M62tu and live in Georgia: I purchased the simulator from gpeterson on here and it works great. I did my emissions inspection today and passed no problems.
I was kinda worried about the emissions test, but all systems were showing ready for inspection on my scanner. Everything went well.
Hope this helps others in the state make a decision if they're getting insufficient flow codes for their SAP system, possibly from carbon clogs in the heads or just a malfunctioning SAP. I got the simulator quick and install was very easy.
Note: My car is supercharged and my wideband does read the AFR on cold starts while the SAP would be running as mid to high 11s so the engine does run rather rich until the SAP is supposed to go off.
Sent from my SAMSUNG-SM-G930A using Tapatalk
Same thing that will make you smile will make you cry. Was that a piston?
I have a patch posted for the DME that deletes SAP without an emulator if you have a K+Dcan usb cable and a computer with a little patience it is very easy to do
I like to pretend I know stuff
Thanks Zarboz. I can't delete the SAP due to strict emissions testing in my state, GA. Their computers would be looking for the original equipment on the car to be functioning properly. If the sap is deleted, it'll show as unavailable on a car that has it standard. No dice. That's why I put the simulator on it. Works well for my situation. If I didn't have to do emissions testing for my tag yearly, I'd totally just remove it and let the cel stay on or delete it as you say.
I was just sharing for other people's knowledge. I was looking for the answer and never found it for my state.
I haven't had issues in colorado emissions testing with my SAP being deleted (they also perform an OBD scan and a dyno test with widebands) It shows the vehicle as not equipped with that option using the patch that motormouth93 and myself worked on
the patch is not merely to "turn off" the trouble light on the dash but it is a little deeper than that. It changes the coding of the DME to set the car to be as if it was never factory equipped with an SAP option according to the computer
So it shows N/A rather than Unavail
Fair enough. Really can't argue with that.
They scan our VIN through the barcode out here and which seems to pull up it's options. Cylinders, stick or auto, blah blah etc. So that would still worry me. They do still scan the obd port so maybe it wouldn't make a difference as long as the dme says it's not an option on the car. I dunno.
Be honest, if I hadn't gotten the simulator I'd totally try it out. You do make a backup of the configuration prior, right?
Are you charging for it or just helping out your fellow bimmer fam?
