Results 1 to 8 of 8
Thread: Trunk emblem loction
    Aug 2013
    Biggar, Sask, Canada
    1991 850i and more
    Hello guys,
    i just received a brand new OEM 850i emblem and i would like know the exact location of the 850i emblem on the trunk-lid.
    is there an image available or would someone be so kind to go out and measure?
    Thanks in advance,
    Matt
    Matt,
    1991 J-Spec mauritius blue 850i, CB01866, eibach lowering springs, brembo front brakes, MK wheels, 295-35-18 and 255-40-18, MK exhaust.
    2004 Chev 1500, Cam, headers, exhaust and extensive ongoing programming by me, 400hp est. And more coming
    2003 Chev Tahoe for the wife, just exhaust
    2001 custom build lotus variant with V8 by me, drivable but in progress
    1953 International L110, wife's project.
    Sep 2011
    Vancouver Canada
    '91 850i, E39 & E46 Cars
    Hi, Matt-
    The body section of the factory WSM usually provides the placement dimensions info you are looking for. I can look this up when I get home and provide some info if you don't have access to the WSM.
    /henryc
    Orange County, CA
    840Ci|725tds|Alpina B7
    It looks to be centered between the edge of the lid and the inner edge of the tail light. The top of the badge is even with the "cross hairs" of the roundel I believe.
    Jun 2012
    Albuquerque, NM
    1991 BMW 850i
    Mine was exactly 1 inch from the right edge and the bottom edge of the trunk.
    When I mounted my V12 emblem I noticed that some 1 inch painters tape lined up with the edges worked perfectly for helping me line it up to keep the emblems consistent.
    Sep 2011
    Vancouver Canada
    Matt-
    Looks like the factory manual doesn't show it.(Although it does show the dims for my E24 rear badge.)
    I measured my trunk lid badge just now. Mine is an original car, never been crashed or repainted so I know that 850i badge was placed by the factory. The bottom edge of the "i" is 55mm from the trunk lid RH edge (as you stand behind the car); the bottom edge of the "850i" is 20mm from the bottom of the trunk lid edge- the lenght of the badge is 20mm from the bottom edge of the trunk lid. With these two dims, you should be able to place your new badge correctly. Hope this helps!
    /henryc
    Aug 2013
    1991 850i and more
    Thanks a lot!
    Matt,
    Oct 2016
    Shoreview MN
    Had a 1991 BMW 850
    Badge
    Is the 850i badge one Piece?
    Dec 2007
    Dallas, TX
    '93 850Ci- Daily Driver
    Quote Originally Posted by rjjablo View Post
    Yes. The “850 Ci” is made from two separate pieces.
    '93 850Ci - Mineralweiß Metallic
    2001 740iL - Titansilber
    ALPINA B7 -Alpinweiß III
