91 850i. I can lock/unlock the glove box ok and the lower compartment opens and closes just fine but the upper compartment will not open. Any suggestions?
Thanks.
Where is the upper and lower compartment? Am I missing something in my car?
17/07/00 E52 Z8 Topasblau/Schwarz
26/08/13 F10 520i Alpinweiss/Venetobeige
02/09/97 E31 850Ci Orientblau/Schwarz (SOLD)
23/03/90 E30 M3 Diamantschwarz/Schwarz (SOLD)
Early 8s have 2 gloveboxes. The upper one was replaced with an airbag on later models.
Yeah I noticed right now. Thank you
I had the same problem with my '91.
Had to pry it open, to get access to latch mechanism, and replace broken part,(pot metal).
My 93 looks like it has the upper glovebox, I was very bummed when I found out there's an airbag there
1983 Monte Carlo SS
1984 Pontiac fiero SE
1993 BMW 850CI
1994 BMW 525I
I just accidentally bought an older '92 upper/lower glove box set off eBay, just to try and get a locking mechanism to replace my broken pot metal latch... Ironically, the parts didn't even come with the latch that I needed. But now I'm tempted to convert my airbag upper to the glove box storage (I always remembered how cool that two button double door setup was in the early '89-'90 promo videos).
It seems the dual button latch mechanism is still available and I should be able to transfer over the control ring and lock tumbler... But I have two other concerns...
First, does anyone know what ohm resistance the pass. airbag circuit is looking for if I were to install a resistor in place of the airbag? And second, in reviewing some nightmarish posts on 8'er heater core replacement (mine's fine thankfully) I see that there might be some support tubing that was added on the airbag/knee bolster cars in the USA. Will that tube block the possibility of the upper glove box installation anyways?
Thanks for any info
2006 R53 JCW (British Racing Green) - 1994 E31 840Ci 6spd (AVUS Blue)
2021 F56 JCW (Rebel Green) - 2000 E38 740i Sport (Titanium Silver)
2017 F26 X4 M40i (Carbon Black) - 2007 E91 328iT (Deep Green)
2012 E82 135i M Sport (Marrakesh Brown) - 2015 E84 X1 (Cashmere Silver)
2005 E53 X5 3.0i Sport (Kalahari Beige) - 2000 E36/7 M Roadster (Oxford Green)
2000 E38 740i Sport (Oxford Green) - 1999 E36 M3 Coupe (Fern Green)
1995 E31 840Ci Canadian (Oxford Green) - 2000 E36/8 M Coupe (Oxford Green)
2004 E46 330Ci (Oxford Green) - 2001 E36/8 Z3 3.0i Coupe (Oxford Green)
2002 E39 525i Sport (Oxford Green) - 2002 E36/7 M Roadster (Oxford Green)
2001 E53 X5 3.0i Sport (Oxford Green) - 2007 E63 M6 (Silver Grey)
1995 E31 840Ci (Oxford Green) - 2006 E86 M Coupe (Sepang Bronze)
2001 E39 530i Sport (Aspen Silver) - 2009 E92 M3 (Space Grey)
2001 E38 740i Sport (Sahara Beige) - 2008 E92 M3 (Melbourne Red)
2000 E38 740i Sport Canadian (Sahara Beige) - 1997 E31 850Ci (Jet Black)
It is easy to do, I did it to my 93 many years ago. Since most airbags get a bit squirrelly after 15-20 years, I made my vehicle an "airbag delete" car. Neither driver nor passenger airbag now in the car. The tube support for the airbag was simply removed.
'93 850Ci - Mineralweiß Metallic
2001 740iL - Titansilber
ALPINA B7 -Alpinweiß III
Very cool! Well I guess now I have a game plan! Do you remember how you got past the SRS light from coming on? I have some 3.3 ohm resistors I was going to use on my 2002 Z3 M Roadster a few years ago but ended up selling the car. Not sure if 3.3 Ohms is appropriate for E31 airbag modules...
I've also got a Euro 3 spoke steering wheel to install too, and you make a good point in disabling these 20-some year old 'bombs'.
It's even simpler than adding a resistor. I disabled the SRS light. I have the non-airbag 3-spoke M-tech steering wheel also. That upper glovebox really does come in handy.
Haha, yea I guess disabling that light would just about do it! Ironically, the 3 spoke Euro wheel I bought has it's own SRS red light on it (must have come from an early car that didn't have a dash airbag light).
So how did you disable the SRS light? nip/tuck behind the cluster kind of thing?
Aren't the materials used for the early and late models different? Does it match decently?
What "thumbs up" really means
it is but not by much, I bought a new upper glove cover and it was different from my 2 year younger model but it did fit the same after a few hot summers.
The upper I got from a 91 matches the lower material on the 93 perfectly.
Mines didn't for some reason, It's just a little off in the pattern, Cost me over $200 for the lid itself.
