Page 7 of 42 FirstFirst 123456789101112131415161732 ... LastLast
Results 151 to 175 of 1041
Thread: 740i to M7 transformation - S62 swap
  1. #151
    IL
    2000 740i sport
    With a muffler delete theres no badges needed. The sound will speak for itself and have people wondering what is really under that hood...
  2. #152
    Nov 2010
    Charlotte, NC
    03 M5/05 RR/06 Cayman S
    Purplecty, that is exactly right. The muffler delete is very likely to happen, so badge-less is what I'm gonna go with.
    -Paul
    2003 "M5" - Full M5 conversion, AMG C63S 6 piston front calipers, Porsche Panamera 4 piston rear calipers, GC Coilovers,
    Eibach ARBs, UUC Evo3/DSSR, Borla Exhaust w/Muffler Delete, BMW NBT with Carplay/Android Auto, Bi-Xenons, e38 Style 37 M-Pars, e60 Hubs 530i 6-speed swap build thread
    2005 Range Rover 4.6is (M62TU Powered) - 4.6is Engine Swap from X5, BMW NBT with Carplay/Android Auto
  3. #153
    IL
    2000 740i sport
    Quote Originally Posted by blackknight530i View Post
    Its the mystery that makes it exciting!
  4. #154
    Nov 2010
    Charlotte, NC
    I had to re-read that last one Purplecty a couple of times to make sure I got it right, LOL.
    -Paul
  5. #155
    IL
    2000 740i sport
    Got a little excited myself ha...
  6. #156
    May 2010
    East Bay Area, CA
    01 Dinan 740iS, 97 318ti
    On your airbox issue. Use E38 750 boxes and horns. Unless you have to modify a lot, as the 750 box is nearly identical to what you are using and the mounting points are already there for a left air box, you will eliminate your clearance issues and have the dual air boxes.
    Can't wait for the finished product!
  7. #157
    Greenville, SC
    01 749iM/6 sporty
    Quote Originally Posted by 740iSport303 View Post
    No, its not the engine air filter boxes, its the cabin filter housings that are in the hood.
    Trevor
    01 749i sporty, build 12/00 "Sports Barge",S62
    92 VW Corrado VR6,AAA
    81 Delorean,B28F
    81 VW Rabbit Pickup 1.8T,AWW
    03 VW Passat wagon 4.0 W8 6spd
  8. #158
    Nov 2010
    Charlotte, NC
    Quote Originally Posted by 007008 View Post
    Correct. The 750 air boxes are totally wrong for this application due to them being narrower and angled towards the firewall, which will not work.
    -Paul
  9. #159
    Dec 2011
    VA
    1998 bmw 740il
    Now I feel like selling my 540i and have get M5 instead along with the 7.
  10. #160
    Nov 2010
    Charlotte, NC
    Ok, I've got another pretty good update for you guys.
    This past weekend, I got the wiring issues figured out and we were able to bump the starter using the key, but I found out that the VAG-COM cable that I have isn't the absolute perfect one that works with the bmwflash software that I was going to use to download the DME firmware in order to delete the EWS code. It detects my PA Soft 1.4.0 cable, but I have confirmed from the developer of bmwflash that it is proprietary and incompatible. So now, I've ordered a Galletto 1260 cable, which will hopefully come in before next weekend. Otherwise we would have been able to start the engine and see if it runs.
    That being said, here's what else we got done. We put the exhaust on and mated the old style cat sections to the facelifted rear section, got the O2 sensors installed and connected, installed the new stainless brake hoses, bled them as well as the clutch slave cylinder, reinstalled the fender liners, test fit the radiator, fan shroud and expansion tank, and began modifying the hood for clearance.
    I only have a few parts left that need to be installed and it will be ready for an alignment and should be ready to roll the next time I go to Alabama to work on it (likely this weekend).
    Here are some pics:
    Exhaust:
    Brake lines:
    Hood:
    The hood cuts still need to be welded up and painted, but they're definitely going to work. The cabin air filters should still work too.
    The garage cleaned up and ready for both cars to fit.
    -Paul
  11. #161
    IL
    2000 740i sport
    That is awesome! Im getting excited...
  12. #162
    Greenville, SC
    01 749iM/6 sporty
    Good job!
    Trevor
    81 Delorean,B28F
  13. #163
    Nov 2010
    Charlotte, NC
    Thanks guys! I'm so close I can taste it. It tastes like gasoline, oil and burnt rubber, LOL!
    -Paul
  14. #164
    Arizona
    2015 328i M Sport
    Oh my gosh the beast is coming alive!!!!! You have to make a first startup video for us!!!
