Page 3 of 4 FirstFirst 1234 LastLast
Results 51 to 75 of 78
Thread: Stainless clutch line?
  1. #51
    Mar 2013
    South Central WI
    1998 Z3 M Roadster S52
    Quote Originally Posted by roccojugle View Post
    WOW GREAT. Of course yours had a rubber grommet! mine is a steel bracket. NO rubber. haha figures!
    I found a couple photos that I took at this step -
    One is with the rubber grommet removed at the bracket and slid up out of the way. You can get regular wrenches on the fitting but no room to turn. The other pic shows the steel line carefully bent up to a point where the fitting is easy to wrench on. Hope this helps. Not sure if your hose routing and clearances are the same. Good luck!
  2. #52
    Aug 2009
    Boston, MA
    2002 BMW Z3 Coupe 3.0
    you inspired me to finally get out there and do some work (and the fact that its 49 degrees doesnt hurt either). I just inatalled my Ireland Eng clutch line on my 3.0. Fits perfectly, smooth install. Only thing I wasnt aware of when I purhased it is that it completely bypasses the CDV. So I have a brand new Zeckhausen modified CDV that I have no use for. uploadfromtaptalk1394301963375.jpg
  3. #53
    Oct 2012
    Louisville, KY
    1997 BMW Z3 1.9L 5MT
    Quote Originally Posted by ticklemejoviemo View Post
    ... just inatalled my Ireland Eng clutch line... I wasnt aware of when I purhased it is that it completely bypasses the CDV. So I have a brand new Zeckhausen modified CDV that I have no use for...
    I thought one advantage of the stainless clutch lines (IE, UUC, etc) was that they eliminate the CDV and its effect on clutch action. Are there any stainless clutch lines that do keep the CDV?
    BMW MOA 696, BMW CCA 1405
  4. #54
    Aug 2009
    Boston, MA
    see i wasnt aware if that until i looked and realized there was no way a CDV was goingin there. as far as your question now that i look at the designs it seems like this may be the only logical way for them to make these, assuming CDVs were really that much of an issue
  5. #55
    Oct 2012
    Louisville, KY
    ... just installed my Ireland Eng clutch line on my 3.0... smooth install...
    I am curious how you did the bleeding of the line and slave cylinder. Did you use a pressure or vacuum tool, or just gravity? And did you follow the suggestion about removing the slave, inverting it and pressing it against the transmission to bleed it?
  6. #56
    Boiling Springs, PA
    '02 Z3 3.0i 5 speed
    I ended up with the exact same problem.
  7. #57
    Aug 2009
    Boston, MA
    Quote Originally Posted by Vintage42 View Post
    i havent bled it yet. im in the middle of swapping in stainless brake lines also so it is empty. i do have a vacula dx 2.5 bleeder, and thats what i use for my brakes, works great. was going to use it on the slave as well and see how it does
  8. #58
    Aug 2013
    Florida
    Coupe
    I had to take my slave out to bleed it. As soon as I inverted the slave, I heard all of the trapped bubbles go up to the top. Reverse bleeding didn't really work for me, but maybe i didn't do it right.
  9. #59
    Oct 2012
    Louisville, KY
    i havent bled it yet. ... have a vacula dx 2.5 bleeder, and thats what i use for my brakes, works great. was going to use it on the slave as well and see how it does
    The slave apparently can trap air unless removed and inverted. Here posts all giving that tip:
    http://www.bimmerfest.com/forums/sho...80&postcount=5
    http://forums.bimmerforums.com/forum...4#post26602674
    http://forums.bimmerforums.com/forum...2#post16538542
    http://forums.bimmerforums.com/forum...d-clutch-fluid
  10. #60
    Mar 2013
    South Central WI
    I was lucky I guess....didn't remove the slave... just had a helper pump the clutch pedal and bled the air out at the slave. It took several pumps and refilling the reservoir but finally the pedal firmed right up. Its been good ever since. Very firm. I like the feel now after the cdv delete.
  11. #61
    Aug 2013
    Pottsville, PA, USA
    1995 530i E34 sedan
    Quote Originally Posted by Z3MROADY View Post
    Well like you said, I am very far from the e34 forums. My situation is NOTHING like yours. If I was looking at that I would never have even been on here looking for advice hahaha. It was horrible getting this job done. I ended up cutting the lines off, cutting the bracket off, then cutting the whole assembly off a donor car(wish the owner had an account here) and finally got it all cleaned up and put on. what a damn mess!!
    Seriously thank you for the helping words guys!
    Oh, I did the two people-pump pedal-bleed method.
    I dont know if its how others did it but
    with the pedal depressed
    open bleeder
    than close
    then release pedal
    repeat..
  12. #62
    SW Florida
    99-01 M Cpe & Rdts, X5M
    To loosen, or tighten, the fitting connection where the rubber hose meets the steel line, I've never failed to get one loose__or tight__by postioning the two (2) wrenches, so that squeezing them together with one (1) hand produces enough force to crack the fitting loose, or the final nudge for tightening.
