Heres mine, great product. I am also rocking Hard's centerlock wheels!!! Before, during and after...I am new here..not sure how to post pics,...sorry
https://instagram.com/p/zklPe4x80x/?modal=true
https://instagram.com/p/zklLn3x80o/?modal=true
https://instagram.com/p/zklF_xR80Z/?modal=true
https://instagram.com/p/zOCiLxx8yu/?modal=true
http://instagram.com/p/zODI7ox80D/?modal=true
https://instagram.com/p/zN_KfhR899/?modal=true
Love functional track usage. What headlight duct is that?
Just ordered a set from the over here in the UK, can't wait for Mr ups man to turn up!
Just wondering if I should have gone v2 now....
275/40-17 on 17x9,5 +35 arc 8, +20 front to clear coilovers. -2.6 all around
Thanks! With a bit of trimming, no rubbing My bumper alignments are way off due to being removed and installed 10+ times, so the flares didn't fit so well. Nothing a little bit of snips can't fix Rear was good to go, no trimming. May have to though if I decided to dial out some camber.
www.facebook.com/Undr8dEmpireLlc Instagram: @UNDR8D_EMPIRE
Scarlet V2 - #Project333Ti - http://www.bimmerforums.com/forum/sh...(-Project333Ti)
I'm going to be running 275/40R17's on a 17x10.5 et13 wheel with a 12.5mm spacer. Just wondering if anyone could provide some insight as to whether or not the V2 flares would cover everything?
Thanks.
All around, or just out back? Also, you want to run a 17x10.5 et 13 wheel at essentially et0 with the 12.5mm spacer? Or you're achieving the et 13 from using a 12.5mm spacer on an et25.5 wheel? That's a very tall tire and more than likely won't fit unless you're 4x4 height. To fit out back, you will need to run max camber, modify the bumper for clearance, cut the entire inner lip of the flare, etc. Up front if you're at et13 you will need to run max camber, modify the bumper for clearance, cut the entire inner lip of the flare, and I don't even know if that will be enough. If you will be at et0 all around, these flares are not for your application. Even at et13 all around, a 275/40 is a tall tire, even for a 10.5. A 255/40 would be more realistic, and still require a lot of modification and dialing in, but JakerMac got it to work with heavy modification of the V1 flares (on the V2s, only the rears are wider).
Thanks, hopefully I can remember this when I start my E36 project. What is the widest tire that will fit under it and what modifications have to be made to the quarter panel?
Would you consider making these for an e34? I think they would look killer and sell rather quickly.
Moar pics of the ti
― George Orwell
I like these fenders, however I do not like the little extra material that covers the side of the nose panel. Takes away the sharp line look and doesn't look as fluid. Im sure it can be fixed, but that's just me
Posting my build thread soon as the car is finally coming to completion.
It's got a worked, bolt-on s52, zf 5 speed, full z3 mcoupe suspension and brake, TC Kline Dual adjustable coil-overs, etc. Interior is currently coming together, but it's mainly black mill point, with Bride Cuga reps (soon to swap out because the GF hates sitting in them)
Soon my friends, soon
Pics of the new Wider flares installed ?
1996 332IS
Built 3.2
Technique Tuning 80# tune.
1/4 mile 10.84 @ 136.72
WWW.CESMOTORSPORT.COM
Now only if these could bond to Plutoian materials
― George Orwell
