with the stock ccv pipe on the stock obd2 valve cover open to atmosphere I saw anywhere from 1 to 3.5 psi in the crank case. this was on a boost from 8 to 15. not sure if that is normal but supposedly my motor was driven by a little old lady from pasadena very gently for 70k.
I'm thinking the same thing about WG. Bigger and better is what I need. Actually, next time I pull the manifold off, I may rework the front WG runner some.
that seems high. I should check mine CC pressure too, maybe this weekend....
The above is what I am seeing boost wise as well as exhaust pressure. The pressure tap for the exhaust is about 3" from the waste gate. My WG pipe is about 15" OAL. So in reality I'm just measuring WG pressure.
Other tidd butts when I logged the pull: outside temp = 37-degrees f, third gear pull, 5# wg spring, 100% methanol up to 6 1/2 psi then a little gasoline injection pre throttle body.
WOT
I was thinking it was high too. I know that somewhere around 2.5 in the crank case I start blowing oil. I know the oem cyclone separator will not allow the intake to pull more than 10 inches of water column at sea level before it snaps closed and waits for more crank pressure.
I guess it is hard to keep your boost at low levels because your huge turbo is almost no restriction at about 5psi. So if the gasses can go through the exhaust wheel and exhaust without any resistance, they will be hard to redirect. Bigger wastegate could help to some point but the main problem (imo), is that the exhaust side of the turbo is too big (at least for running low boost levels).
Low boost systems should have properly sized turbo. Flow path between turbine discharge and wg cross section needs to be consideted. Unfortunately I have not seen a formula to calculate so ready world experience is all I got. This is why restriction in the exhaust, post turbo, will help build pressure against the cross section of the turbine wheel. In that scenario it will be easy to control boost as the wg becomes the route of least resistance. Un cork the exhaust and you may get run away on a less than ideal setup. I will add this chassis makes anything ideal hard.
I agree guys. When I first started looking at the WG routing on my manifold, I contemplated not attaching the front bank to the WG. The reason I was thinking this was after looking at my HX35 internal WG turbo where it only dumps exhaust on the back side, I thought I could get away with it. However, I never ran the HX35 at less then 24 psi on my 1.8 L.
Obviously I didn't go down this rout, and I could of routed the front bank a lot better on my first manifold. It jets off the main pipe at a 90-deg then has a nother 90-deg turn before it transitions into the larger pipe. Again, it's not a big issue for me now that I have additional fuel for this creep. In fact, for those that have ran a few pounds of boost creep, it feels quit good revving it up to redline.
Specs on the turbo are:
72.4 / 102.9 mm compressor
79.0 / 68.4 mm hot side with a .84 AR.
The bad side to running an eBay turbo, is the inability to view a compressor map on it. I wonder how far it is from a true T72.
WOT
Just to clear any confusion, I am still running my first black carbon steel manifold and not the new stainless one.
You can see how I improved the front WG piping on the SST version.... Maybe this summer we will see if the stainless one has creep.
I checkEd my Crank case pressure this morning At 9 psi boost I am reading 1/3 psi give or take. The only mod I did on the CCV is drill out the hole to 1/2" and attached a 5/8" hose to a catch can. Warning to the FI crowd, don't buy an engine driven by granny.
WOT
lol, good point.
My granny got me too, valves meet piston kinda thing.
By no means did I believe that a granny drove the car, the stereo and subs were for sale in the same add. But at least I got a good trans and bottom end (as far as I can currently tell. )
Finally finished my exhaust, and boy, why did it take me so long. Adding a muffler to the WG dump tube is a no brainer, and soooooooo much quieter, I love it. It's like a new car, again, still slow, but it's so nice to be able to hear the 72mm spool up. Fun times are ahead!
WOT
So I was messing around the other day, taking some video's of the car and thought this was interesting.
WOT
I decided to buy in bulk. Works out to be about 60 cent per gallon less then 87 pump gas.
WOT
Is the tire getting skinny like a street bike tire?
What tire are you running out back?
You know the nice thing about those tires is that they are pretty quiet whil spinning! Lol
So I went to the strip last night and made one pass before she broke sitting in the pits.
More on the broke later on, as I've been dressing her up a little by adding a two stage direct port methanol system.
I also installed a second walbro on my methanol fuel system.
Added an ACT 6-puck unsprung clutch. Grabby to say the least.
I also added a resistor to the yellow wire on the HFM and installed some 24# ford injectors in place of my stock 17.5# injectors, (note, I'm not sure if stock S50 injectors are 17.5, but it really doesn't matter to me at this point lol). The reason for this was to eliminate the CEL under boost. Previously, the CEL would come on at 5200rpm under boost, a mass flow error. Now with the larger injectors and resistor, my DC is reduced so now I can run 40 to 45 psi on the methanol side instead of my prior 30-ish. Any who, I believe I have much more control of fuel delivery under boost.
The above shows the modification to my intake to add the 52# injectors, thus making M&M a dual fuel car. Pump gas for daily driving, then flip a switch for 100% methanol boost action.
So with the above updates, I removed the 5# WG spring and installed the 10# spring and went to the races to do some much needed fuel tuning. AFR under boost are in the 10's, but she runs well even being this rich, (gauge reads lambda 1 @14.7 gasoline).
First hit of the night, I run the 96 mph, dismal time, but fast, which is really what I was looking for as my number 1 goal for that night was not to break, besides not hurting anybody. So I pull back to the pits after weighing her, talking to the Z owner with our hoods up, cooling the motors down. He asked me where my intake was and I'm pointing down to where it is when POP, fizzzz.
I can't believe it, my expansion tank blew, right there an then.
Fortunately, nobody got burned. Fortunately it didn't break on the track. And fortunately, I was able to tape up the tank And drive it home running on methanol, heater blowing full blast.
WOT
What's with clean look? No more dirty engineering? Lol. Nice trap speed! You've got a roll race monster now. It must be something special going on this week because I developed a crack in my gas tank. It's fun driving around spraying gas all over a hot exhaust pipe. In no way is that dangerous lol.
335i with a PT5858 stuck on it.
