Results 1 to 6 of 6
Thread: Compairing ZF4HP22 tranny
    Dec 2012
    Granbury, Texas
    1988 BMW 735i
    I have to choose to replace or rebuild my trans on my 735i and i located a used ZF4HP22GE, and my E32 has ZF4HP22YM.
    Can anybody tell me other then the shifter select button on the GE is marked A,M and the YM is marked S,M, are these interchangable
    and what is the diff, should i expect troubles if i swap the two ? my trans is also a 8 pin plug i dont know what the GE trans is.
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    Here is some info on transmissions used in BMW
    http://www.ge39.com/files/electran1%2B2.pdf
    8-pin plug is the older one and there I only find 1 info how to convert from 8-pin to 7-pin
    http://bmwe32.masscom.net/johan/gear...rbox_swap.html
    But I do not exactly know what GE means for ZF 4HP22
    http://www.zf.com/na/content/media/u...sscartrans.pdf
    here is some info
    http://forums.bimmerforums.com/forum...22-Differences
    What is mostly mentioned, best is to use the same transmission control unit, always transfer trans and the control unit into the other car, plus wire loom if necessary.
    Hamburg, NY USA
    e23, e32, e34, e39
    Plus the applicable tranny switch either s/m or a/m.
    I used a 92 tranny in my 6/88. Tranny, TCU and a/m switch went into my car. So grab them all from the donor, if available. With the s/m switch, it wouldn't shift correctly. If at all, I can't remember. The wire harness is the same, just one pin isn't used on the 7 pin models.
    Jan 2005
    Japan
    In case you need repair manuals, ZF has the following:
    Repair Manuals
    Transmission...... Description....... Where used................ ZF Part # .................Language .......Old ZF Part #....... Notes
    4HP14 4HP14... Repair Manual....... All 1036 000 ___......... 1036 751 101......... English
    4HP22 4HP22... Repair Manual.... (BMW) Certain 1043 010 ___.. 1043 751 110.. English
    4HP22 4HP22.... Repair Manual ....(PSA) Certain 1043 010 ___... 1043 751 111... English
    4HP24 4HP24..... Repair Manual............................................ Currently not available
    4HP24A 4HP24A... Repair Manual............................................ . Currently not available
    5HP18 5HP18....... Repair Manual...... All 1056 000 ___..... 5HP18REP........ English...... 1056 751 101
    5HP19 5HP19 Repair Manual All 1060 000 ___ 5HP19REP English 1060 751 101
    5HP19FL 5HP19FL / FLA Repair Manual All 1060 030 ___ 5HP19FLREP English 1060 751 102
    5HP19FLA 5HP19FL / FLA Repair Manual All 1060 040 ___ 5HP19FLREP English 1060 751 102
    5HP19HL 5HP19HL Repair Manual Currently not available
    5HP19HLA 5HP19HLA Repair Manual Currently not available
    5HP24 5HP24 Repair Manual All 1058 000 ___ 5HP24REP English 1058 751 101
    5HP24A 5HP24A Repair Manual All 1058 020 ___ 5HP24AREP English 1058 751 102
    5HP30 5HP30 Repair Manual Certain 1055 000 ___ 5HP30REP English 1055 751 101
    6HP26 6HP26 Repair Manual (CD Version Only) All 1068 010 ___ 1068 766 702 English
    6HP26 A61 6HP26 A61 Repair Manual (CD Version Only) All 1068 030 ___ 1068 766 703 English
    6HP19 6HP19 Repair Manual (CD Version Only) All 1071 010 ___ 1071 766 701 English
    6HP19A 6HP19A Repair Manual (CD Version Only) All 1071 040 ___ 1071 766 702 English
