Page 2 of 4 FirstFirst 1234 LastLast
Results 26 to 50 of 89
Thread: Philly98540, I've installed thermostat and it works well
  1. #26
    Dec 2007
    Great Dismal Swamp
    E36/7 E36/8x2 E46 F25
    The one spare thermostat I have isn't marked, of course. Everything I can find gives an operating temp of either 108, or 108-110. It's possible the markings on the stat are the nominal point at which it starts opening, as the manufacturer won't know the characteristics of the engine and where it will find balance. So if the same is true on OP's 95, ie thats the marking rather than the balance point, then I could accept a 97-98 operating temp.
    /.randy
  2. #27
    SoCal
    F10 N52
    Quote Originally Posted by philly98540 View Post
    Performance vs Efficiency
    Why would a colder engine perform better? Is it to keep air intake temps down?
  3. #28
    Sep 2010
    Ooltewah, TN
    2010 BMW M6*2019 X3 M40i
    Quote Originally Posted by GreenTiger View Post
    So 540san, the correct part number for non vanos M62 95C thermo is: 11531745476?
    Correct. Tomkinson BMW (I highly recommend them) has it for $75. Shipping is flat $12 unless something real big and heavy. I usually try to buy something else to offset the shipping cost.
    To clear the confusion, the thermostat I pulled has 105 C markings on it just as M62TU, which means the reason for M62TU running slightly higher temp is due to different input from DME. 105 C is simply mechanical opening temp in case heater fails.
    I don't understand the theory that 5-6 C difference between KTMP and thermostat rating means something is wrong. It makes the sense as KTMP reading might not be 100% accurate and there are way to many factors in play such as ambient temp, engine load, radiator fins not 100% clean, aux fan sensor not 100% accurate etc. It seems that quite a few owners see that temp difference with no cooling problems.
    Why am I seeing almost identical temp and no difference in fluctuations with the 95 C thermostat? It's simple, map controlled thermostat does what it's suppose to do but not as much as it's claimed. Engine temp (head) matters but coolant temp doesn't? Sorry but I disagree, because they're related to each other and of course there will be a difference.
    Also, the claim about higher engine temp and potential engine pinging. That's all fine in theory and I'm sure map controlled thermostat helps with that but it's glorified too. So BMW comes with new technology and suddenly the old technology that's been working fine for many years is obsolete.
    BMW wants to be the leader in technology and one of the main reasons is the competition. Look how great all that new technology is working on E60, E92 etc. We don't have to wait 15 years, there are already number of problems that exceeds E39 problems.
    Draw your own conclusion, but I switched to the thermostat that's been originaly on M62 and eliminated the potential wiring issue, I call that improvement.
  4. #29
    Jun 2005
    New Jersey Republic
    2001 740IL,2000 540I/6
    I hope I'm not hijacking this thread but here is an update: I ordered the 88C thermostat from Europe(Romania), total time being shipped-6 days(it spent sitting at US customs for 3 days, lol, well it was weekend), put it in today, test drove the car, ambient temps were about 70. After a decent haul on high-way the temp was around 92-93F doing about 70mph, once in traffic it stayed that way for a while then it climbed up to 96-97F, once i started moving it goes down to 92-93F. I think I know now, why we see the temps a little bit higher with the lower temp thermostats----our cars' fan clutches were designed for higher temps to lock up the clutch, I noticed that if I shut my car off for 5-10 min. and then start it and drive, i can hear the fan clutch engaging from the heat soak and my temps go down to 92F immidietly, anyway I love my new "upgrade" . So now I'm on a search for lower temp fan clutch, lol, or go electric as I already have the Lincoln MKVIII fan .
    Edit:
    I just checked realoem, and they actually rate fan clutches in degrees Celsius , but they dont display it for E34 535 which I think may work in my application since the stock thermostat is rated at 80C.
  5. #30
    SoCal
    F10 N52
    Supra, the 88C thermo is stock for which application?
  6. #31
    Jun 2005
    New Jersey Republic
    http://www.realoem.com/bmw/partxref....r=on&details=1
    Part # 11512248542
    E38 740d Sedan, M67, Europe, AUTO (GE81) : Waterpump - Thermostat
    E65 740d Sedan, M67, Europe, AUTO (GM41) : Waterpump - Thermostat
    E65 745d Sedan, M67N, Europe, AUTO (HM61) : Waterpump - Thermostat
  7. #32
    Virginia
    1999 540i sport
    Sweet supra thanks for the update I have my 88C thermostat right on the bench but I haven't installed it yet as my car has been a the body shop.
