Page 3 of 3 FirstFirst 123
Results 51 to 72 of 72
Thread: E46 ABS into E36 - details wanted
  1. #51
    Dec 2002
    Lake Tyler, TX
    88 E30 M3 S65
    It is my understanding that the wheel speed sensors ARE different. I have been told the easy way to tell is grey plug vs blue plug. Mk60 uses the blue plugs. I have never tried a grey plug however.
    It's not speed that kills, it's the speed difference that does. Obviously you aren't going fast enough.
    Turning Benjamins into noise since 1997
    I read a list of the 100 things you MUST do before you die. Funny, "Yelling 'HELP'" didn't make the list!
  2. #52
    Dec 2012
    Virginia Beach
    2001 525i Sport Wagon
    On the Nissan 370, I used the stock Nissan sensors with the Mk60E5.
    2 wire, current type I believe.
    Peter Florance
    PFTuning.com
  3. #53
    Mar 2004
    Tampere, Finland
    E46 M3 SMG, E36 318is Class II
    You do not have to change the old E36 VR type ABS sensors to newer Hall type sensors. You can just convert the signal type to be suitable for newer ABS units
    http://www.boostaddict.com/showthrea...gnals-reliably
    Boards are from here, 40/50 USD depending on version:
    http://jbperf.com/dual_VR/v2_1.html
  4. #54
    NY
    skateboard
    Quote Originally Posted by boyracer View Post
    So 1 would only need an abs cpu from say a e46 m3?
    ― George Orwell
  5. #55
    Feb 2013
    MD, USA
    2005 M3 Coupe
    Quote Originally Posted by GG///M3 View Post
    You'd also need to run a 4th brake line to the rear of the car, the E36 is 3-channel, the Mk60 is 4-channel. You'll obviously also need the controller/abs unit (as you mentioned) and to rewire the connector because I would guess the E36 unit is different than the E46 unit in that respect.
  6. #56
    Mar 2004
    Tampere, Finland
    Yes, that small adapter board just allows you to use E36's (or other BMW's using) original VR type ABS sensors. Plenty of other stuff needed to get Mk 60 up and running as dmw16 pointed out.
  7. #57
    Feb 2013
    MD, USA
    2005 M3 Coupe
    Would it let you use an E30 speed sensor?
    I'm in the process of setting up Mk60 ABS in my E30 and right now I'm planning on using rather crude adapters I built to put E46 speed sensors into my E30 struts. But if a little plug in board can do it and let me retain my originals that's something worth considering.
  8. #58
    Mar 2006
    Menlo Park, CA
    95 M3 & Legacy Manwagon
    Disclaimer: I have no idea if this works on an E30. It did on my E36.
    It was trivially easy to get the blue connectors working in an E36-- I just depinned the grey chassis-side connector, installed the chassis-side blue plug housing, and reassembled it. Then the blue plugs are plug and play, as they bolted right in without any shimming or effort required. Spending $50/wheel to convert the signal type doesn't make a ton of sense (to me).
    After that, you still need to wire the wheel speed sensors to the E46 DSC/ABS computer. With the DSC/ABS installed in the engine bay, I ran wires through the firewall to the E36 ABS computer location, removed the E36 computer and tapped the existing wheel speed sensor wires at the ABS computer plug. Super simple, just a lot of contorting to access stuff.
    You will still want to have an E46 M3 master cylinder, brake pressure sensors, and the yaw/dsc sensor wired in for full ABS functionality, at a minimum.
    If you aren't comfortable doing the wiring, you can buy pre-built harnesses such as Epic Motorsport's (and likely others): http://epicmotorsports.com/mk60-stan...o-e46-abs.html
    "Fear disturbs your concentration" -Sabine Schmit
    1995 BMW M3/2/5-- S54 + Mk60 DSC, California Smog Legal (Build Thread)
    1998 BMW M3/4/5 Alpine/Modena, Z3 Rack, otherwise stock-- DD without burbles
    2017 Chevy SS, Orange Blast Metallic, 6MT -- DD with burbles
  9. #59
    NY
    skateboard
    Dang that isn't cheap lol
    ― George Orwell
  10. #60
    Vancouver, BC Ca
    1993 325is
    Quote Originally Posted by Bimmerman535i View Post
    My reading lead me to believe that each board would convert 2 wheel speed sensors, so $100 total for internal and $80 if you wanted to run 12v power to them.
