Page 3 of 10 FirstFirst 12345678910 LastLast
Results 51 to 75 of 226
Thread: Big Single 2JZ E36 M3
  1. #51
    Jkpgt96's Avatar
    Jkpgt96 is offline One of those JZ swappers BMW CCA Member
    Jul 2012
    St. Louis, MO
    2JZ 95 M3
    It is the pan and all parts associated with the pan. You can buy rear sump conversion kits.
    1995 M3 - Forged 9.8:1 2JZ, S366, MS3x, E85, LQ9s, 420g/PMC Motorsport kit, 4 clutch 3.15 LSD Large Case 757whp/710wtq
    2011 X5 Xdrive35d- Blk on Cinnamon, Towing Pkg, Heat Pkg., etc..the tow rig/DD!
  2. #52
    Sep 2012
    Mia
    99 e46
    Quote Originally Posted by Jkpgt96 View Post
    So the one ill need would b the rear sump , if not it will get in the way with the front cross member?
  3. #53
    Jkpgt96's Avatar
    Jul 2012
    St. Louis, MO
    2JZ 95 M3
    Amongst other things. Yes, get a rear sump.
  4. #54
    Sep 2012
    Mia
    99 e46
    is there a car where i can take the oil pan off and fit the 2j?
  5. #55
    Oct 2008
    West coast
    '00 540 6.0/4L80e/S480
    Lexus SC300?? They have n/a 2JZ and seem to be plentiful in wrecking yards.
  6. #56
    Ft. Lauderdale, Fl
    E36 M3, Mk2 GTI
    Nope sc300 are front sump, I think only supra and aristo (not to sure) came rear sump
    MODS
    1JZ, BC 264 cams, BC TI Springs and Retainers, Ferra Keepers, Arp Head Studs, Arp Main studs, Arp rod bolts, Custom Emerald Performance Dual Plenum intake, 70 mm TB, SC6169 T3 Turbo, full 3 inch SS exhaust, Ar5 Transmission, 60lb injectors, Walbro 400 fuel pump, GTR intercooler. Porsche Turbo Calipers, Gutted Tein SS coilovers with Koni Race shock inserts , Tein Pillowball Camber Plates, UUC Swaybarbarian bars....needs more mods and a tune!!!!
  7. #57
    Jkpgt96's Avatar
    Jul 2012
    St. Louis, MO
    2JZ 95 M3
    Aristo I think is front sump also. Needs to be a mkiv supra I think. Or buy the kit online from driftmotion or the like.
  8. #58
    Sep 2012
    Mia
    99 e46
    iv heard from a friend that i can use the sc oil pan . i would have to buy it if it does not work but those kit are expensive did you have to buy this kit as well?
  9. #59
    Jkpgt96's Avatar
    Jul 2012
    St. Louis, MO
    2JZ 95 M3
    You can usually find them used online. Search te supra pages on fb or the supra forums.
  10. #60
    Nov 2013
    Miami, FL
    95 e36 95 e34
    Sc300 uses rear sump, gs300 front sump, supras rear sump, thats from what ive seen. I'll try to take pics as soon I can, been busy at work this month!!
  11. #61
    Sep 2012
    Mia
    99 e46
    Quote Originally Posted by turbopimp View Post
    Yea that's what I heard but I'm also going to look into the forums aswell..Bro you live in miami what part???
  12. #62
    Nov 2013
    Miami, FL
    95 e36 95 e34
    Dirty south! near homestead.
  13. #63
    Jkpgt96's Avatar
    Jul 2012
    St. Louis, MO
    2JZ 95 M3
    Little update on the engine situation.
    The seller is giving me almost all of the money back and i am keeping the engine to rebuild it.
    Gte rods/pistons
    Valve job
    Bc springs/retainers
    Acl bearings
    Arp studs
    Arp rod bolts
    Oem ge head gasket
    The shop will be getting a jump on the mounts and suh using another 2j/r154 they have to mock it all up in order to keep the project moving along.
