I drove my e34 with no 3rd gear for about 3 weeks. You get use to letting off the gas before it tries to shift into 3rd, so it then goes to 4th.
e46 m3, some 740 sport shorts, F30h, LR3 and a 540it
Ahhh.... the joys of a 5-speed. :-)
Andrew Bird
I had my trans fluid changed a year+ ago, still going fine. It was slow shifting from first. Car has ~212xxx on it, on most likely the original trans. What I had heard was not to 'flush' the fluid, just oem filter and new fluid.
my version of a midlife crisis: 20 year old spray painted, lowered BMW station wagon.
Good find! LOL
Mine wasn't that bad, was not having shifting problems but I have done 2 auto trans services w/ filters on her in the past 4000 miles. Very confident auto tragi-matic now.
That metal growth on the magnet looks scary though...
'Sweetness Tres' M44, 1.9L Z3 5-Speed Roadster '97 Boston Green 66K Smiles Mine
'Sweetness Too' M52, 2.5L Z3 5-Speed Roadster, '00 Jet Black 165K Smiles 2022 Gone Ins Co Total in Jan 2022- Right Front Collision - Paid $8850 !!
'Ol' Black Betty' S52, 3.2L ///M3 5-Speed Vert '98 Cosmos Black 265K Smiles Wifeys
M50, 2.5L 525i E34 Tragi-matic '95 Sedan Alpine White III 238K Smiles Was Daughters Mine Again
'Gretchen' M30, 3.5L 535i E34 Tragi-matic '90 Sedan Glacier Blue/Indigo 144K Smiles 2018 Gone & I miss her
'Sweetness' M44, 1.9L Z3 5-Speed Roadster '96 Boston Green 264K Smiles Was Mine Ins Co Total in Jan 2013- Rear End Collision - Paid $4800 !!
update .... This tranny is still going strong. lolololz.
93 E34 525I Slushbox
83 GMC C1500
84 GMC K3500 3+3
10 Subaru Impreza w/ hail damage
Cool. It's outlasted many people in the thread!
Has it still got the strange 2-3 shift?
'98 740iL E38 201k, TCG at 190k, 5HP24 at 195k
'97 540i/6 E39 Dinan blower & stage 1 suspension 114k
'93 525i E34 "Golf Ball" (hail damaged) 334k
83 GMC C1500
84 GMC K3500 3+3
This thread is funny. Missed it in 2013...I did a auto trans service on the touring shortly after purchase...(about 30k miles ago) and it still shifts like butter. I read thread after thread trying to arrive at a decision on changing the fluid. I have been sitting on a 5 speed swap since before I owned the touring anyways...so even if it died, I would still eventually win...I finally said 'f it' and changed it expecting the worst. Here we are over 2 years (of hard driving) later and it is still giving me zero issues.
So for the next guy contemplating changing the fluid, and reading forums posts all night long: just do it. If the tranny is already dying, you are screwed anyways...
+1
My transmission had all the signs of failure. When I did my flush I drained the old fluid, dropped the pans and cleaned them, filled it up with cheap Napa fluid, drove it around for an hour in the city, then dropped the pans again and cleaned them again, changed the filters, and filled up with royal purple.
Personally, I think flushing all the crap out of the transmission, with new fluid, is the trick.
83 GMC C1500
84 GMC K3500 3+3
I must be the exception. Same symptoms, same attempt to revive via flush, filter, and fluid change. Tranny puked a couple of months after. 5-speed is better now though
1992 525iT, Manual Swap, Bilstien Sport struts, H&R springs, Style 32 17" wheels (17x8 fronts, 17x9 rears), ACS exhaust, Euro cluster, Wilwood SL6R BBK on E38 rotors
the propensity for these transmissions to crap out after being flushed is confusing to me. There is no reason, i can think of, that would lead a transmission to failure after getting all the crap flushed out of it and filled with new fluid.
The only explanation, in my feeble mind, is the transmissions that do fail after a flush were beyond saving to begin with. I can only surmise that the transmissions would have failed at the same interval, or sooner, had the the flush not been done.
83 GMC C1500
84 GMC K3500 3+3
From my years as an auto tech, I never did much transmission work other than flushes but I heard from many veteran technicians that if the fluid in an automatic transmission hasn't been serviced in normal intervals, it's best to not flush it due to varnish buildup from the worn fluid. Basically from what they were saying, the new fluid kind of "cleaned" the surfaces of the transmission and when this varnish would circulate it was harmful to the internal parts. I'm no transmission expert but this is the only explanation for this phenomenon I have.
clicked over to 250k .... this car wont die.
83 GMC C1500
84 GMC K3500 3+3
With the flushed auto? Impressive.
I had a Pathfinder that I was trying to kill because it was dropping 5 pounds of rust with every drive. So I stopped changing the oil. Three years later I finally gave up and gave it to someone else. And that's when I bought my first e34.
demet
yup. im too cheap to fix a transmission that is still mostly working. the only problem the transmission has is the slightly harder than normal 2/3 shift and the reverse pause (which it has had since i bought it in 09).
i literally cannot kill this car and i have tried. Though i did just have to put in a new pass front brake caliper (seized after sitting for a few months) and a new alternator.
83 GMC C1500
84 GMC K3500 3+3
Agreed. No reason to fix what's not broken. But it doesn't hurt to have AAA platinum just in case.
demet
83 GMC C1500
84 GMC K3500 3+3
