Page 1 of 4 1234 LastLast
Results 1 to 25 of 77
Thread: Turbo or supercharging the M70/S70........
    Iceland
    BMW 850
    I have been thinking about on thing and since many guys around here know their way around those engines they might give their input.
    Just to be clear. I am not thinking about doing it, but just would want to know.
    What is would the difference be between those two?
    Supercharged and turbocharged.
    Benefits and drawbacks. This might be a fun discussion.
    Tampa, FL
    '93 850Ci, '07 X5 4.8
    From what I've seen, I would think supercharging is more parasitic to engine output. Isn't that right?
    Apr 2009
    Vancouver Isl, BC, Canada
    98 Euro M3, 04 M3, 06 M5
    Supercharger is a compressor that runs off a belt driven by the crank pulley
    Turbocharger is a compressor that is driven by exhaust pressure.
    fitting either into the engine bay of an 850 is a challenge. if you turbocharge you would need 2 to do it properly. You could get away with only 1 supercharger.
    Current:
    - 09 335i MSport, FBO.
    - 98 Euro M3, Estoril Blue
    - 04 M3, Carbon Black, 6 Speed Coupe
    - 06 M5, Black on Black, Full Leather.
    - 73 3.0CS, Tagia Green, 5 speed M30b35 converted
    Ex's: 1984 325e, 1988 325IX, 1992 525I, 1995 540i/6, 2002 330i, 2005 330xi, 1992 850i, 2003 330i #1, 2003 330i #2, 2002 330ci, 2004 330ci, 2007 328CI, 2007 335i, 2001 M3, 2006 M5 6 speed
    jcs1966's Avatar
    jcs1966 is offline SoCal Eights - CA BMW CCA Member
    Nov 2012
    Bakersfield, CA, USA
    1994 BMW 840ci
    Good details to come on this topic. We just had a great presentation on the subject. I'll talk to Brian and see if we can get a link to the presentation uploaded.
    Jeremy Smith
    94 840Ci
    98 Porsche 986
    02 Mini Cooper
    13 Ford F150 Platinum
    Woodland Hills, CA
    Disco II 850i MERs 750il
    Bryson, please pick up the nearest white courtesy telephone.
    Dec 2003
    SJ, CA
    '00 Z3C, '70 XJ6
    lol
    The benefits of a S/C over turbo are mostly packaging, decreased system complexity, immediacy of power delivery and cost
    The benefit of a turbo (or two) over a S/C is power. A mildly tweaked m70 with a big turbo or two and good engine management should be capable of near 1000hp.
    - A single turbo will require use of a standalone engine controller to avoid engine damage/failure in the case of single bank shutdown
    - Twin turbos have very limited packaging constraints due to the giant steering box on the driver's side
    - Twin twin-scroll turbos could make for very quick throttle response while still being able to hit the 550+hp pump gas daily driver (this is what I have sitting in a box and designed in-part on my computer)
    So your limitations are really; How much power do you want and how much are you willing to spend to get it? If you want less than 550hp, buy John's S/C kit and ask for the big C38-91 blower. If you crave more than that, go turbo - you can throw some money at me and hit me up for system design
    that's pretty much it in a nutshell
    2.8 Z3 coupe + 6 speed || 200kW electric 1970 Jaguar XJ6
    Woodland Hills, CA
    If you were to get rid of the steering box, would that open up the design space significantly or does the volume constraint shift to the other side?
    Duesseldorf, NRW, Germany
    '90 850iM70B54, '91 850i
    Quote Originally Posted by bruinbro View Post
    funny idea to get rid of the steering box
    If you do this please do not test drive the car with your 18" ALPINAs on.
    Jun 2012
    Uk
    1994 850csi rhd
    Quote Originally Posted by wokke View Post
    Straight line performance will be improved :-)
    Woodland Hills, CA
    I was thinking that it might be possible to replace the steering box and hydraulic power steering components with an electric rack "fly-by-wire" system.
