To be on the safe side, measure the cam journal diameter to make sure they do fit. I'm sure they do but ..... you know the drill.
Also, this isn't the accurate method of measuring max lift, but if one could measure the two perpendicular diameters of the cam lobe profile and the difference of it should roughly give one an idea of max lift number. Another way is if one could fit a zeroed-in dial indicator on the profile and turn the cam over could also give a rough estimate on the lift. One thing to keep in mind is that we've got hydraulic valve lash adjustment and so the valves may appear to open fully but that may not be true. If one could put an epoxy in that lifter so as to compress it and to be able to get the true max lift would be great.
Sorry, not to compress it otherwise you're back to square one .....
I'll be using a dial indicator.
Ah, epoxy solid lifters.
I don't remember seeing an easy way to open up these lifters like lifters on some other engines. I'll check them out again when I head into the man cave later today.
I know a guy that has a set of VAC stage 1 heads, he wanted big bucks for them. So now we're dumping more money into the car than it's worth....HP and torque, love it.
Go big or go home! (thanks for the saying Aryana)
I would think those lifters are the same across many BMW engines including the M62 from this site. Check it out:
http://forum.e46fanatics.com/showthr...7#post14251457
Any chance that you have the valve->piston clearance for the intake & exhaust at TDC? I wish there was someone local which I could to a clearance mock up with plastercine, so it is not a guess. At least having a stock M62tu piston/valve clearance baseline, would at least give us an idea how much is available to go bigger.
Yeah, we need to know the cam/crank degrees when the valves open and close, and the position of the pistons too.
Auaq, good find, those are the lifters. I haven't checked out the p/n's yet but they look exactly the same.
I got these from a 99 540tu engine that had a rod thru the side of the block.
Can't get that on my engine, the heads are on. I may bea able to get that info from a non vanos that I helped the owner strip a few months ago. Pretty sure he still has the engine.
So why is an I6 guy so interested in a V8. Oh wait, he really want those two missing cylinders.
As much as I would like to get that info my engine is too much back together to get that.
Cam journal specs should be in Bentleys or TIS.
Total lobe lift is 0.3525" as close to measuring it on both intake cams, this is almost 9mm.
I couldn't read the exhaust lobes, no good place to anchor the dial indicator base to.
Also had trouble trying the read the intake duration which is suppose to be 236, I was getting 189.5 deg.
What are you mad cam scientists up to? Looks like fun. Only 189 degrees of crank rotation showing lift at the cam lobe. Hmmm? Cant be right. The lifters dont squish much at all at engine rpm, so you get pretty much the same lift at the valve on these modern ohv style heads. No rockers and the cam is in alighnment with the valve stem. Direct action pretty much.
Yeah, that's what I was trying to figure out, doesn't seem right.
I did it 3 times. Got the same reading every time. I must be missing something or the info I read was wrong, but I doubt it as 236 does sound like a proper duration.
Not to change gears, you bought a PWM fan controller, right? What was it? I'm trying to help out another guy that wants one.
http://www.ebay.com/itm/RADIATOR-FAN...-/251485739357 Heres the one I used. Still works perfect. Looks like he is using my pics on his add. Not much else out there that I could find with these specs.
Thanks for the PWM info.
Thanks a lot for taking the time & contributing with actual data Jim, really appreciated. As soon as I pick up a set of Alpina B10 cams I'll be able to contribute back the same. I'm going to get my cams plotted/measured professionally, like I did for my m30b35 so there is no guessing on my part.
http://www.bavengine.com/engine.html rebuilt my engine and I went w/ the Performance Option that regrinds the cams, ported and polished heads, etc. I've dyno'd the car and have verified I've gotten more power due to their mods.
If you're looking to get more power out of your BMW, then upgrade to our Performance Option and increase your horsepower by 20%. This option provides a substantial increase in performance while preserving the 5 year warranty, factory longevity, and emission standards. The upgrade includes flow-tested CNC cylinder head porting & hand polishing, Bavarian Performance camshaft, MaxSil pistons with Tefcote, Sealed Power piston rings, and precision balancing. Proprietary Bavarian CNC porting provides optimized turbulence, maximum air flow and precision consistency between ports.
