Page 2 of 3 FirstFirst 123 LastLast
Results 26 to 50 of 54
Thread: F/I engine oil weight choice?
  1. #26
    Nov 2009
    Long Island, NY
    67mm 325i, RAM 1500
    No oil temp gauge but uhhh no problems lol since i have an old m50 in therr i don't even change the oil its been like 9k on e85 and im really not caring.
  2. #27
    Sep 2003
    NYC
    E36 M3 stg2 S/C...& a MV
    Quote Originally Posted by E36 HateR View Post
    That's because you can take care of her with your own two hands! lol
    I stick to 10-40 all year round, just installed Oil cooler last fall but my Oil temp is not working so can't input the results yet.
  3. #28
    Nov 2008
    nnj
    Vipers, e46m
    damn u cray cray son! I'm runnin' a thermostated cooler, but not bothering with a gauge because they're ugly. I currently use the T6 in everything but the s52 (castrol instead) and really like it. The r6 loves it, so I think that is good enough for a s52t
  4. #29
    Nov 2009
    Long Island, NY
    67mm 325i, RAM 1500
    As long as you keep an eye on pressure you should be fine, obviously never beat on it when cold but i dont beat on my car until the water temp is 12 oclock with the low temp thermostat.
  5. #30
    Toronto, Canada
    E36 Turbo
    Realistically you should always go by oil temp and not by water temps, especially since the E36 gauge is buffered and reaches half well before 70 deg C.
    Plus oil take much, much longer to reach proper operating temps then coolant does. So if you're really worried about minimizing damage you should always wait until your Oil temps are correct before "beating on it" :P
  6. #31
    Nanaimo, B.C., Canada
    EuroS50B30,e83,Frontier
    Quote Originally Posted by NOTORIOUS VR View Post
    Love the Euro gauge cluster for this reason
    "There are bold drivers and there are old drivers, but there are no bold, old drivers."
  7. #32
    Nov 2008
    nnj
    Vipers, e46m
    ^ agreed, but at the same token, I think guys like e36 hater and I live by the "ehh close enough" rule of life. If the water is up to temp, then the oil is warm enough to start having some fun.
  8. #33
    Nov 2009
    Long Island, NY
    67mm 325i, RAM 1500
    Notorious i know that the gauge is buffered and i know that oil temp takes much longer to get warm unlike water. With that being said im not putting an oil temp gauge in my car until I blow a motor or a turbo due to my methods. That is all.
  9. #34
    Toronto, Canada
    E36 Turbo
    ^^ yup, I wasn't directing it completely to you. I was also just stating it for general info
  10. #35
    Jul 2013
    Pittsburgh, Pa
    2004 BMW 545i
    Mobil 1. 0w40 European is good all around for bmw 's.
  11. #36
    Austin, TX
    S13, Turbo M3
    I use 15w50 in my drift car. Hot texas heat + hot lapping and I've got 5-8psi at low idle according to my MXL logs. The 50w helps maintain some hot idle pressure compared to thinner stuff. I religiously wait until 140 F oil temp measured in the pan before beating on the car hard at all. This is always substantially after the water has come up to temp, sometimes 15+ minutes of engine running before a hard lap just waiting for all 8+ quarts of oil to heat up thoroughly.
    It's good that you wait, but the water temp gauge is a really bad indication of oil temp in general. In my black street car, I had the factory gauges, and the MXL in front of them logging. I've seen my water temp needle show "fully warm" i.e. 12:30 on the gauge at as low as 110 F water temp (which could be 50 F oil temp, or something way too cold depending on ambient temp) and stay in that position until 220 F +.
    Mike
    IG: @mikevanshellenbeck
  12. #37
    Feb 2013
    Jacksonville
    '95 M3/10 135i/95 325is
    I love t6 5w-40. It has stopped my flickering oil light and my pressure is right at 15 at idle.
    2010 135i- Space Grey/Coral/Msport-JB4 G5 ISO, Burger DCI's, wedge flash, E85
    1995 M3-AA STG1 S/C, AEM METH, Quaife 3.46 LSD.
    E36 M3s Shoot by Tommy604604, on Flickr
  13. #38
    Jun 2006
    Frederick, MD
    e39 540i/6, e36 318i
    I think I have 15w50 rotella in mine.
    1985 325 - 5 speed - LSD - M50NV - MS2/extra - AEM UEGO - TiAL MV-R - 750cc injectors - HX35 - Blunttech Manifold - 3" exhaust
    1991 318i - 5 speed - M50NV - e36 rack - Smileys
  14. #39
    Toronto, Canada
    supercharged 97 m3
    I have been using 5w50 for years...
    Insufficient funds...
  15. #40
    i go oil free, to much resistance fighting that heavy petroleum
  16. #41
    Toronto, Canada
    supercharged 97 m3
    Olive oil works well! Extra virgin, of course....
  17. #42
    Oct 2008
    Albuquerque
    a m3 on a 7675
    15w50 rotella, with factory bearing clearances.
    World record holder for a m52 stock bottom end.
    9.41@153 c4 auto 28" et streets, e34 3.64 gearset 900+hp
    E36 chassis irs world record holder 8.49@162
    Th400, e85, 7685, m50 intake 26.6 lbs of boost
  18. #43
    Sep 2008
    Toronto, ON
    6465 328ti
    I messed around with brad penn semi-syn 10w40 last year but I didn't like the lower oil pressure it gave me. I run Shell T6 5w40
  19. #44
    Manchester, N.H.
    96 332IS 6466 turbo
    Yeah, and stuff like that.
    1996 332IS
    Built 3.2
    Technique Tuning 80# tune.
    1/4 mile 10.84 @ 136.72
    WWW.CESMOTORSPORT.COM
  20. #45
    Feb 2001
    Dallas, TX
    2000 M Coupe - 2014 435i
    Unfortunately I cannot do anything about this in FI forum, but I'll forward it to Kevlar.
    -Joe
  21. #46
    SW Florida
    99-01 M Cpe & Rdts, X5M
    Yup I think that should about do it. Maybe take a deep breath and count to 10. Then edit the kaka words. ; ) you bring too much to the community to have you banned as well
    I deleted my post (with useful content) that was hacked/spammed, but that didn't seem to affect the quotes.
    I'm pissed they spammed me, but perhaps more pissed that my legitimate requests for action have been ignored.
    I'm starting to count now...
  22. #47
    is it just me or does the f/i section need more monitoring??
  23. #48
    Manchester, N.H.
    96 332IS 6466 turbo
    Quote Originally Posted by Randy Forbes View Post
    Might want to add in 5 Hail Marys and 2 Our Fathers , Randy.
    1996 332IS
    Built 3.2
  24. #49
    SW Florida
    Quote Originally Posted by cdmbmw View Post
    Too much is bad; too little is bad; but some is good.
  25. #50
    Jul 2003
    Tempe, AZ
    95' M3, 98' M3/4
    Quote Originally Posted by TheJuggernaut View Post
    I would go with the lightest weight oil that gets you good oil pressure under your operating conditions.
    +1
    Big thing is pick your oil weight to the driving you will be doing.
    Example - 202rwhp E36 M, Track only with no oil cooler. I run 10w-60 and have no temp/heat problems.
    996TT - Stock runs 10w-40 and some times 10w-50 and even in 775hp we use the same oil for daily drivers.
    Street M3 - 10w-30 or 0w-40 depending on the exterior temp.
