Page 4 of 5 FirstFirst 12345 LastLast
Results 76 to 100 of 123
Thread: Fuel supply line removal - stuck on hard line
  1. #76
    Feb 2009
    District Nine
    sold 78 BMW 320i
    Quote Originally Posted by beaucephus View Post
    I wouldn't measure in squish. The instructions were to preset the bite ring on the tube by getting all the fittings finger tight and turning the nut 1 1/2 turns. Then the slip ring is inspected on the tubing and reinstalled with only 12 degrees (half flat) of the nut past wrench tight. I think the instructions link has the answer you are looking for. I think it is more foolproof than it seems. I hit high resistance near where I should be in both preset and final install.
    One more word of caution. The first hose the hydraulic shop put on was not EFI rated even when I stated the working pressure required. They just assumed everything they had was 300 PSI or better. If it doesn't have the pressure rating printed on the hose, it isn't right. I grabbed some Gates 225 PSI at a shop down the street and they remade the hose.
    Excellent, that's what I wanted to know - if you were able to atleast do that to inspect the bite.
    The bookmarks in my adobe reader don't work, I'll try reading it again later
    Tbd
  2. #77
    Nov 2005
    Mills River, NC
    '82 E21 320i
    Many thanks again to Beaucephus for all your leg work!
    A few clicks, one phone call and $6.06 later I have double the fittings I need! (Just in case I mess up somehow)
    Eric P.
  3. #78
    Aug 2009
    Metro DC
    79 323i, 94 325is, 13 M3
    Hey, who did you order from? I tried MROStop and they took a couple months . . . .
  4. #79
    Nov 2005
    Mills River, NC
    '82 E21 320i
    I went to www.parker.com and clicked the "Where to buy" link.
    Typed in my zipcode and picked "Industrial fittings"
    One of the businesses listed was "Cross Hose and Fittings" in Greensboro within blocks of my office.
    Monday I called to find out it's their corporate offices but they patched me throuh to the store in town.
    I read the part numbers to the guy on the phone and he said he had a couple in stock as did the Raleigh store.
    When I offered to pay by phone and pickup on Thursday he said, "Don't worry about that. We'll just hold them for you. Do you want the ones from Raleigh, too?"
    Sure! I figured extras were cheap insurance against my screw-ups.
    So I swing by there this morning on my way to the office and he has the bags waiting for me.
    The grand total: $6.06
    He probably thought I was nuts because I came bouncing in there at 8:01 like a kid on Halloween.
    Eric P.
  5. #80
    Bayview, WI
    1983 BMW 320i M20 Turbo
    I ended up using a yor-lok tube fitting from mcmaster-carr on the hard line after cutting the fuel hose off. I used the 8mm Tube OD x 1/4 NPT Female yor-lok fitting with a 1/4" NPT to hose barb fitting and sealed them together with Permatex Aviation Form-A-Gasket No. 3 Sealant.
    1999 Z3 Coupe 2.8L
    CHECK OUT >>>
    RAGE DRIFT DESIGNS <<< FOR DECALS AND MORE!
  6. #81
    Aug 2009
    Metro DC
    Yeah thanks I wound up getting those McMaster Carr fittings myself.
    But next time I know to just ask my mom to drive over from Reidsville. Or ask my uncle to take care of it, since he lives in Greensboro. You might know him, Hugh "Pumpkinhead" Williams.
  7. #82
    Sep 2015
    Atlanta, GA
    1983 BMW 320is
    looks like i picked the perfect project to tackle the weekend before the vintage. luckily, a local hydraulic shop had those parker fittings.
    anyone else tried this recently? i actually ordered the oem fuel hose (#1 in the realoem diagram). got it from my local dealership for $45 shipped. figured it would be better than trying to find that banjo fitting at the distributor end.
    so is there any shot i won't have to cut the hard line? and if i do have to cut it, will i be able to take off a small enough section that i won't have add a piece of hose to #1 to make up for the lost length on the hard line? also am i the only one who doesn't understand why everyone is advocating against heating the fitting due to the fuel present, but is in favor of cutting a metal line, which will undoubtedly produce sparks? not trying to sound like a smartass, just don't want to light myself on fire.
    as always, the help is appreciate. let me know what y'all think.