  15. #165
    Nov 2010
    Charlotte, NC
    Quote Originally Posted by M I C H A E L View Post
    Definitely will be video of the startup. I didn't feel like making videos before, because there just didn't seem to be anything interesting enough to require video, but when we actually start it, that will definitely be interesting enough.
    -Paul
  16. #166
    Mar 2012
    Bristol, TN (ish)
    03 325xi, 01 740iL
    lookin sexy.
    Current:
    2009 xdrive35D
    Past:
    2003 325xi
    2001 740iL
    1993 740iL
  17. #167
    Arizona
    2015 328i M Sport
    I'm stoked for you
  18. #168
    Butte, Montana
    Suck
    If it were me, and I couldn't get the car to start because of EWS, in the meantime I would run power to the starter to turn the engine over to prime it. Crank it over until the oil light goes away. Much safer than just firing it up after sitting.
  19. #169
    Nov 2010
    Charlotte, NC
    I can spin it on the starter just fine with the key. Thanks for the suggestion! I'll do that before we officially fire it up.
    -Paul
  20. #170
    Oct 2008
    Mclean, Va
    2000 Bmw 750il
    Can't wait!
  21. #171
    Dec 2011
    Reading, PA
    2001 740i Sport
    Isn't the ews rolling code table stored on a different chip separately from the dme firmware? I thought that was the case with the me7.2. For the m62tu. Maybe its different for the m5 dme.
  22. #172
    Nov 2010
    Charlotte, NC
    Aright guys, I was hoping that this update was going to be the really good one, but alas, my galletto 1260 cable did not come in last Friday like I expected and I wasn't able to get the DME modified to remove EWS, but that doesn't mean I didn't do anything on the car.
    Some engine bay shots: (The hood is removed in order to do some welding to fill the gaps from our cuts and that is being done this week)
    The engine bay is pretty much completely assembled except the M5 coolant hose going to the expansion tank is a bit bigger than the 740i expansion tank, so we need to make an adapter for the hose and then we fill it with some antifreeze and she'll be ready to get an alignment and get on the road (of course after the galletto comes in).
    Interior Shots: (Cluster front piece isn't secured yet since I still need to make sure the tach needle is set correctly and I need the engine running to do that)
    She's going to need a major bath after we're done. Sport button is wired and ready to go, console is fully assembled and so is the dash under the steering wheel. I still need to run one more wire to the new DMTL leak detection pump which will need to run from the left rear wheel well, into the trunk, along the floor and all the way to the E-Box. Then I need to run two wires from the where the general module is to the E-box for the servotronic to work. The M5 DME handles servotronic rather than the GM. That's going to be a bit of a pain since the glove box is a pain to remove apparently. She's got all the wheels mounted and I think she's going to sit just a little bit lower in the front due to the added weight of the engine, but only a little since now it's a manual instead of an auto.
    This coming weekend will be a good weekend assuming my cable comes in. The seller said USPS can't find it, so he's sending me another and before I knew that, I placed an order through someone else as well. I have three chances of getting a cable by next weekend, so fingers crossed, we'll get the car on the road for some shakedown runs. Then she'll be coming home the following weekend. I can't wait for that since driving nearly 1000 miles a week since Thanksgiving is getting rough.
    Also, look for some parts to be posted in the classifieds soon. I've got an M62TU to part out as well as a good 5hp24 transmission and related ecu's. I also have a set of both pre-cats and cats for the TU, some M5 front struts/springs, M5 brake rotors (no calipers), transmission support bracket and even some used but decent transmission mounts, a stock 540i shifter, a 540i pedal bracket for pre-facelift, and a few more things.
    -Paul
  23. #173
    Jan 2013
    Warwick, Ma
    2001 M5
    Looks great! I'm sure you're chomping at the bit to get her running. Thanks again for the detailed write up, that's gonna be a blast to drive! Not sure if you ever heard of Simeon from the E38 board, he was a pioneer in manual tranny supercharged E-38's, he'd love this swap
  24. #174
    Nov 2010
    Charlotte, NC
    Quote Originally Posted by S62fan View Post
    Thanks!!! I really am chomping at the bit. I have heard of Simeon's "Baby" and it is a sweet ride and one of the cars that inspired me to do this. I always figured it was possible, but now I know it is. I hope he sees mine and comments, it would be a huge honor.
    -Paul
  25. #175
    Feb 2013
    The Motor City
    1997 750 IL
    Nice. That nearly 400HP is going to feel good!
    ---- Processing Individual ----
    Z1XX Upholstery
    Seats front and back in Epingle / leather englishgruen,
    As Schl.Nr. B9EG.
    Front seat backrest in Montana Englishgruen (No. 8 174 861)
    Other interior equipment as for Volleder Nappa englischgruen,
    Schl.Nr. P5EG
