Results 1 to 7 of 7
Thread: E36 Push Button Start wiring
    Oct 2013
    Mass
    97 328is
    Hi
    I have a bad tumbler and looking around I found this for the wiring
    Can anyone confirm this is correct or changes needed before I fry my ignition?
    Joe
    Hi
    Sorry to bother you
    but i read you know the wiring to converting a push button start ?
    ANy chance you can send me a basic wiring?
    here is what I have
    position1 switch red and purple
    position2 switch red and(green/white, green and brown/bue)
    then relay for button
    30 batterypower
    85 ground
    86 switch(push button)
    87 starter wire
    other side of switch to ground?
    joe
    Mar 2010
    NJ
    325iC
    http://www.bimmerdiy.com/diy/e36startbutton/
    If you have EWS (which you do if you have the 328) you will still need the Key inserted, get an ECU that deletes EWS, or take the chip out of the key to set next to the EWS antenna
    Zionsville, IN
    93 740i, 84 533i
    You will need both a switch to put the car into 'Run' and a button to start. No need for a relay. Just splice into the wiring for the ignition switch.
    Black on Black 740i - 10/92 build date, 225,000 miles.
    Delphin on Cherry 533i - 4/84 build date, 136,000 miles
    Black on Black 328i - 3/96 build date, 185,000 miles - Sold
    2008 Porsche Cayenne GTS
    South Carolina
    2004 330 vert 2004 X5
    My suggestion is to spend $50 and get a new tumbler. That way you'll already have it fixed when you get tired of putzing around with the push start
    Zionsville, IN
    93 740i, 84 533i
    Quote Originally Posted by flyfishvt View Post
    Yep. Just take your registration into a BMW dealer and they will have the correct one for you in about two days.
    Los Angeles, CA
    1998 BMW M3 Sedan
    Quote Originally Posted by UnderCoverGuy11 View Post
    Anyone know if the EWS only communicates at start-up or does the chip have to be next to the antenna at all times while driving?
    The Netherlands
    DE-spec E36 328i/M3 cab
    Start-up only to check if a valid key is inserted.
    IG:
