Results 1 to 6 of 6
Thread: Sunroof drains and others to be checked - location pics
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    The drain hoses are going thru the A-pillar and in the rear thru the C-pillar, here pics from an sliced E32 where you can see it
    http://twrite.org/shogunnew/upgrades...nd_dicced_E32:
    Note: the other pic links removed in 03/2024
    Then there are drain holes in the area under the wiper motor area to drain off the water which comes thru the fresh air grills above the blower motor
    http://i44.servimg.com/u/f44/14/94/56/00/ablauf10.jpg
    One of the drain holes in the sunroof area
    http://i64.servimg.com/u/f64/14/94/56/00/dsc01510.jpg
    To check if the area under the doors in rocker panel area is full of water or if the drain holes are clogged, you can remove the door sill cover and check here with a flashlight
    http://i34.servimg.com/u/f34/14/94/56/00/korros10.jpg
    Sliced area to show where the drain hole ends in rocker panels right and left
    http://s71.photobucket.com/albums/i1...fSchweller.jpg
    Another thing to check the drain hole inside the e-box at the lowest point (where DME etc are located in engine room), there have been reports that these drain holes got clogged and expensive electronic devices like DME got damaged.
    Drain from area where wiper motor is located, here the IHKA unit is also going thru the firewall into interior room, if these holes are clogged, you get water into the interior.
    http://i44.servimg.com/u/f44/14/94/56/00/affnun10.jpg
    Drain hose connections sunroof
    http://bmwfans.info/parts/catalog/E3...ng_roof_drive/
    The hole in the fiewall for IHKA and also the drain hole outside is shown here
    http://www.bimmerboard.com/members/take/P1030372.jpg
    rubber plugs in floor can slip out
    http://www.bimmerboard.com/members/t...l/P1020853.jpg
    here better to be seen, as well as one of the 2 drain holes for the IHKA under center console
    http://www.bimmerboard.com/members/t...l/P1020855.jpg
    holes towards engine room and the second drain hole IHKA seen from driver side.
    http://www.bimmerboard.com/members/t...l/P1020859.jpg
    If someone has more pics or hints where to check for clogged drain holes etc., please post them, then we have a detailed list.
    In the trunk bottom on left side towards fender of my E32 are rubber flaps which lead the air from interior room thru the holes under the rear parcel shelf thru the trunk to the outside. Have no pics of these flaps.
    Some pics are from E34, but basically the same.
    May 2012
    Boynton Beach, Florida
    1990 735I (E32) M30
    http://i71.photobucket.com/albums/i1...frontclip4.jpg I'm glad I finally have a picture of what you need to do, to be able to get to the heater box........when those flaps aren't working properly.
    Jan 2005
    Japan
    One more possible leaking area, Water coming from e-box cooling fan into footwell
    http://www.bimmerforums.com/forum/sh...ght=drain+hole
    Richmond, Virginia
    '88 735i, '06 RSX
    We need to store this pictures in a zip or on a google drive so that they do not go missing, this is valuable information.
    Jan 2005
    Japan
    Some good cut off sections from E34 where the drain hoses end , also how they modified the drain holes, from the German E34 forum https://forum.e34.de/thread.php?thre...ht=schiebedach
    very long thread, go thru all pages and see for pics, they were posted over several years in this thread. Same design as on E32.
    Here the pics of the modification on E34 with extended hoses going out of the sills , hope you can see the pics w/o being logged in/registered https://forum.e34.de/thread.php?thre...iebedachablauf
    Jan 2005
    Japan
    1 more pic, water coming in thru the plastic covers under the windows into the area where the wiper motor/system is and the inlet flaps for the IHKA system, that is normal, water should then drain into the wheel wells of front fenders on each side, these small ports can clog, causing water to accumulate in that area and then enter thru the sealing of the IHKA housing in the firewall into the area where the IHKA is located behind the center console
    better download all pics of interest, some links in the first posts are already no longer working. Photobucket, imageshack etc