    Huge relief to have the claim behind me.
  14. #64
    Dec 2013
    Queens NY
    E34
    We will not have to mod the crossmember. We are actually building the mounts ourselves. I have a set of the k's racing mounts but we are not using them because we decided to build our own and possibly make a few sets. But I have seen the k's mounts used with great success by many others.
    Sounds good
  15. #65
    Jkpgt96's Avatar
    Jul 2012
    St. Louis, MO
    2JZ 95 M3
    I'll put the ks mounts up for sale shortly. I have to make a trip out to the shop in a bit anyway if anyone is looking for a set.
  16. #66
    Sep 2012
    Mia
    99 e46
    my friend lives by 268 and naranja im going to visit him this weekend i live in broward . ill love to see your swap on
    ur car if its possible and have time can you pm me with your # maybe we go cruise the city.
    Gte rods/pistons
    Valve job
    Acl bearings
    Arp studs
    Arp rod bolts
    Oem ge head gasket
    wow that's awesome you going to have allot of extra money to play with , how come because of the paypal?
  17. #67
    Jkpgt96's Avatar
    Jul 2012
    St. Louis, MO
    2JZ 95 M3
    Guy tried selling me a junk engine..
    Should have some more pics and such next week. I am taking a few things down to the shop that is fabbing the mounts. They are thinking the mockup engine would be set in the car today to check clearances and fitment of the downpipe/turbo/etc..
    I have been collecting parts for when I get the car back from having the fab work done.
  18. #68
    Dec 2013
    Alberta, Canada
    1999 M3
    What made you build your own mounts if you already have the k's mounts?
    Do the K's mounts require further modifications for them to workout?
  19. #69
    Jkpgt96's Avatar
    Jul 2012
    St. Louis, MO
    2JZ 95 M3
    Small update. Head is heading out to get refreshed and loaded with BC goodies!
    The k's mounts are fine and have been proven to work but I am very picky and the ks mounts are just ugly and not up to par from a quality standpoint. As I said, they work, they are just not for me. Also lets us make adjustments to the mounts and fit everything together. Things like fitting the radiator, fans, shifter, etc for the custom pieces that I am choosing to use.
  20. #70
    Dec 2013
    Raleigh
    1993 325is
    yes the ks engine mounts are hella ugly both color wise and weld quality, but they are built like a tank. I'm not sure if your going to run into this problem but I had to cut a huge notch in the driver side mount for the oilfilter to fit. I didn't figure that out until motor was in the car and bolted down. just a head up. do a test fit haha.
  21. #71
    Jkpgt96's Avatar
    Jul 2012
    St. Louis, MO
    2JZ 95 M3
    Noted thanks! I was planning on an oil cooler and relocation but I might hold off on it for now. I should be play with the newer tubular mounts but we will check that for sure. Thanks!
    As I said the head was sent off today, manifold bolted on and check for fit. There are a couple mods being done to it to clean up the wastegate tube for a tial mvr versus the hks style flange it has. Also redoing the twin scroll flange and divider.
  22. #72
    Dec 2013
    Raleigh
    1993 325is
    The relocation kit was the only option I had after I found that out, so I took a cut off tool and spent two hours cutting that thick steel.
    Ks has new tubular mounts?
  23. #73
    Jkpgt96's Avatar
    Jul 2012
    St. Louis, MO
    2JZ 95 M3
    I gotcha.
    No. The new mounts I am having dabbed are tubular. At least that was the initial plan of attack. I am not personally fabbing them though. Cxracing was supposed to be working on a mount kit as well but I have not seen any sets for sale yet.
  24. #74
    Dec 2013
    Raleigh
    1993 325is
    I gotcha.
    cx racing has stepped their game up. it would be nice to see a kit come out
  25. #75
    Jkpgt96's Avatar
    Jul 2012
    St. Louis, MO
    2JZ 95 M3
    I know they are working on it. It should be done if they had stuck to what they told me about 2 months ago lol.