    I have polished it in the mean time....haha
    Can't wait to install this.
    1999 BMW 540i Sport
  8. #33
    SoCal
    F10 N52
    Nov 2012
    Lewes,DE
    1997 540i
    Can you please tell me what you used for the dummy load or resistor?
  10. #35
    Jun 2005
    New Jersey Republic
    Quote Originally Posted by ninetyseven1 View Post
    I used nothing, why?
  11. #36
    Nov 2012
    Lewes,DE
    1997 540i
    Quote Originally Posted by supra94tt View Post
    because another member said he got the
    code: 06-8B Electric thermostat control final stage after disconnecting the wire without using a resistor. ??
    BMW540San , what did u use for a resistor? to stop any CEL?
  12. #37
    JimLev's Avatar
    Sundance Mesa, NM
    00 540/6, '16 Highlander
    See post #19
  13. #38
    Jun 2005
    New Jersey Republic
    You should not get any CEL by disconnecting the thermostat, maybe a code in DME, but that's about it.
  14. #39
    Virginia
    1999 540i sport
    I have installed my 88 C thermostat today and I have run the engine to bleed it but I haven't driven it yet will keep this thread updated on the temps I see.
    I have not used a load resistor on mine and no CEL.
    Oh B.T.W. Randy my original BMW thermostat I just took off says 105 C on it.
    1999 BMW 540i Sport
  15. #40
    Sep 2010
    Ooltewah, TN
    Still haven't got any CEL and I don't think I will. What's even stranger, I didn't even get the any type of code. That's according to my AutoEnginuity which is fairly competent scan tool.
  16. #41
    Mar 2012
    Lansdale, Pa
    98 540 6, SC'ed, 16psi
    Quote Originally Posted by BMW540san View Post
    That is strange as mine threw the "stat final stage" code very quickly. I guess BMW changed the program in the computer at some point. Some get, some don't.
  17. #42
    Jun 2005
    New Jersey Republic
    Do you have a CEL or just a code in DME, two diff. things .
  18. #43
    Mar 2012
    Lansdale, Pa
    Both CEL and code showed up. Sorry for not clarifying.
    I can unplug my resistor and make the CEL light up. My car is a 6/98 build date.
  19. #44
    Aug 2008
    princeton, nj
    2001 540i 6speed
    im confused... some claim thermostat code is stored in DME only while others say it throws a CEL. sigh.....
    2001 540i 6speed metallic silver
  20. #45
    SoCal
    F10 N52
    Philly, are you using a 12 ohm 25 watt resistor like Jim mentioned?
  21. #46
    Mar 2012
    Lansdale, Pa
    I used a 10 ohm 100 watt. I posted it on one of these stat threads somewhere.
    The one Jim posted will work too. I went 100 watt since it runs cooler and i was unsure how hot the thing would get. I think i got it off amazon for cheap.
  22. #47
    Virginia
    1999 540i sport
    I have a 10/98 Build date with no cel
    1999 BMW 540i Sport
  23. #48
    Nov 2012
    Lewes,DE
    1997 540i
    Quote Originally Posted by Alpina540i View Post
    I guess my next and only other questions would be: Is your fan on more often now? OR does the car operate the same only runs much cooler? If I recall this past summer ,my clutch fan was really robbing power one day and sounded like a school bus. I wonder if there is high speed and a low speed in the fan itself? I ask this because, I hope putting in a lower temp thermostat would not make the fan come on more often.
  24. #49
    Virginia
    1999 540i sport
    The reason the fan is called to high speed for is hot engine temps thus reducing the overall engine temp will make the fan turn on much much less.
    1999 BMW 540i Sport
  25. #50
    Virginia
    1999 540i sport
    So to update this thread I have installed my 88 c thermostat and in 80 degree Fahrenheit weather today I saw 93-94 c while crusing at continuous speed and in stop and go hardly moving conditions 101 was the max. While stopped and idling with AC on I saw a steady 99 c temp.
    Much better than the 103-109 c temps I had before.
    All of these temps are measured without a mechanical engine fan installed and just auxiliary fan.
    1999 BMW 540i Sport