    $1600 is nutin for that harness. Though this type of wiring doesn't make me uncomfortable.
  11. #61
    Mar 2006
    Menlo Park, CA
    Quote Originally Posted by jakermac View Post
    That's good if you can run two sensors off of each board. My thinking is that, given the amount of wiring needed to get the Mk60 up and running, does it make sense to get the signal converter board? The board doesn't save you any wiring work.
    Agreed on the harness price, it's just an example that you CAN buy them if needed.
  12. #62
    Mar 2004
    Tampere, Finland
    Well, it's an option which allows you to leave everything under the car as it is, just put the two converter boards near ABS unit and you can leave rest of the existing ABS sensors and wires as it is.
    Costwise, you need two boards which is 80 USD or 100USD. I bet 4 x E46 Hall ABS sensor cost something too? :O
  13. #63
    Feb 2013
    MD, USA
    2005 M3 Coupe
    Quote Originally Posted by Bimmerman535i;29038687You will still want to have an E46 M3 master cylinder, brake pressure sensors, and the yaw/dsc sensor wired in for full ABS functionality, at a minimum.
    If you aren't comfortable doing the wiring, you can buy pre-built harnesses such as Epic Motorsport's (and likely others): [URL
    http://epicmotorsports.com/mk60-standalone-abs-system-upgrade-to-e46-abs.html[/URL]
    I'm using the E30 MC still, mainly because the bolt pattern for the E46 MC isn't horizontal so when mated to my booster the whole thing would sit at an angle...namely the reservoir. I guess I could make an adapter plate if I have to, but I am going to start without the E46 MC. The pressure sensors will go into brakequip 3-way fittings to pickup that signal.
    The jury is also still out as to whether or not you need the yaw sensor for ABS functionality. Some say yes, others say no. I'm using one because the sensor was $30 on eBay and why not (make sure you're sitting down before you look at new-part prices on that sensor).
    The pre-built harness is very expensive, but I suspect it's mostly because it's a pretty limited market that uses this stuff in non-standard applications. It's also not trivial dissecting the wiring diagrams to wire everything especially if you're talking about a totally standalone system into an older chassis like an E30 or E21 or E9 or whatever.
  14. #64
    Nov 2008
    New York, NY
    2001 BMW M5, 2005 BMW M3
    Quote Originally Posted by dmw16 View Post
    Making the harness is easy. I did it over a weekend.
    The yaw sensor is not required for standalone ABS. It plays a role principally in traction control. Exactly what role it plays in the ABS algorithm, I don't know and would like to know. What I do know is that standalone MK60 ABS works fine without the yaw sensor. That said, I run the yaw sensor because it was cheap and easy to wire into the harness.
    --Peter
  15. #65
    Feb 2013
    MD, USA
    2005 M3 Coupe
    Quote Originally Posted by herrubermensch View Post
    --Peter
    Now that I've got my pinout planned out making the harness won't be a big deal.
    I ended up getting a yaw sensor for the same reason. For the $30 it cost there was no reason not to wire it in. Obviously to add DSC requires the yaw sensor and the steering angle sensor and possibly other things, not sure. But I'm just using it for standalone ABS.
  16. #66
    NY
    skateboard
    --Peter
    So what 1 would need would be the abs ecu/pump , 2 of those boards to change the signal for the sensors, and what else did I forget? lol
    ― George Orwell
  17. #67
    Mar 2006
    Menlo Park, CA
    DSC computer/pump unit
    E46 M3 brake pressure sensors (2x)
    Z3M S54 brake booster (or, shim your E36 booster at the master cylinder mating surface)
    either blue connector wheel speed sensors OR the electronic boards discussed above
    optional but suggested: yaw rate/dsc sensor (the combined unit, not the separate Mk20 style)
    Those are the minimum components you need for functionality of ABS, not including the wiring itself.