650hp 10 X5///M5
PERFORMANCE:JB4 w/ meth, stage 2 tune, wrapped downpipes, custom intake
INTERIOR:AVIN 10.25" screen, Blackvue 550 dashcam, 7" tablet for JB4 logging
EXTERIOR:Niche staggered 20's or AC Forged staggered 22's, H&R 2" suspension, LED AE, CF front splitter
325hp 98 BMW 740iL6
PERFORMANCE:///M5 6spd swap, iron sleeves, L/W Teflon coated & silicone impregnated pistons, Sealed Power rings, 3 angle valvejob, P&P head, perf cams, electric fan, CF intake tube w/aluminium heatshield/wrapped MAF tubing, Magnaflow 14816'd, Eaton M112 in-work
INTERIOR:Android Dynavin, hardwired V1 above rearview, 12" RE Audio DVC sub, MTX 81000D monoblock, CF silver trim, 5% tint
EXTERIOR:///MPar staggered 19's, H&R Stage 2/Bilstein HD, custom notched bumper, Shadowline trim, 750iL brakes w/ Axxis pads
190hp 97 328ci
PERFORMANCE:Single mass flywheel, ///M3 clutch
EXTERIOR:Z4///M staggered 18's, rolled fenders, tinted markers
^^^ I thought those guys stopped doing the performance build options 1-2 years back?
Copy and paste directly from the bottom RH corner of their webpage. The only thing I've heard years ago is that they now contract out the work, but it's still being done nevertheless.
650hp 10 X5///M5
325hp 98 BMW 740iL6
190hp 97 328ci
I also am interested in this. Looks like Jims setup but somebody else has done the housing bit for you (minus the override switch which should be easy enough to add) I have the capability to homebrew like Jim but need to stop overloading my project plate and should buy-in more stuff like this.
Only question is what fans I want use... might chase down the Summit/Jegs options other guys have had luck with...
2003 M3CicM6 TiAg
Former:
1985 MB Euro graymarket 300SL
I don't want to side track this thread too much, but here is my install from the old Roadfly hood (sniff sniff): http://forum.roadfly.com/threads/131...PWM-controller I used the Summit curved fan.
I wonder if the Vanos has that much of an impact that they can remove so much duration and still get performance. Maybe that combined with the intake helps expain some of the top end (and low end) differences between the motors torque and power outputs. Seems too drastic of a drop to me though. Only 189 deg. - No way...?
2003 M3CicM6 TiAg
Former:
Sign up on RF, it only takes a few seconds. Good pics along with some of a Ferrari BBQ I went to last year and some brews that you won't find around these parts.
I used a Flex-a-Lite Slimline 116 fan, only draws 10 amps max, it never runs at more that maybe 1/3 speed even on a hot summer day.
I'll try the duration thing again. This time I'll use a degree wheel on the crank.
Yesterday I was just counting how many teeth of the cam gear from when the lobe started pushing on the lifter to when is stopped. Then used that to figure the duration.
OK, some new readings and info.
My intake cam duration reading were wrong, I failed to see the cam rotating on its own due to the vanos unit. The open valves pushed the lobes while the chain driven gear wasn't rotating. That's what messed me up.
So a few min ago I checked the exhaust cam duration, no vanos unit on this cam to screw me up.
The published duration is 228°, I read 225° so with the slop in my timing wheel connection to the ratchet and extension I would say the published 228° is correct.
Now to figure out how to lock the intake cam vanos so I can get a good reading.
Aha, the damn vanos strikes again! Makes sense. Not sure how to lock it. No vanos on mine. Maybe put some kind of indexing tape on the cam itself and measure how much it rotates on that then divide by two?
Heheh - deleted my earlier post.
I think if the intake cam can be turned and locked at full retarded position shouldn't give any erroneous readings.
I'm giving up, got to get this thing back together, it's been apart since mid Dec.
I measured the duration from close to fully open, that was ~120 deg. Then the cam rotated on its own because of the other valves that were pushing on their lobes.
Auag, I thought of that but I would have to hold the wrench on the cam back at the rear holding spot while turning the engine over at the front of the crank. Arms aren't that long.
No volunteers?
Heheh - Well, you need to roll. No problem. Maybe somebody else need to take on and find IO/IC/EO/EC.
Here are the BMW published specs for the M6x cams. I don't know the VANOS advance for the TU cams though.
Intake BTDC ABDC Exhaust BBDC ATDC Duration Lift Open Close Duration Lift Open Close Overlap M60 246 9.7 14 52 242 9.4 48 14 28 M62B44 238 9 8 50 228 9 42 6 14 M62B35 238 9 12 46 228 9 42 6 18 M62B44tu 238 9 -4 62 228 9 38 10 6 M62B35tu 238 9 -4 62 228 9 31 17 13
Cool, thanks.
The vanos will retard or advance the cam timing (in relation to the crank) +/- 20 deg.