  8. #83
    Jun 2006
    Atlanta, GA
    1982 E21 BMW 320i
    Quote Originally Posted by jlups View Post
    I'm thinking you can cut the metal line with a spinning pipe cutter, which would not produce any sparks. I've wandered into this conversation with no background so I may be way off, but after you've cut the pipe end and removed the old screw fitting, you'd have to put the new fitting on and then put a conical flare on the end for the ferrule to seat in.
    Are you sure you need to cut your metal line? Two spanners and some blaster oil can't get that fuel line unscrewed?
    1982 320i E21 Coupe, Manual, Cashmere Metallic, 162K+ miles (Daily Driver)
    1997 318i E36 Sedan, Manual, Black, 388K+ miles (RIP)
  9. #84
    Nov 2007
    Sacramento, California
    1980 BMW 320i E21 M10B18
    Nice work
    Randy
  10. #85
    Sep 2015
    Atlanta, GA
    1983 BMW 320is
    Quote Originally Posted by Hagbard View Post
    I'm thinking you can cut the metal line with a spinning pipe cutter, which would not produce any sparks. I've wandered into this conversation with no background so I may be way off, but after you cut the pipe end and removed the old screw fitting, you'd have to put the new fitting on and then put a conical flare on the end for the ferrule to seat in.
    man, i'm hoping i don't have to cut it. just preparing for the worst, as we both know is typically the way these jobs tend to go.
    but even if i don't have to cut the hard line, though, the original ferrule probably won't be reusable (assuming its not fused to the end of the hard line). if i do need to cut it, though, i don't think it needs to be flared because as far as i've gathered, looks like as the screw fitting tightens, it compresses the small end of the ferrule up into the fitting at the end of the flex hose and the hard line into the larger opening at the bottom of the ferrule, squishing everything together.
    excellent idea on the pipe cutter, though. would have never thought of that.
  11. #86
    Bayview, WI
    Problem is the location of the oem hard line fitting. It does not give you enough room to spin a pipe cutter let alone a flaring tool unless you remove the entire line off the car first. I had the same problem with mine being completely seized onto the hard line, making cutting it off my only option. I used a dremel with cutoff wheel and didnt have any problems with sparks or blowing up. I did leave the fitting sit a couple days to make sure any fuel and vapors at that location had dissipated before cutting. With the correct tube compression fitting, you do not need to flare the tube whatsoever. The double ferril design of the fitting creates a leakproof seal onto the metal tube. Just have to make sure that the tube is cut perfectly flat and all burrs removed. And also make sure the screw end part of the fitting is completely seated against the tube before tightening it down onto the tube.
    1999 Z3 Coupe 2.8L
    CHECK OUT >>>
  12. #87
    Nov 2007
    Its not the gasoline you have to worry about, the liquid part will put out a match, its the vapor coming off the liquid that is burnable , forced air the tube and your good to go. Internal combustion proves that, thru compression the liquid turns to vapor or a gas form and is ignited as such by the spark plug with oxygen present.
    Randy
  13. #88
    Dec 2012
    TITUSVILLE
    1983 320i
    Hey guys, I've moved on, but needed to come back just to tell you the bubble flare is required if it was there before. These fittings are precision work. Don't play with gas. Have a fire extinguisher. Plan on YOU being on fire.
  14. #89
    Sep 2015
    Atlanta, GA
    1983 BMW 320is
    do you mean there's a flare at the end of the hard line? if so, how did you flare yours after cutting it?
  15. #90
    Bayview, WI
    He is referring to the return line that has a flare on the hard line, not the feed line that we are talking about.
    1999 Z3 Coupe 2.8L
    CHECK OUT >>>
  16. #91
    Sep 2015
    Atlanta, GA
    1983 BMW 320is
    Quote Originally Posted by bassboy3313 View Post
    i see. thanks for the clarification man. so it looks like as long as i have those new parker fittings and a new oem hose, i should be able to get it hooked up even if i do have to cut the hard line.
    thanks again for the help gents. always appreciated.
  17. #92
    Sep 2015
    Atlanta, GA
    1983 BMW 320is
    got the job finished this weekend. much easier than i anticipated. i didn't end up having to cut the fitting and when i removed the hose, the original ferrule was fused to the hard line, so i reused it. tightened it up, ran it, drove it, no leaks yet. only time will tell, though.
    the best piece of advice i can offer is to start soaking that fitting with pb blaster or wd at least 48 hours before you do the job. i gave it a quick squirt from the top about every 12 hours starting thursday morning and did the job saturday morning with no problems.
