Results 1 to 25 of 44
Thread: Ideas diagnosing 850i that starts, idles for 1 second, then dies?
    Apr 2002
    San Diego
    1997 840ci
    I am going to be helping Braveheart61 diagnose one of his 850i's over the weekend (1991). As it says in the title it starts, idles for a second, then dies. The plan is to go through it as follows:
    - Stomp test
    - Visual inspection of intake / vacuum system for leaks
    - Fuses
    - Unplug MAFs and see if it goes into limp home mode (though now that I think about it, those don't usually go out at the same time do they?)
    - Camshaft position sensors
    Does anything else immediately come to mind for you V12 guys? I drive a lowly V8, so I'm probably 4-short on ideas.
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    The usual cause of running for a few seconds and then stopping is the lack of cylinder identification signals. These are provided by the inductive sensors on HT leads 6 and 12.
    My BMW Repair YouTube Channel
    Apr 2009
    Vancouver Isl, BC, Canada
    98 Euro M3, 04 M3, 06 M5
    fuel pump
    Current:
    - 09 335i MSport, FBO.
    - 98 Euro M3, Estoril Blue
    - 04 M3, Carbon Black, 6 Speed Coupe
    - 06 M5, Black on Black, Full Leather.
    - 73 3.0CS, Tagia Green, 5 speed M30b35 converted
    Ex's: 1984 325e, 1988 325IX, 1992 525I, 1995 540i/6, 2002 330i, 2005 330xi, 1992 850i, 2003 330i #1, 2003 330i #2, 2002 330ci, 2004 330ci, 2007 328CI, 2007 335i, 2001 M3, 2006 M5 6 speed
    Woodland Hills, CA
    Disco II 850i MERs 750il
    Quote Originally Posted by DanB View Post
    You're going back to 1991 to diagnose his car? Are you going to the factory? If so, would you please kick the C-pillar cover design engineer in the balls for me?
    Thanks,
    Steve
    San Ramon, CA
    850Ci, M5, Model-S P85D
    Fuel Pressure Regulator!!
    Apr 2002
    San Diego
    1997 840ci
    I will swap the leads off his parts car and see if it makes a difference, thanks for the info.
    Quote Originally Posted by legoman67 View Post
    fuel pump
    Need to know which relay to bridge for this and where it's located.
    Quote Originally Posted by m6bigdog View Post
    Will check.
    Quote Originally Posted by bruinbro View Post
    Thanks,
    Steve
    Sure, I'll run the red exhaust tip idea up the flagpole while I'm there.
    Update; INPA stored errors:
    Ti-signal 7-12th cyl
    Throttle valve servo motor 1-6th cyl
    Any ideas what the ti signal is? I assume throttle servo is idle control.
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    ti-signal is the injection time signal, the base timing is derived from the cylinder identification signal.
    Apr 2002
    San Diego
    1997 840ci
    Roger that, thanks Timm
    Replaced throttle body on bank 1-6 with known good one, replaced cyl 12 wire with known good one, no dice.
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    Is it still running for a second or so and then fizzling out?
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    We had the same problem this weekend on an 850. Exactly as Timm said: lack of cylinder identification signals. In our case the ignition wire boot of cylinder 12 was lose/not connected to the spark plug.
    Before we checked the usually subjects like fuel pumps, fuel pressure, ignition = distributors+rotors, crankshaft position sensors.
    Apr 2002
    San Diego
    1997 840ci
    Problem solved - bad fuel pump. And the tank was full... Thanks for the help guys!
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    That's good news!
    Apr 2002
    San Diego
    1997 840ci
    No tea around here, so time for a cup of beer.
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    Don't you V12 boys have a fuel pump per-cylinder-bank as the 750 boys do?
    Apr 2002
    San Diego
    1997 840ci
    I dunno, this is my first time working on a V12. I just went for the one under the right side rear seat.
    Mar 2013
    South TEXAS
    1993 850CI
    same symptoms I experienced on my 93 850ci. my car went nto lhm then died... car would start then die.. changed my fuel pump assy (passenger side $400+) . car started but still on LHM. stomp test gave me 2247. was thinking it was sensor but trned out to be a bad plug wires (#7 and #9)
    daryl
    1993 e31 850ci Diamond Black
    1996 Mitsubishi 3000gt VR4 Pearl green
    1997 Mitsubishi Pajero LS Intercooler Grey
    1993 Nissan z32 300zx Twin Turbo Pearl White
    1991 Nissan Sentra GXE (Sedan) Pearl blue
    Sep 2013
    Commiefornia
    you're going back to 1991 to diagnose his car? Are you going to the factory? If so, would you please kick the c-pillar cover design engineer in the balls for me?
    Thanks,
    steve
    rofl
    WOW
    Big Thank You Dan!!!!!!!!!!!!!
    Hell with the Tea, Ill bring the Tequila
    Apr 2002
    San Diego
    1997 840ci
    Quote Originally Posted by Braveheart61 View Post
    rofl
    WOW
    LOL! It was a group effort. Hopefully there's a LOT to celebrate today.
    Gary C is swinging down again, should be fun!
    Dec 2007
    Texas
    91-Dinan 850TT
    yes
    rofl
    WOW
    Now we're talkin'
    Jan 2005
    Japan
    Not all, the E38 750 V12 with the M73 only has one fuel pump, the E32 750 with the M70 V12 has 2 fuel pumps.
    Mar 2011
    Liberal Loontown, CA
    Cool Volvo, Ugly BMW
    Thanks,
    Steve
    This. Brand new pillar and no way to install. I think they put them in before the glass. I've decided.
    What "thumbs up" really means
    Apr 2002
    San Diego
    1997 840ci
    Quote Originally Posted by toomanyparts View Post
    Jackasses!
    Edmonton AB
    850i
    Damned car has been giving me the kinds of ulcers that only 8 owners can really understand; doing the exact same thing as initial subject, fires, runs for a couple seconds if that then dies.
    Thanks to this forum and all of it's threads, I was able to summize that it is quite likely the fuel pumps. Wasn't really looking there as it smells horribly of fuel and I had already replaced them just a couple years ago, good friggen reliability there for sure, NOT,
    A special thank you to the forum member who suggested jumping a wire (with car off) from fuse 23 to 30amp fuse 25, then 24 to fuse 25 to see what's what with factory fuel pump wiring and what not. Very helpful diagnosis tool, very helpful indeed, makes perfect sense and a guy's thinking, shit why didn't I think of that; alas, one cannot think when all they want to do is put a stick of dynamite underneath a car and a piece of crap Peake Tool that's........ well,... that's another rant.
    Thanks Gents
    Jul 2014
    oklahoma city
    bmw 840ci
    hi
    i need help please
    my car 850i manual 1991 run really rough and it die checked the fuel pumps and both working replaced 2 cid sensors 2 crank sensors cap , rotors and spark plugs and i still have the same issue ?
    my codes are 16 CAMSHAFT POTION SENSOR for both sides and when ever i clear the codes and start the car the codes come back at ones ?? and the car die ?
    sometimes the car start normal like V12 but it start to stall then die and some time passenger side work and drive side shut off and when i turn it off and start it again the problem go to passenger side ?
    please i need help
    what i am missing here
    i order 2 coils still waiting
    do i have to order new spark plug wires ?? ecu , dme , wire harness ????
    i love the car and i want it back to be normal
    please any advice
    thanks
    ryan
    Sep 2008
    Santa Barbara
    91 Dinan860 & 91 850 6sp
    the car is telling you what's wrong, the CID sensors...
    You sure you have them plugged into the right plugs?
    You sure they are actually any good? Bad "donuts" have been a common problem with some replacements...