    I bought a complete DSC swap kit from Asmod3us here on bimmerforums, and he's also on m3forum. He sells most of the above components bundled together, I think I paid ~$450-500 for it?
  18. #68
    Vancouver, BC Ca
    1993 325is
    So I finally got my hands on a Teves MK 60 setup from an '03 M3. Now here are MY questions:
    I'm installing this in my 93 325is which already has a Wilwood front setup and is about to have some lightweight Wilwood rear stuff as well as a Massive Brakes booster delete with either their single or dual MC delete system (I have both). Does the E46 M3 system need a pedal "travel" sensor like my 93 has? Can anyone say for sure that the YAW sensor is not needed? I have it, but if it's not needed, I'd rather not install it. My ABS controller is the 813 (813.3). Who is this guy overseas that can do the reprogramming, what does he charge and will it make a big enough difference for an autocross car on wide-ish sticky (Hoosier purple crack) rubber to make it worthwhile?
    And, does anyone have the blue plug wheel speed sensors and the MC pressure sensors spare for sale? I didn't get those with my package.
    Does anyone remember the guy that machined adapters (I think they were "T"s) to hold the sensors and the feed off the MC to the ABS pump?
    Oh, and when I finally decide what MC delete kit I'm going to use, I'll have the other one for sale.
  19. #69
    Feb 2013
    MD, USA
    2005 M3 Coupe
    Not sure I can answer all of these, but I'll try to help where I can as I just finished putting a Mk60 system in my E30.
    A pedal travel sensor is not required. You do need a "brakes on" switch which is just a splice from the brake light switch that is under the dash.
    The speed sensors are cheap on ebay...full set was $40. The pressure sensors are a little more expensive. I scored a used set off of eBay, but failing that you can get them thru BMW (P/N: 34521164458) or Ali Express has them (can't vouch for their goodness)...
    http://www.aliexpress.com/item/Brake...535713245.html
    A yaw sensor is not required. Seems it doesn't do anything without the full TCS/DSC system in place which requires a bunch of other stuff.
    Not sure on machined adapters, but brakquip and others make 3-way juntions that work just fine. You'll just need to work thru the sizes of the lines...both pressure sensors as M12 threads, but the brake lines are M10 and M12 depending on the side. But having said that, if you use an E46 MC then it doesn't matter since there are outlets specifically for the pressure sensors so you don't need any junction fittings. But one thing to note on that is that the E46 M3 uses a "clocked" fastener pattern compared to the E30 (and I think E36) MC that is a horizontal bolt pattern. So you'd need an E46 booster to use an E46 MC.
    Lastly, and you probably know this, but you'll need to run a second brake line to the rear of the car since the Mk60 is a 4-channel system compared to the E36's 3 channel system.
    Hope that helps.
  20. #70
    Vancouver, BC Ca
    1993 325is
    Hope that helps.
    All of that helps immensely. Thank you very much. I knew about the 4th brakeline and I'm not using a BMW MC so no worries about bolt patterns. It'll either be a pair of 3/4" Wilwoods, or a single 19mm VW one.
  21. #71
    san jose
    E36 S54 M3, CAAD10,
    Hey guys, I'm gathering the necessary parts to integrate mk60 abs into my e36. What's the concensus on the brake booster? Can I use my stock? Or is z3m booster needed?
  22. #72
    Sep 2010
    Pacific Northwest
    95 BMW M3 | 03 330i ZHP
    Quote Originally Posted by sh1ftgear View Post
    I don't even know if this warrants a responce, but read:
    http://www.bimmerforums.com/forum/sh...ia-Smog-Legal!
    http://www.bimmerforums.com/forum/sh...tandalone-info
    2003 E46 330i ZHP - Daily Driver | Bike Hauler
    1995 E36 M3 - Autocross | Fun