    The heads of the wrenches are canted X number of degrees for a reason, usually to rotate half as much as one (1) flat of a six (6) sided nut will allow.
    As far as online shipping rates go, regardless of vendor, You're better off making that phone call. Many use an automated checkout system that automatically calculates the shipping. Imagine my shock when I wanted to place an order for a Shrick intake manifold gasket and shipping was "about" $14.00. Being nobody's fool, I knew that after a long search to find them (crucial to Eurosport Twinscrew work) I decided to get a few spares. Yes, four (4) flat gaskets worked out to nearly $60.00!! I was ordering MLS gaskets as well as some ARP hdwr, and thought my order justified some personalization, and the shipping was reduced to probably less than $20.00 total for the order.
    Call them, these are people who like to talk about cars too...
  13. #63
    Springfield, Ohio, USA
    1998 Z3 Roadster
    open bleeder
    than close
    then release pedal
    repeat..
    Usually, that method of bleeding the clutch is not good enough. You need to squeeze the air out of the slave cylinder by (1) using the special BMW tool, or (2) pressing the plunger against the side of the transmission.
  14. #64
    Aug 2013
    Florida
    Coupe
    Quote Originally Posted by Blacklane View Post
    Yup, I agree with this. I had to do this.
  15. #65
    Feb 2014
    allentown
    99 Z3MC/00' 2.8 roady
    I bought Goodridge g-stop , I like them for my motorcycles so I decided to go with them.
    Sorry I had a brain fart... Goodridge G-stop brake lines and IE SS clutch line. I heard problems with UUC line with where and how it's bent in the hard line doesn't make for an easy connection. No problems with IE and I've had it on for about 2 years now.
  16. #66
    Oct 2012
    Louisville, KY
    Quote Originally Posted by redlinealley View Post
    And what is a Goodridge g-stop?
  17. #67
    Aug 2009
    Boston, MA
    im assuming this http://www.optionsauto.com/prodinfo....r=GR-31003-CLU
  18. #68
    Los Angeles, CA
    2000 Z3M Roadster
    Hey- quick question for the chose the Rogue Engineering stainless steel hose guys- received mine yesterday and I'm too lazy to put my car up to take a look at the old hose, but I thought it would come with some sort of hard-line fitting on one end? Mine is just the flex line with two fixed ends. Just want to make sure that's correct for the //M application before I get under there.
  19. #69
    bartlett il
    blown 98 m roadster
    Quote Originally Posted by mreloc View Post
    <img src="http://www.bimmerforums.com/forum/attachment.php?attachmentid=523599"/>
    Correct part
  20. #70
    Jun 2014
    OlyWa
    02 AW M Coupe
    Anyone here install the Ireland Engineering (IE) SS clutch line? IE claims it has, 'the correct 90 degree angled end (no adapters required).' Honestly, 90 degrees looks more severe than either the UUC line or the non-M line some folks advocate (#21 52 1 159 714). Thanks in advance.
  21. #71
    Oct 2012
    Louisville, KY
    A couple of years ago I bought a UUC stainless clutch line. It seemed a good idea because I assumed my old rubber line was swelling. It was only $30, and a shop installed it for $70 while I waited.
    But getting into 1st gear was harder afterward. This month I had my brake fluid and clutch line bled at another shop. I told them I thought were was air in the slave, and printed out the special instructions for bleeding the slave.
    Now shifting into 1st gear is OK. Be careful that installing a nice hard stainless steel clutch line does not get air in your slave. How would the average shop know that the slave must be removed, inverted, and pressed against the transmission? They will actually question this and resist it.
  22. #72
    Jun 2014
    OlyWa
    02 AW M Coupe
    Vintage42 - Thanks for jacking my inquiry to share your experience with a different product. I’ve reached out to the one identified IE user, ticklemejoviemo. Anybody else?
  23. #73
    Oct 2012
    Louisville, KY
    I apologize. My post was not meant to be about a particular product, but about the problem of bleeding the slave cylinder when any clutch line is installed. I posted it as #59 earlier in this same thread, and thought it was OK to repeat it.
  24. #74
    Feb 2012
    MN
    1997 z3 roadster
    Quote Originally Posted by DBWard View Post
    You may want to start your own thread.
    It's a Hybrid--Burns Gas and Rubber
  25. #75
    Jun 2017
    Portland, OR
    99 M Roadster
    I bought and installed the Ireland Engineering stainless clutch line and have had zero problems with it. My car had a squishy old rubber line that worked fine cold but shifts became increasingly difficult as the car warmed up, especially if I had to sit in traffic. I decided to roll the dice on bleeding it with my pressure bleeder and a helper instead of removing the slave - it's been working great since then with zero mushiness.
