Page 6 of 10 FirstFirst 12345678910 LastLast
Results 126 to 150 of 230
Thread: Post Pics of Your Hard Motorsport 330 E36 Coupe Rivet on Fender Flares
  1. #126
    busterhax's Avatar
    busterhax is offline Y̝͎̘̍́ͣ̉͑̿̆Ō͎̼̺̬̒ͯ̃̇͗̂ U͈̖
    Jun 2006
    NYC
    e36
    Quote Originally Posted by m3j0n View Post
    can you explain how the flares increase wheel/tire clearance? do you just have to cut the fender?
    Essentially yes.
    The fronts you cut and rivet on. Seal the metal where necessary for rust preventative purposes.
    The rear you *can* just cut and rivet but the quarter panel will be weak. What most do is cut, then tac weld the inner sheet metal to the outer sheet metal for strength. Then seal it all up.
    I had my old fenders baseball batt rolled to the point where they were perfectly flat and stuck out 45 degrees from the body. These flares stick out a bit further than that on the edges and allow more room for tire inside of the flare.
    The only fitment issue I have is the left and right edges of the wheel wells. This is only an issue for going flush, not performance. My 265/35/18s (on a 18/9.5 et36) required me to do quite a bit of dental work to the edges of the rear bumper where it meets the flare. My fronts took a bit of dental work to the ends of the nose panel and the flare where it meets the nose panel.
    You'll notice most people with these flares have the car at a reasonable performance ride height or they will be pretty low with the wheels tucked in. If there was some sort of bumper attachment similar to the Rocket Bunny flares, I think it'd be a piece of cake fitting a fat 18" tire in there.
    Notice if the wheel is spaced out to be flush for aesthetic purposes, it would interfere with the bumper.
  2. #127
    May 2014
    NC
    A few
    Anybody have a good pictorial DIY for this? Think we know what all is involved but a picture of two from an existing install would help greatly.
  3. #128
    Oct 2007
    jacksonville, fl
    e36 m3 Ls2, 318I, 325is
    Quote Originally Posted by LandR View Post
    I got lots of pics on my instagram @o_mateo of the install process on my car..
  4. #129
    Bay Area, CA
    97 328i, 07 335i
    Would love to see sedan ones. I'm itching to pull the trigger on these!
  5. #130
    Apr 2008
    Spokane, Wa
    '97 M3/2/6 '01 996tt
    Quote Originally Posted by Chowbow View Post
    http://www.hardmotorsport.com http://Facebook.com/HardMotorsport
  6. #131
    USA
    Lotsa ///M's
    A few more!
    Current:
    15' F82 M4 (soulless beast)
    12' e92 M3 (clean daily)
    09' e92 M3 (track whore 3.0)
    06' E46 M3 (ZCP YUM)
    02' e36/8 M coupe
    01' e36/8 M coupe (the chosen)
    99' e36 M3 (spoiled)
    99' e36 M3 (track whore)
    99' e36/5 (chump 2.0)
    95' e36/5 (chump car)
    90' e30 M3 (track whore 2.0)
    88' e30 M3 (Diamondschwartz eurospec)
    88' e30 M3 (broke my wallet)
    And a few P-cars nobody on here cars about lol
  7. #132
    USA
    Lotsa ///M's
    I found so many pics of this car today. I need to frame a few of these and put them up around my garage.
    Current:
    02' e36/8 M coupe
  8. #133
    Apr 2008
    Spokane, Wa
    Looks awesome as usual!
  9. #134
    Apr 2008
    Spokane, Wa
  10. #135
    Florida and ATL
    1999 M3 and 1990 Jetta G
    That livery looks neat!!
  11. #136
    Jul 2002
    Covington, Ga
    08 535i, 95 540 MSport
  12. #137
    Apr 2008
    Spokane, Wa
    Quote Originally Posted by e34biturbo View Post
    do u make these for e39
    Sorry we don't
  13. #138
    Apr 2008
    Spokane, Wa
  14. #139
    Compactive's Avatar
    Compactive is offline Helpful. BMW CCA Member
    Moderator
    DMV
    3x 318ti
    would love to see some more!
    Want a custom signature? Post requests here, or PM me here | My Flickr
  15. #140
    Jan 2015
    m3
    m1
    Those corvette brakes work just right with the LS swap, well done!
  16. #141
    Apr 2009
    Pittsburgh
    99 M3 LS1, '11 WRX
    I want to run 285/30s on 18x10 et 25 apex arc8's on all 4 corners. Anybody have any experience with how well that wheel setup would fit with these flares on a coupe?
  17. #142
    busterhax's Avatar
    Jun 2006
    NYC
    e36
    Quote Originally Posted by ckpitt55 View Post
    You'll have to keep the car high up and have some super negative camber to pull that off.
    I'm pretty low right now and have absolutely no more room for meat at -2.7 deg camber. Here is how that will compare to where I'm at. Also, I have a 10mm spacer up front, no spacer in the rear.
    http://www.willtheyfit.com/index.php...et2=25#content
  18. #143
    Apr 2009
    Pittsburgh
    99 M3 LS1, '11 WRX
    ^^ you're probably a good bit lower than I'm going to be, but even at the raised height that seems like it'd still be pretty aggressive. maybe a 275/35 on a 9.5 would be a better fit.
    Clean install, btw.
  19. #144
    Apr 2008
    Spokane, Wa
  20. #145
    Apr 2009
    Pittsburgh
    99 M3 LS1, '11 WRX
  21. #146
    Los Angeles, CA
    #Project333Ti & Z3 Coupe
    Thanks to Adam, I had the first set of Ti flares installed on my project a few months back by Kings Auto Body Shop. They fit great and gave me the room I needed after I removed the entire inner lip of the flare (it's at least 3-4mm thick, which leaves a lot less room for full use of the added space).
    Here are some teasers, I have a full build thread I will be posting for the car once I'm done with the car showing the stages of the flares.
    Car is FAR from done! Front will be coming down at least an inch with shorter springs and I'll space the front wheels out at least 10mm.
    Fitment notes - I'm running a full Z3 M-Coupe suspension, which sits the wheels at least 4mm further out on each side vs. a stock Ti rear. I'm going to test fit a friend's wheel set-up from his Ti to see how much a difference it actually is.
    Wheel and tire specs:
    AC Schnitzer Type 2: 17x8.5 et 15 front with 235/40/17 Nexen N8000; 17x9.5 et 21.5 rear with 245/40/17 Falken FK453
  22. #147
    Oct 2007
    jacksonville, fl
    Old shot... love these flares..
  23. #148
    NY
    skateboard
    Quote Originally Posted by busterhax View Post
    Essentially yes.
    Very clean. Which rear wing is that?
    ― George Orwell
  24. #149
    Not sure if I hate it or love it... the fenders I love, the body color makes em look great. But the wheels are great... but also horrible?
    Nah, I think I love it. Nice car
    PRICE CUT on ALL FABRICS
  25. #150
    busterhax's Avatar
    Jun 2006
    NYC
    e36
    MA Shaw wing
