As I have time I am posting links to said products. I am trying to "spread the wealth" with vendors. Not making it easy as some vendors carry the same product. I will not hunt down the best pricing. It will be the viewers responsibility to take it from there.
1996 332IS
Built 3.2
Technique Tuning 80# tune.
1/4 mile 10.84 @ 136.72
WWW.CESMOTORSPORT.COM
This thread has beaucoup potential...
thanks.
97 BMW M3 (s52b32) - VF-Supercharger kit ( Vortech V2-SQ supercharger, 32 pound injectors, VF tuning ), VDO/LeatherZ Gauge Kit (Oil Temp, Oil Pressure, and Boost), UUC Motorwerks RSC36 Exhaust, Stainless Steel 6-2 Exhaust Headers, Bilstein Sports, Rear Adjustable Camber bushings, Wheel Spacers 10mm in front 25mm in back, Uprated Clutch, UUC Shift Knob, Short Shifter and Clutch Stop, Cross Brace, Mason Engineering front strut bar, Contour Wheels, Euro Ellipsoid (Angel Eyes) HID Headlights, braided steel brake lines, aluminum thermostat housing, mishimoto aluminum radiator and silicone hoses and a partridge in a pear tree
Well done.
I thank you for thinking of this and having the guts to originate it as it is a thankless pursuit, except not from me because I know what it is like first-hand so I salute you. You will not be able to please everyone and asking for members to give their own input from the get-go is a very smart move on your part.
Looking forward to this thread developing.
1996 332IS
Built 3.2
Great and helpful thread. Much appreciated.
I would like to have a brief discussion on the different (Grades) of bushings used.
If we could get some feed back from those with experience with 95a 75a etc .
Real world experience on track and street would be great.
Also if anyone has any regrets on a bushing they installed. Ie "I wish I didnt install solid engine mounts on my DD"
1996 332IS
Built 3.2
If it helps, I'm currently running powerflex black bushings on the rtabs and subframe bushings. I believe the black bushings are the 95a equivalent its been a long time since they were installed so I'm not 100% sure. When I purchased these I was told by TCDesigns that they had problems with the purple powerflex bushings on both street and track cars and advises against he purple ones.
So far, from my experience, I personally think that the powerflex bushings are great. I have quite a bit of track time on them and personally dont find the increase in nvh to severe for the street (but now a days my car doesn't see much street time).
One regret I have is that I didn't know about about the vibra-technic engine mounts that Sniz did a write up on sooner. I'm currently running poly motor mounts with the factory heat shield, and as far as I can tell they have are working out, the nvh isn't bad just as long as they aren't over torqued, but I believe the vibra-technic mount would be a better mount.
i'll post up my personal experience based on Dyno Dynamics results 515 WHP / 760 WNM
ENGINE/COOLING/FUEL SYSTEM
Stock M52 Rods
ARP M52 Rod Bolts
Stock M52B28 Pistons
Stock M52B28 Crank
Iron block
stock Head
stock M50NV Cams
*Lowering compression via thicker headgasket.
-Cometic MLS .098
*Head studs
-ARP 2000s
http://www.cesmotorsport.com/documents/94.html
*Fuel pump
-Walbro 255
*Cooling system
-stock e46 radiator
-Stock e46 electric fan
TRANSMISSION/CLUTCH
*Clutch
-stock m52b28 pressure plate
-custom single mass flywheel
-4 pad ACT clutch disc
- transmission S52B32 (US E36 M3)
CHASSIS
*rear subframe, RTAB reinforcements and mounts.
-UUC
*Diff support aka DSB
-custom made, bracket / mount for E36 diff on E46 chassis
At what power level would you say cams are needed
I have akg 95a fcab on my e36 that's a daily, love them,
Has anyone used the AKG front diff bushing with the 14mm upgrade ? I'm thinking about doing this . Over the summer I snapped a Diff bolt @ the strip. Needed to drill it out and I'm not happy with the results. I could transfer over the internals to a spare case I have. Or I could drill/tap for 14mm. This would be much stronger and matched with a MaxPSI style brace it should be never a problem again.
The 14mm upgraded bushing is only offered in 75a or aluminum.
I was hoping to run 95a bushings to match the subframe bushings I just picked up
Link to bushings.
http://www.akgmotorsport.com/catalog...ion%2FBushings
1996 332IS
Built 3.2
Why would you drill and tap it? I drilled mine straight through and put a 1/2" bolt and nut on that sucker. If you shear it then you don't have mess around unscrewing the piece the piece out of there, you just push it out.
Sent from my GTX3582R
Butters you need to add "fuel" what type can be used to achieve what power level as well.
1991 bmw 325I <e30>
First 8 second full body BMW with BMW independent rear suspension in the USA
8.69 @160mph in a 1/4mile on slicks.
drag radial tires record holder9.53@148. Also a world record holder for bmw overall 60-130mph 4.2 seconds.
Bistein sport susp,turner sway bars,3:25lsd,m52 AEM INFINITY stand alone. MORAN 2500cc injectors E85 ,front mount 33x12x4 intercooler, 5lug conversion M3 front,Mcoupe rear Dss axles/driveshaft ATI Proglide.
2003 Ford Expedition
1998 M3
1986 Mercedes Cosworth 190e 2.3 16v 5speed (sold)
I wanted to keep the thread to "what's needed when making XXX" . No as much "How to make XXX" . Also IIRC all levels can/have be made with 93 and E85. @ 700+ wtq 93 octane made need a splash of race gas as INS.
On the other hand, once thread is all sorted , I would love to expand thread to fuel, even turbo sizing.
1996 332IS
Built 3.2
1996 332IS
Built 3.2
