Results 1 to 8 of 8
Thread: Changing oil on EDC III shocks
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    This we did as an experiment on an E32 750iL Alpina B12. In general it is said the shocks are non servicable, but it is possible, we already had some apart from the rear and replaced some o-rings. Front shocks are a bit more difficult, but this time we welded 2 washers to the top plate and then we could lift the top seal out without damaged it like this
    http://8810.teacup.com/750hiline/img/bbs/0001321M.jpg
    http://8810.teacup.com/750hiline/img/bbs/0001321_2M.jpg
    http://8810.teacup.com/750hiline/img/bbs/0001321_3M.jpg
    Then we attached a slide hammer and pulled it out. Actually it was a dent puller as we borrowed it from a friendly paint shop which allowed us to use their shop, looks like this
    http://toolmonger.com/wp-content/upl...ntpullerlj.jpg
    In case someone is wondering why the wheel is still on (or again on), that we did re-attach to have the shock nicely secured and have power when using the slide hammer.
    The oil inside was quite dirty from >20 year or working and tiny material from the seals was found when we filtered it and it looked similar like Pentosin. We measured the drained oil and replaced it with the same volume of about 400 ml. We used oil for motorbike shock absorbers and so far so good. Were also thinking about forklift oil
    From what I have got as info from someone who is also studying this, the original fluid/oil is
    ESSO EGL 45 374 or DEA 5045 f (the f stands in a circle O)
    volume/quatity:
    The piston must be in oil up to the upper rim of the cylinder (a small amount of oil must flow into the spare/reserve area between inner and outer cylinder when closing the cylinder, but the spare area should not be filled more than 2/3 filling height. Pictures or drawings I unfortunately cannot send you. The sealing cap of the front shock probably must be destroyed, for example by heating, the inner gaskets melt. But you must keep them, as most of them you have to re-use.In case you find a good way to add compressed air, please let me know., thank you. 3 Bar
    Loveland, Colorado USA
    1993 740i
    Hi Shogun, just curious how these shocks are working after ~8 months?
    '93 740i - Mine
    '13 Range Rover Sport - Hers
    '08 Land Rover LR2 - Hers
    '96 328i - Son's
    '97 328ic - Daughter's
    '87 944 Turbo - Mistress
    '74 Alfa Romeo Spider - Italian Mistress
    Northern Colorado, USA
    Jan 2005
    Japan
    Works fine, we did it meanwhile on 3 more E32 750iL Alpina B12.
    We also found out that a slidehammer/dent puller is not absolutely necessary to do the job.
    1993 740i
    Excellent. Did you only change the oil or did you replace seals as well?
    Assuming only oil, was that enough to improve the damping?
    '93 740i - Mine
    '96 328i - Son's
    Jan 2005
    Japan
    We only changed the oil and that was enough to improve the damping.
    1993 740i
    Simple enough then. My struts seem ok in compression but are under damped in rebound, so I'll probably give this a try sometime.
    Thanks as always, hope you had a great trip.
    '93 740i - Mine
    '96 328i - Son's
    1993 740i
    Sorry to resurrect this 4 year old thread, but do you know what viscosity motorcycle fork oil you used Shogun?
    '93 740i - Mine
    '96 328i - Son's
    Jan 2005
    Japan
    My wrenching buddy has a list on his Japanese website, click in the index on EDC http://e32b12.blogspot.jp/ there are different brands listed like from Yamaha and the viscosity
    language can be changed to English on the left side. And below these are for comparison the data of Pentosin CHF 7.1 and 11S.
    In an old thread from the E34M5 forum in Germany I once posted this info, which I got from someone who researched a lot
    ESSO EGL 45 374 or DEA 5045 f ( f in is in a circle) , 11 years ago http://www.e34m5.de/board/showthread...fer-Reparatur&
    But no one can find these oils, so we too shock oil
    more pics under struts http://e32b12.blogspot.jp/search/label/Strut
    https://www.bimmerforums.com/forum/s...-refurb-shogun
    interesting youtubes for RC track oils, just for info:
    How to choose shock oil and oil weights https://www.youtube.com/watch?v=dRxIs1q9tKE
    Shock oils https://www.youtube.com/watch?v=Z16X-lKOMhw