    Dec 2003
    SJ, CA
    '00 Z3C, '70 XJ6
    The answer to your questions is 'yes'
    Lots of space would open up and the constraint would also move to the passenger side due to the starter. that can be worked around, however
    Sep 2013
    Commiefornia
    Crash test dummies come to mind
    Quote Originally Posted by Fatandre View Post
    bring diaper
    will show u 0-140 under the 1/4 mile mark
    Mar 2010
    Derry, NH
    1994 525I, 1993 850Ci
    I would love a twin scroll for my 850. Do you have just the design or a "working model"?
    Also how would the stock auto trans handle this kind of power?
    1983 Monte Carlo SS
    1984 Pontiac fiero SE
    1993 BMW 850CI
    1994 BMW 525I
    Dec 2003
    SJ, CA
    '00 Z3C, '70 XJ6
    Just the system design and a working model that needs, well, work..
    I have made exactly zero progress in the past year
    Dec 2007
    Dallas, TX
    '93 850Ci- Daily Driver
    There was a supercharged 850 at 8-Fest that is veeeery fast and it works. Designing one of these in a computer modeling program might give you a 3D picture of the components, but there are a lot more real-world parameters that need to be considered besides just seeing if the parts fit. Having seen both the DINAN TT and the single S/C 850, and having driven the TT and watched the S/C blow by at Warp-9!, either way will work, and produce more than enough power to put you over 200mph.
    As far as being able to attain 1,000HP from the M70 with a TT, you need at least double-digit boost. The DINAN TT Stage 3 car manages 625HP running around 11-12 pounds of boost. To get to 1,000HP, you will need to crank the boost up much higher than that plus use some "special" fuel. The M70 really might not do too well with 20 pounds of boost. The Stage 3 uses a modified engine to get to its 625 - forged pistons, crank, etc. The 1,000 HP dream is just that -a dream...
    Besides, the S/C looks like a beast and sounds as mean as it looks! 1,000HP might be everyone's wet-dream, but the reality is that your tires won't be able to keep up - at that point it is worthless...
    '93 850Ci - Mineralweiß Metallic
    2001 740iL - Titansilber
    ALPINA B7 -Alpinweiß III
    Quote Originally Posted by TxGR8White View Post
    I don't think the tires will have a problem with 1000HP.
    Simply because gearbox, drive shaft etc. fail before the power gets to them.
    But besides that, who the heck needs 1000HP ???
    Woodland Hills, CA
    Those of us that are going to do the wheelie bar mod.
    Mar 2010
    Derry, NH
    I'll happily take a s/c kit.
    But really, where can I get either a s/c kit or a turbo kit, preferably s/c.
    I was told to contact johnindc but he never got back to me.
    1983 Monte Carlo SS
    1993 BMW 850CI
    1994 BMW 525I
    Dec 2007
    Dallas, TX
    If you have an M70, and want a supercharger, then John is your guy. Very nice quality work.
    Iceland
    BMW 850
    are there any actual pics of Johns kit how it looks under the hood?
    Dec 2003
    SJ, CA
    '00 Z3C, '70 XJ6
    For the record, I absolutely recommend the supercharger setup for 98% of owners! Definitely give John a ring, I wouldn't consider anything else an option really
    Iceland
    BMW 850
    Well, you did consider the turbo
    Sep 2013
    Commiefornia
    Quote Originally Posted by Larkin660 View Post
    Hello Larkin,
    i have the stage |||+ from John ,
    installed the day before the fest,we then drove from Los Gatos to garberville with a flawless run and return back home.
    John estimates 530+ and 480 hp at rear wheels, with room for improvements from there.
    i will be changing the diff gearing for even more improvements.
    the installation is very clean and almost unnoticeable from above.
    John is a perfectionist and it shows.
    he will fly to your location and do the install and final tune for a nominal fee.
    Iceland
    BMW 850
    Brave.
    Do you have a pic of the kit installed?
    Jan 2003
    Silicon forest
    318ic 540ia 740il 850i
    In for Pics......
    Bave- automatic of manual?
    Thx