    Functional Descriptions
    4HP20 4HP20 Functional Description (MB, PSA, Renault) Certain 1019 000 ___ 1019 754 101 English
    5HP18 5HP18 Functional Description All 1056 000 ___ 5HP18FD English 1056 754 101
    5HP19 5HP19 Functional Description All 1060 000 ___ 5HP19FD English 1060 754 102
    5HP19FL 5HP19FL / FLA Functional Description All 1060 030 ___ 5HP19FLFD English 1060 754 101
    5HP19FLA 5HP19FL / FLA Functional Description All 1060 040 ___ 5HP19FLFD English 1060 754 101
    5HP19HL 5HP19HL / HLA Functional Description Currently not available
    5HP19HLA 5HP19HL / HLA Functional Description Currently not available
    5HP24 5HP24 / A Functional Description All 1058 000 ___ 5HP24FD English 1058 754 101
    5HP24A 5HP24 / A Functional Description All 1058 020 ___ 5HP24FD English 1058 754 101
    5HP30 5HP30 Functional Description All 1055 000 ___ 5HP30FD English 1055 754 101
    Valve Body Information
    All 5-Speed 5-Speed Valve Body Manual All 5-Speed 5HPVBMAN English
    Wall Charts
    4HP14 4HP14 Wall Chart - Explosive Picture (Peugeot) All 1036 000 ___ AAAAZFS014 English
    4HP18 4HP18 Colour Wall Chart All 1050 000 ___ 1050 764 701 Eng/Ger
    4HP18 4HP18 Wall Chart - Explosive Picture (Saab) Certain 1050 000 ___ AAAAZFS017 English
    4HP20 4HP20 Wall chart Wall Chart - Explosive Picture All 1019 000 ___ 1019 764 001 Eng/Ger
    4HP22 4HP22 Colour Wall Chart All 1043 010 ___ 1043 764 702 Eng/Ger
    4HP22 4HP22 / 24 Wall Chart - Explosive Picture All 1043 010 ___ AAAAZFS016 English
    4HP24 4HP22 / 24 Wall Chart - Explosive Picture All 1043 030 ___ AAAAZFS016 English
    5HP18 5HP18 Colour Wall Chart All 1056 000 ___ 1056 764 701 Eng/Ger
    5HP18 5HP18 Wall Chart - Explosive Picture All 1056 000 ___ AAAAZFS018 English
    5HP19 5HP19 Wall Chart - Explosive Picture All 1060 000 ___ 1060 764 001 Eng/Ger
    5HP19FL 5HP19FL / FLA Wall Chart - Explosive Picture All 1060 030 ___ 1060 764 002 Eng/Ger
    5HP19FLA 5HP19FL / FLA Wall Chart - Explosive Picture All 1060 040 ___ 1060 764 002 Eng/Ger
    5HP19HL 5HP19HL / HLA Wall Chart - Explosive Picture All 1060 050 ___ 1060 764 003 Eng/Ger
    5HP19HLA 5HP19HL / HLA Wall Chart - Explosive Picture All 1060 060 ___ 1060 764 003 Eng/Ger
    5HP24 5HP24 Wall Chart - Explosive Picture All 1058 000 ___ 1058 764 001 Eng/Ger
    5HP24A 5HP24A Wall Chart - Explosive Picture All 1058 020 ___ 1058 764 002 Eng/Ger
    5HP30 5HP30 Colour Wall Chart All 1055 000 ___ 1055 764 701 Eng/Ger
    ATSG repair manuals are available from their bookstore https://www.atsg.us/atsg/
    Feb 2019
    Richmond
    BMW 528i
    Hey guys.. this is my first post!
    Talked to zf today and they dont have any of the repir manuals. Can anyone help me with these
    1060 751 101
    1060 754 101
    1060 764 101
    Thanks. Bunch!
    Jan 2005
    Japan
    check with Eriksson, they list it http://www.erikssonindustries.com/ZF...nsmissions.htm
    technical documentation 5hp19
    repair manual 1060 751 101
    functional diagram 1060 754 101
    wall chart 1060 764 701
    they have it partly online
    http://www.erikssonindustries.com/ZF.../5hp19sch1.htm
    valve body http://www.erikssonindustries.com/ZF.../5hp19sch3.htm
    https://zftranspart.pinnaclecart.com//
    My Cars: BMW 528i
    pls add model and built year/month
