Page 4 of 5 FirstFirst 12345 LastLast
Results 76 to 100 of 104
Thread: Blunttech / Classic Daily S85 V10 E30 M3 Swap
  1. #76
    VA
    E63AMG/Z31/Tacoma/F31
    +1!
  2. #77
    Michigan
    70 '02 / 85 557e
    Not a huge update but something none the less.
    We had found some rotors that were going to work for the brake setup but they were not ideal. So we got some hats from Ireland and then had some rotors made custom from coleman eng.
    Here are the rotors when they showed up.
    Fronts
    Starting to mock stuff up
    These are just sorta stuck in there...if you look to the left of the caliper it looks like they are hitting the wheel. The caliper is nut but there is a washer in there to keep the caliper clamped to the rotor. There is room all around.
    clearance between wheel and caliper
    rear rotor....nothing that exciting here.
    [img[https://lh5.googleusercontent.com/-DqJ97ieM94Y/U77S8FHKt_I/AAAAAAAAMIU/xwqWJID7drY/s640/IMAGE_1830.jpeg[/img]
    rear compared to front
    www.classicdaily.net
    1970 m42 swapped 2002
    1985 LS1/T56 Swapped e28 (557e)
    Follow me on Instagram for constant build updates @classicdaily
  3. #78
    VA
    Daddy needs a new pair of shoes
  4. #79
    Feb 2013
    Hamilton, Ontario, Canada
    1992 BMW 525i Sedan
    Wow what a cool engine swap. If you guys crack the DME will you be releasing any relevant information?
    1992 525i/5
    Quote Originally Posted by Binjammin View Post
    I doubt it was a bomb victim, looks like most members' cars.
  5. #80
    Michigan
    70 '02 / 85 557e
    Quote Originally Posted by RVAE34 View Post
    Quote Originally Posted by mdimillo View Post
    That will be up to the person cracking it for us. Some I expect
  6. #81
    Jan 2012
    FRANCE
    M3 E46 RHD
    very nice work but it's not finish it's very hard to fit V10 into E30 with sway bar steering ...
  7. #82
    Royalest of Oaks
    Mazda 3
    Did I read right that you sold this car off? Or did you sell it but finishing it off for the customer? Can't recall...
  8. #83
    Jul 2006
    gods country usa
    rusty 02's
    Quote Originally Posted by LSxDreamer View Post
    lol Hope he didnt sell it. Its mine and hes finishing it for me. Maybe I should call jake??
  9. #84
    Royalest of Oaks
    Mazda 3
    Quote Originally Posted by blunt1 View Post
    Ha! See, said I could have read something wrong! Thought I saw something like that when he mentioned his imported E30 wagon
  10. #85
    VA
    Maybe we can make a trade
  11. #86
    Dec 2003
    Arlington VA
    E30 M3
    No that was his personal car, the LS1 E28 that he sold last winter.
    Those Who Stay Will Be Champions
  12. #87
    Hillsboro OR USA
    E30 318is 24v
    blunt is my hero
  13. #88
    SLR is offline Senior Member Supporting Vendor
    Jun 2004
    Florida, USA
    '08 E46, E36,
    Awesome work guys! Can you PM me and put me in touch with the DME tuner? Also if you aren't able to crack it, I have a source who is doing mine in a few weeks (Z4 V10 swap).
    Also, the crossmember work looks pretty nice, so not to rain on your hard work but look into the 325ix crossmember, might be a nice fit (about 6inches forward of normal E30 x-member and holds the rack differently).
    It's also very stiff cast aluninum.
  14. #89
    Michigan
    70 '02 / 85 557e
    Been spending some time on the brakes recently.
    Will be running 135 brakes front and rear.
    We bought e36 fitment wheels so we could space to fit and clear the brakes.
    This is with about 12mm of spacing.
    Front brackets were not to bad to make. Piece of 6061 aluminum... Stacked washers just used do to lack of hardware at the time. Brackets will be cleaned up some....edges rounded, etc.
    We are using hats from IE with custom rotors from coleman. The hats have been installed INSIDE the rotors to give more clearance at the control arm ball joint.
    Kinda hard to tell but nice and centered.
    All mounted up.
    Now the rears were a MUCH different story. We machined the calipers and removed the mounting ears.
    There was VERY little room between the mounting bracket and the backing plate. To keep enough material left in the bracket some was machined out to give clearance at the backing plate.
    mounted
    The m5 uses a very odd radiator as it is actually two radiators stacked on top of each other. If BMW designed it that way we would love to keep it. But one issue is the m5 radiator is too wide.
