Page 6 of 6 FirstFirst 123456
Results 126 to 136 of 136
Thread: My 540i/6 project thread
  1. #126
    Jul 2016
    2004 R32, 2011 A4 Avant
    Wish there were like buttons available. Love this thread!
  2. #127
    South Africa
    '04 330i, '95 540i6
    Quote Originally Posted by KSEADUB View Post
    Thank you I appreciate it.
    Moving on with the work on the diff. Pressed in the new shaft seal
    https://drive.google.com/uc?id=1Cfyd...BIZC94ruGpeYJ3
    And fitted the new o-ring
    https://drive.google.com/uc?id=1n5W7...ztEYbSdJZfKD8w
    Did this above for both side plates and refitted them along with the output flanges also fitted new spring clips (the ones that hold the output flanges in)
    https://drive.google.com/uc?id=1eUEm...Veaov-_SuOBwTg
    Removed the input flange
    https://drive.google.com/uc?id=1rw63...8vRF2y-Bp9IhAD
    https://drive.google.com/uc?id=1-rZC...-eO8wtp-EwVRve
    Removed the old shaft seal
    https://drive.google.com/uc?id=1B33V...ozn3cfPqJ0KRGo
    Fitted a new seal
    https://drive.google.com/uc?id=13zzB...rG3gjZh_cCM_d0
    Clean off the input flange and refitted it
    https://drive.google.com/uc?id=1ObCg...HJdsMfh7ZEhUKQ
    Removed the diff back cover
    https://drive.google.com/uc?id=1u-HO...trc-sBkkXi5IqQ
    All the parts cleaned up
    https://drive.google.com/uc?id=1jvcC...wF0Avz2WvTR76F
    Back cover refitted with a new gasket
    https://drive.google.com/uc?id=11_q9..._mVjhHhDM30bN4
    New o-ring for the speed sensor
    https://drive.google.com/uc?id=10A9H...xelyvNKZCYWioj
    Fitted the speed sensor and the diff rear mount.
    https://drive.google.com/uc?id=1GVNB...oI36tDcQ4I77e2
    Thank you for watching.
  3. #128
    South Africa
    '04 330i, '95 540i6
  4. #129
    South Africa
    '04 330i, '95 540i6
  5. #130
    moroza's Avatar
    moroza is offline MORΩN ΛABIA BMW CCA Member
    BFE
    E34T
  6. #131
    South Africa
    '04 330i, '95 540i6
    Thank you. I would actually like to do more, but time simply doesn't permit this. Hopefully someone with fine something here of help.
    I ended up getting it from the dealers. Price probably isn't reasonable, cost 3 times what the front subframe mounts are each. (For a relative price comparison) Or about $100 (just the dealer price here converted to USD) I figured at the dealer I at least get quality and it is not like I will change it soon again (also don't want to). Decent aftermarket parts aren't easy to fine mostly just get topran and the like here.
    Edit: Another thing is the serial number on my ZA 540i on both the BMW and online EPK's returns the rear mount as "part not fitted to this vehicle" so I had to do some extra searching. In all likelihood this part wouldn't have been available other than at the dealers in any case. Was back order from the dealers (not much of a surprise most e34 parts are)
  7. #132
    South Africa
    '04 330i, '95 540i6
  8. #133
    South Africa
    '04 330i, '95 540i6
    Removed the inner bearing shell form the hubs
    https://drive.google.com/uc?id=1SurK...il_H_SXngFjR9f
    Cleaned and refitted the hubs and drive flanges
    https://drive.google.com/uc?id=15ioT...EY7O8XNFzF8EWz
    Stripped the side shaft CVs
    https://drive.google.com/uc?id=15wLF...S_ibHq3pWisaMR
    Cleaned everything
    https://drive.google.com/uc?id=1s_Ib...vgPSUzSpGogy6t
    https://drive.google.com/uc?id=1Gzts...EIIUuP-A-7j3yd
    Dry reassembled the CVs
    https://drive.google.com/uc?id=1eiXC...jcdu626Ln3AgzA
    https://drive.google.com/uc?id=1quMF...ry_ZQ8WayKviam
    Reassembled the side shafts left
    https://drive.google.com/uc?id=1gpUs...Kv7irBejqdGz6S
    and right
    https://drive.google.com/uc?id=1EMt8...x9yrUH9hsjNqhD
    Knocked in the hub nut locking plates
    https://drive.google.com/uc?id=1kq-B...5qlvfBF3fNt5Z7
    Refitted the side shafts
    https://drive.google.com/uc?id=1Q8lO...VLSN6LUwV1jN4c
    Cleaned and refitted handbrake parts
    https://drive.google.com/uc?id=1T9zv...eE019Luk6zRLLv
    https://drive.google.com/uc?id=11THt...1uXQ2i67p3N9fD
    Refitted discs and caliper carriers
    https://drive.google.com/uc?id=1x4PM...kMBuyqBRMZX6WV
    Refitted calipers
    https://drive.google.com/uc?id=1heSo...y8KtstqXMxwFKH
    Refitted brake hard lines
    https://drive.google.com/uc?id=1jMsj...zUYkOHeheIluU6
    Fitted new rear pitman arms
    https://drive.google.com/uc?id=1eIsV...GA_xlpVWj7a6JH
    https://drive.google.com/uc?id=1PWFk...c6CLbj9XFF9ysM
    Fitted braided brake hoses
    https://drive.google.com/uc?id=1jCo-...6K7Mx-KPq_Dp9F
    Fitted rear struts
    https://drive.google.com/uc?id=1taAh...aTXrpv1LzDjs18
    With the struts in I pre-loaded the rear suspension, bled the rear brakes, adjusted the handbrake, and refitted the prop shaft heat shields and exhaust.
  9. #134
    Ambler, PA
    1995 540i/6
    Awesome work and attention to detail. It's on my perpetual to-do list to rebuild/ clean the CV's on my 540i as well. Nice job!
  10. #135
    Aug 2019
    '95 540/6, '01 750iL
    Any updates my friend? Been a long time since we've heard from you...
  11. #136
    May 2020
    EU
    E34 520i 1996
    Great thread. Really hope there's updates.