  18. #93
    Jun 2006
    Atlanta, GA
    1982 E21 BMW 320i
    Awesome work man. There's no substitute for patience!
  19. #94
    Feb 2009
    District Nine
    sold 78 BMW 320i
    Aye, good job, jlups.
    If the hard line and flex line is in good condition, fittings are tightened and it's not seeping fuel after one hour of run time, it's good.
    Tbd
  20. #95
    Nov 2007
    Cool
    Parker Store is near by stopped in got 4 ea for that day .. Nice to Find NLA parts, elsewhere. Thanks beaucephus and others. Having parts in hand is worth more than two in the bush. I see how this fits together in original condition using these pieces from Parker. I had a leak in the back hose with the same fittings and after a few minutes got it loose got it out and replaced the hose, the compression fitting stayed with the hard line and I tightened up the nut and drove the fitting in place no leaks or smell of gas. Well done beaucephus , Eric and others--Nice plane beaucephus.
    Randy
  21. #96
    Feb 2009
    District Nine
    sold 78 BMW 320i
    Success!
    Parker M08LCFX (nut) and PSR08LX (sleeve) seem to fill the gap for the NLA 07119970258 (#16) and 07119970111 (#17). I recommend getting both as they fit together better. I brought my FI hose to a hydraulic shop and had them install crimp collars on the hose ends effectively making a longer version of 13311272771 (supply hose #1) to make up for how much hard line I cut. I was able to get the line in the wheel well for a clean cut. It's pretty cramped under there. Fighting it in the installed position with a 14 and 17mm was not easy. It looks good and doesn't leak. In hindsight the EFI clamps were pretty stupid, so don't do that.
    I followed the Parker provided instructions here. They look pretty important.http://www.parker.com/literature/Tub...e_Fittings.pdf
    Attachment 488622
    Attachment 488624Attachment 488623Attachment 488628
    Assuming all is still good!
    Bump on those fuel line pieces and for future reference.
    I've not shopped from these folks, and they appear to have a bunch of the same Parker fittings.
    8 mm Tube Nut
    8 mm Progressive Ring
    8 mm fuel pipe line tube nut ::
    https://www.partsgopher.com/product/...m#.XAoDmlRKg1I
    8 mm fuel pipe line tube ferrule slip sleeve progressive ring (search friendly?) ::
    https://www.partsgopher.com/product/...r#.XAoDvVRKg1I
    *Get extras, not just enough to get the job done (ie: for test fitting, loosing, etc..)
    *And do Not forget to read the install instructions...
    Tbd
  22. #97
    Feb 2009
    District Nine
    sold 78 BMW 320i
    Quote Originally Posted by 320iAman View Post
    Randy
    Nice! I should stock up, the day for need is not far away... I looked at the "About" page on the partsgopher.com website, and saw they have many many places throughout the US, seems several not far from me too.
    Tbd
  23. #98
    Nov 2007
    Cool
    Quote Originally Posted by epmedia View Post
    I seen the post and solution, found a Parker store nearby and drove over there, they were right in bins--good idea to get these NLA parts-for that day..
    Randy
  24. #99
    Vermont
    81 320i, 98 318ti
    This post was very helpful to figure out how this connection works and I wanted to post a response. I just had that problem separating the hose from the steel pipe yesterday, supply line by the passenger fuel tank was stuck. I was replacing the hose between the fuel filter and a steel pipe with the correct BMW part. Someone in the past must have had a leak there and instead of using a proper high pressure line from BMW or make your own, they rigged it by using a standard fuel hose. I am surprised it worked at all, and it did for years, but not surprisingly there was a minor leak at the clamp. Next, I will need to deal with the same problem on the opposite side, in the engine compartment, where the plastic line going to frequency valve was patched with the piece of a rubber hose.
    Anyway, the stuck connection comes apart. At least it did in my case. WD40, vice grips on the 14mm male part section/threads of the rubber line (can be damaged as it is getting replaced anyway) and tapping with the a hammer did the job. NLA sleeve stayed on the pipe and while it spins, I do not see how it could come off. I put the new hose on it and luckily no leaks.
    So cutting or replacing the pipe may not be necessary. Tapping with the hammer should eventually get it free, given time and patience.
    Max
  25. #100
    Nov 2007
    Cool
    Mine had a leak,, No 10 Hard Plastic Line, what I did is remove all the hard plastic line and replace with fuel injection hose with two small clamps. Did this years ago--no leaks.
    Randy