    Sometimes you have to cut...
    The cut part will be completely boxed in.
    And there we go...
    The engine has been mounted but the trans has had a VERY temp mount. But that needs to change. So...getting going on that.
    Just to show how big the e60 guibo is.
    Mount will be two parts.
    One that bolts to the trans (flat part in picture below) and then the cross brace. There will be a poly bushing in between (update on that when it shows up Tuesday)
  15. #90
    Mar 2004
    USA
    96 328is 6.0L
    Nice brake setup. What are you planning to use for the master cylinder to feed these calipers?
  16. #91
    Raleigh, NC
    SR-71 Blackbird
    Some progress.
  17. #92
    Michigan
    70 '02 / 85 557e
    Quote Originally Posted by bimerok View Post
    We are switching to hanging wilwood pedals and masters. .625 front master and .75 rear. Should put more pressure for the front while keeping pedal effort easy.
    For some reason this forum never emails me with subscribed threads. I'll have to check settings.
  18. #93
    Jun 2015
    Los Angeles
    06 325Ci
    Any updates?
    Any updates on this build? I'd like to see where it's at now.
    Thanks.
  19. #94
    Michigan
    70 '02 / 85 557e
    Build was delayed for a bunch of different reasons but things are starting to move along again. The goal is to have it for vintage in NC the endish of May.
    So...back to some updates. This will be a bit of a hodgepodge until I get on a bit more of a schedule to keep up on updates.
    We had taken a cut out of the drivers side frame rail to fit the e60 radiator.
    So then we needed to box it back up.
    And we wanted AC so to fit the compressor and lines a notch was required on the passenger side.
    Will get some custom lines but the e60 ones are a start...
    Fitting the air boxes and making mounts
    Close to the ABS pump....
    Similar setup on the passenger side.
    The trans sits so high in the tunnel that there was NO room for the shifter carrier. So it got chopped and mounted a little different.
    Start with some raw bits...
    Weld raw bits together...I am getting better at TIGing Aluminum but still have a ways to go. It's strong just not always pretty.
    VERY short shifter linkage
    Some captive nuts welded into the tunnel.
    And bolted in
    A video of it working....
    https://lh3.googleusercontent.com/-5...2/IMG_8644.MOV
    Adapting the E30 to S85 Power steering lines...
    Tig some AN6 fittings on each.
    Then there will be a short line made to connect the two.
    Fit the stock e60 oil filter.
    Start with some cardboard
    Turn that cardboard into aluminum
    Weld and add a gusset (again not super pretty but not terrible...)
    Mounted
    Extra Steering linkage mount needed due to the extra Ujoint. Had to figure a way to be able to remove the mount so came up with this...
    With the engine in the car.
    Hard to tell but there is more room than this pic shows.
    Sway bar wouldn't fit in the stock location so it was moved in front of the subframe.
    Core support is removable so need to make it so it stays in...more captive nuts behind these allen bolts.
  20. #95
    VA
    So glad to see this back here again. Probably one of my most favorite builds ever posted on bf.c. I keep lusting after E30's lately. Like my wallet needs anything more projects..
  21. #96
    Jun 2004
    PA
    Too many to list...
    Yes!
    '97 M3/4
  22. #97
    San Pedro california
    '94 325is ls1/T56
    First off, excellent build this little machine will be a monster! All your work is incredible!
    Quote Originally Posted by JakeB View Post
    How is the steering effort/feel with this set-up? I was considering something similar when I make new headers on my e36....are there any pros/cons
    -Hunter
  23. #98
    Michigan
    70 '02 / 85 557e
    Quote Originally Posted by sk8rpirate View Post
    -Hunter
    Feels pretty much like stock
    So the S85 radiator is more like two radiators on top of each other and the engine has 4 radiator hoses. Others have used aftermarket radiators but we want to make this as stock as possible so...we are using the stock radiator with VERY modified in/out.
    Step one....cut the stock inlets off
    Start fitting...
    next one
    And another...
    Fitting hoses
    Three out of 4.....
    I won't say I am great at tigging aluminum but sometimes things fall into place.
    Then there were four...
    tack them to the radiator
    madness....If you look close each pipe has a bit of a bead roll to keep the hose on.
    It still fits...
  24. #99
    Jun 2004
    PA
    Too many to list...
    Jeez, what a mess! So tight!
    '97 M3/4
  25. #100
    Royalest of Oaks
    Mazda 3
    I was going to say, not too much room in there for airflow eh?
