Page 9 of 10 FirstFirst 12345678910 LastLast
Results 201 to 225 of 230
Thread: Post Pics of Your Hard Motorsport 330 E36 Coupe Rivet on Fender Flares
  1. #201
    Jul 2015
    Madison, WI, USA
    1999 E36 M3, 2013 135IS
    Quote Originally Posted by busterhax View Post
    Sounds like your fenders need chemo, not flares.
    Offset is in the equation too but I'm sure it will look stupid either way without spacers.
    Thanks Buster.
    Cancer = Rust.
    It's not a pristine car so I don't mind cutting it to put the flares on. Spacers are an option unless I'd need something crazy to make it look "ok". I do autox and HPDE it so nothing too crazy as far as spacers.
  2. #202
    busterhax's Avatar
    busterhax is offline Y̝͎̘̍́ͣ̉͑̿̆Ō͎̼̺̬̒ͯ̃̇͗̂ U͈̖
    Jun 2006
    NYC
    e36
    Use willtheyfit.com and find the specs someone with flares are running and you can compare to see how much spacer you'll need.
  3. #203
    Del a Where?
    LSx M3 & 2017 Touareg
    My buddies 95 M3 track car has them.
    Few photos I snapped
  4. #204
    Oct 2007
    sterling hts, michigan
    02 M3
    Crap phone shot
  5. #205
    Del a Where?
    You guys match haha
  6. #206
    Joliet, IL
    Out of Service
    Anyone running 285+ tires on 17's with V2? Debating if I want to get these or go with felony form. I'd like to run a 285 or larger rear tire, if possible, on a 17" rim. Just wondering people's experience so I can figure out what offset and rim width I should go with
    Sent from my SM-T707V using Tapatalk
  7. #207
    Oct 2007
    02 M3
    I have V1 rear flares. 275 on a 17x9,5 +35 fit with minimal issues, especially with -2.5 camber. I have 10mm spacer back there now and still clear perfectly fine with the 275. A 285 on a 10" rim should fit fine IMO especially on the wider V2 flares.
  8. #208
    Dec 2015
    Los Angeles
    BMWs
    such track, very meat, so rivet.
  9. #209
    Vancouver, BC Ca
    1993 325is
    What 285 tire are you looking at in 17"? I know 285/30-18 is a viable size, but anything more than a 285/35-17 would be quite big in overall diameter and a difficult fitment. I have 275/35-17 Hoosier A6s (kind of wide for the size) on et31 10.5" wide rims and with no spacer and it BARELY clears the V1 flares which have had all the inner edge of the flare lip removed, as well as some massaging of the inner sheet metal around the strut.
  10. #210
    Dec 2005
    corpus christi, tx
    e36 m3, f30 335i
    Finally got to cutting the front fenders and riveting on the front flares. I had trimmed the front portion (for a cleaner look) so that it does not go over the nose panel edge.
  11. #211
    SOCAL
    IG: Clearsandadrop
    Quote Originally Posted by bmdubbayoo View Post
    Looks great, I was never a fan of the original front flare design.
  12. #212
    I agree, looks amazing with that front part trimmed
  13. #213
    Granite Bay, CA
    A Few
    That looks great trimmed!
  14. #214
    Florida and ATL
    1999 M3 and 1990 Jetta G
    That looks so much better!
  15. #215
    Norway
    E36 And E21
    My brothers 328I
  16. #216
    Dec 2002
    Broward, FL
    I take the bus to work.
    Quote Originally Posted by m3mobbin View Post
    thats how it should be...
    -M3J0N
  17. #217
    Hercules, CA
    1999 COSMOS M3
    That looks awesome! More pics please!
  18. #218
    Jan 2003
    Charlotte
    Ok I have to say I just received my V2 Hard motors ports flares they look a lot better in person. Im gonna fit 295/30/19 with obviously some slight modifications. Dropping off wheels to be built today. for some reason I cannot post an image
    1998 Turbo M3 Nick G tuned setting 5 934Whp 849Wtq @27.88 Psi. ignite E90 setting 6=
  19. #219
    Dec 2005
    corpus christi, tx
    e36 m3, f30 335i
    Quote Originally Posted by SAL's M3 View Post
    Thanks, here's a few more.
  20. #220
    Miami, FL
    98 M3 S54 coupe
    That looks so good! What are your wheel specs with the flares? v2 I assume?
    1997 Estoril/Dove M3 sedan (62k miles)
    1999 Imola/Modena M3 coupe (1 of 2) S54 swapped
    2002 Estoril/Black M3 coupe (Individual)
    2007 Mercedes-Benz E63 AMG (500hp daily)
  21. #221
    Sep 2015
    ontario canada
    bmw
    Beautiful stuff!
  22. #222
    Dec 2005
    corpus christi, tx
    e36 m3, f30 335i
    I haven't upgraded to wider tires/spacers yet, so what you're looking at are V1 flares with 17x9.5 Apex wheels with 245/40 Hankook RS3s.
  23. #223
    Vancouver, BC Ca
    1993 325is
    Bit of an upgrade on my car. Still V1 flares, but the fronts have 1/4" spacer between the flare and the fender. The rear is more like 3/8" now. Wheels/tires are 285/30-18s with 18x10.5 29mm offset. No spacers in the back, 20mm in the front. I'll be changing the camber setup in the front soon which should allow me to come down to 15mm spacers. Still just a hair of rubbing on the front of the left rear flare. It might need a bit of trimming or maybe I need another 1/8" of spacer in the back.
  24. #224
    Aug 2003
    Charlotte, NC
    99’ M3
    I'm in love with your car man!
  25. #225
    Sep 2013
    Omaha, NE
    1995 E36 M3 Coupe
    I have a question about installing the rears and have attached a picture. Obviously, you cut out the section in the red box and the rear bumper can be pulled-out/shimmed to make room for wider tires/wheels. However, what about the part in the green box? To me, it seems like the wheel/tire would hit it if you DON'T cut that part out but it seems like a lot of people don't cut that area? Does the nature of the suspension travel more or less allow the area to not come into contact with the wheels?
    http://imgur.com/a/L2Aaq
