Results 1 to 7 of 7
Thread: S52 vs M52 flywheels
    Jul 2010
    KC, Mo
    04 M3, 02 E39, 01 46 M3T
    They are quite different, even though they WILL interchange between engines. Not sure what is different about the clutches, maybe stack height. Anyway ... PICS !!!!!!!!!!!!!
    Manchester, N.H.
    96 332IS 6466 turbo
    I knew it.
    1996 332IS
    Built 3.2
    Technique Tuning 80# tune.
    1/4 mile 10.84 @ 136.72
    WWW.CESMOTORSPORT.COM
    Jul 2010
    KC, Mo
    But SOME did NOT.
    Outer Heaven
    '92 TRM E36 / '05 325ci
    Idk why, but I have a feeling that this is why guys with stock flywheels and clutches with e36 Ms complain of resistance when they put the trans into 1st, but 328 owners do not. I figure there are a few differences beyond friction plate.
    Jul 2010
    KC, Mo
    So, after posting the pictures and before installing the ZF in a 96 M3, I took a good look at the 328 and M3 pressure plates. I had to get the box in the car, so only took a quick look at them laying on my work bench. I think the M3 unit is "thicker", and that would make sense after seeing how the two flywheels are built. It may be a stack height thing. Anyway, I will never mix/match ANY of the parts (even though the clutch plates look and measure the same.
    Mar 2004
    Brooklyn
    97 M3, 65 Mustang FB
    How are the weight differences between the two?
    Jul 2010
    KC, Mo
    Did not weigh them. A friend was with me at the time. After I picked up both of them (one is each hand) I noticed the difference in weight. I said nothing to him except to take them from me. "Holy crap!!!!" was the response. There really is a great deal less metal on the M3 flywheel, and it is taken away from where it really counts - the perimeter. I am guessing at LEAST 3-4 lbs. While it may not be apparent when you just drive around a 328 with an M3 flywheel/clutch retrofit, it would matter on a drag strip or race course as the flywheel would certainly take less power to spin up. PHYSICS !!!!!!!!!
