Results 1 to 13 of 13
Thread: Bluetooth DB25 to 54-pin ULF adapter
    Dec 2008
    Plainville, CT
    2003 540i M-Sport (6 spe
    I have a DB25 to 54-pin ULF adapter that came with my used Bluetooth kit. It was used on a 2000 M5 but it wasn't needed for my 2003 540i because it already has the 54-pin connector pre-wired. This adapter is required to connect the Bluetooth ULF module to your car.
    This is a home made version of the OEM BMW adapter cable, part # 84120308375. For E39 prior to 03/2002, E46 prior to 03/2002, E38 after 09/2000, E53 prior to 03/2002. (Please verify compatibility yourself). The OEM adapter cable currently retails for $45.
    Asking $20 shipped for this cable.
    Tony
    1998 SVT Contour (B/MNB) #542 3L
    2000 SVT Contour (SF/MNB) #1533
    2003 BMW 540i M-Sport (6 spd)
    2002 Lexus IS300 SOLD!!
    Nov 2007
    Scottsdale AZ
    2000 E38 740il
    Quote Originally Posted by CSVT1214 View Post
    I have a DB25 to 54-pin ULF adapter that came with my used Bluetooth kit. It was used on a 2000 M5 but it wasn't needed for my 2003 540i because it already has the 54-pin connector pre-wired. This adapter is required to connect the Bluetooth ULF module to your car. This is a home made version of the OEM BMW adapter cable, part # 84120308375. For E39 prior to 03/2002, E46 prior to 03/2002, E38 after 09/2000, E53 prior to 03/2002. (Please verify compatibility yourself). The OEM adapter cable currently retails for $45. Asking $20 shipped for this cable.
    I have a production date 11/2000 m5 where can I get the blue tooth module other than the cable you are selling
    Dec 2008
    Plainville, CT
    You can find the ULF Bluetooth module on eBay, from Bimmernav.com, or from the dealer. The best place to pick one up is on eBay. Bimmernav.com has the newest generation (13th) of the module which is not available in the US but it retails for $600. If you buy new from US dealers, they are only allowed to sell the 1st generation module which was problematic. eBay will have used modules at a much lower price and give you the option of finding something newer than the 1st gen.
    You should stick with 4th generation or higher. The older versions had problems with pairing and sound quality.
    Tony
    Dec 2008
    Plainville, CT
    bump
    Tony
    Dec 2008
    Plainville, CT
    bump
    Tony
    Dec 2008
    Plainville, CT
    Bump
    Tony
    Aug 2016
    Moscow, Russia
    e39, e83
    Thumbs up
    Bump
    Still not sold?
    I need one!
    Feb 2017
    Southern Ontario Canada
    2001 325i Sedan
    Is this sold yet?
    I am interested in this.
    Thank you.
    Feb 2016
    West Palm Beach, FL
    2003 BMW 540i M Sport
    OP - I have the same car and I’m looking to put in Bluetooth ulf. Can you PM me the part numbers for what you put in? I don’t have PM privileges yet. Thanks!
    Feb 2017
    2001 325i Sedan
    Can't be too hard to snip the 54 pin part out of a wreck and bribe some poindexter genius to solder one up can it?
    The 54 pin part seems to be the hardest part to find.
    Any takers?
    I will send pop and chips and whatever it takes to get the job done!
    Aug 2016
    Moscow, Russia
    e39, e83
    Lightbulb
    Stuck my retrofit on this stage too.
    Luckily indeed there are lots of ULF modules sold ripped with 54-pin cable tail, like this one:
    https://71.img.avito.st/640x480/4994694471.jpg">
    the second connector, DB25 is a standard retro PC-cable.
    And here’s the final pin-out for this adapter:
    https://a.d-cd.net/owAAAgD6UOA-1920.jpg">
    Full retrofit article:
    https://www.drive2.ru/l/507322912466796927/
    Aug 2019
    Dana point
    Bmw
    Im interested for this adapter so please get back to me with more details
    I'm interested for this adapter so please get back to me with more details
    Aug 2020
    Chattanooga
    2001 740i, 1998 z3
    Quote Originally Posted by alishahna View Post
    I would like to purchase your 54 pin adapter. Please let me know how to purchase.
    Charlie
