Page 5 of 13 FirstFirst 12345678910111213 LastLast
Results 101 to 125 of 302
Thread: Instead of knocking up girls, secretly paying a shop to build...... The Zackmobile
  1. #101
    Mar 2012
    Lansdale, Pa
    98 540 6, SC'ed, 16psi
    Quote Originally Posted by daandaman View Post
    Actually I was not aware of these valves... I just knew of the in line mounted ones. Im not sure about how these units operate and how 'smooth' their proportional to the front pressure functionality is... why would people still mount twin master cylinders with balance bars then, and wilwood produce them?
    I called willwood today. The tech there said they do provide proportional pressure control down low, but I'm not sure the guy I spoke to was the "lead" engineer at the place. Do some research and see what you find. I suggest doing anything besides gluing sleeving into the caliper bores. New master?
  2. #102
    Dec 2011
    Holland, bish!
    Euro e36 M3 3.2 cabrio
    Quote Originally Posted by philly98540 View Post
    I had a call with them as well, the guy explained me that the rears wouldn't do much upwards to 100psi brake fluid pressure, and then gradually increase proportionally. It works with some sort of chamber with a piston that closes a needle valve. Not yet convinced of the operation and suitability. I like to have braking force on the rear as well, at lower brake forces. When there is snow or ice for instance.
    Funny, Tein apparently sells or sold the same technology I want to produce; twin tube damper with external reservoirs. Gathering parts atm.
    http://www.rallyxd.com/parts/tein/index.html
  3. #103
    Dec 2011
    Holland, bish!
    Just ordered 4 internal floating piston reservoirs made by Fox from Evan @ http://www.schmidtyracing.com/ who was really super helpfull!
    They have a 2" x 6" steel body with a Schrader valve on one end for the nitrogen filling. On the other end is an O-ring boss thread female fitting.
    It will look somewhat like these, albeit much shorter:
    and I will have to decide on mounting location, which will determine what kind of hose/connection/piping I will use. When on the shock I could use piping or a short hose with normal hose ends, when on the car, depending on where maybe with swiveling banjo's made by Goodridge, like on these pictures:
    But then only on the shock body. They are quite expensive at around 80 USD each so...
    Got a fitting tool
    Time to stirr things up a bit... and tame down the generally accepted awesomeness.
    Because...
  4. #104
    Dec 2011
    Holland, bish!
    Damper reservoirs came in:
    Now I need to figure out, with the large wheels and calipers mounted, if there is place to attach them to the damper bodies or if I need to remote mount them (with a piece of dash 5 hose)
  5. #105
    Apr 2012
    Tampa, FL
    E36,E38, and E46
    After the necessary calculations with quite some help of a friend from the UK who basically has a master degree in e36 braking, and some nice spreadsheets, I now know that the rear calipers have too much piston surface. Fronts are very good actually, only about 4% more surface. For informative purpose: Audi R8 ceramic caliporce the retaining solution must be able to resist. I was thinking about mechanical retaining (with a cleverly designed snap ring or something) and by gluing with a specialized polymer. I wish to not machine the caliper. For information; the wall thickness of the sleeve, at the height of the oil seal, is about 2mm. Anyone ideas?
    so you are trying to decrease the piston diameter or increase?
  6. #106
    Dec 2011
    Holland, bish!
    Quote Originally Posted by bry195 View Post
    Decreasing.
  7. #107
    Mar 2012
    Renton, Wa
    98 m3
    Are you still doing those shenanigans instead of getting the proper master...?
    1989 535i - sold
    1999 M3 Tiag/Dove - sold
  8. #108
    Dec 2011
    Holland, bish!
    Decreasing.
    Quote Originally Posted by vollosso View Post
    You tell me what solution there is; i need to:
    Retain brake booster, go 50% lower in braking force on the rear.
    I have yet to find a tandem cylinder that outputs different pressures front and back
  9. #109
    Apr 2012
    Tampa, FL
    E36,E38, and E46
    so you are going to sleeve the cylinder and make a smaller piston? dry ice and heat.
  10. #110
    Dec 2011
    Holland, bish!
    I'll use original brembo pistons. Im just scared that a strong enough press/interference fit (will be after they get delta T = 0 )sleeve could potentially crack the caliper. I have no clue what material it is etc...
    And I think that even a press fit could potentially slide out with brake pressure. The surface area of the sleeve is basically the same as the piston it surrounds...
    This can only be overcome by sealing the void between sleeve and chamber floor...
  11. #111
    Apr 2012
    Tampa, FL
    E36,E38, and E46
    instead of a sleeve make it a piston. pressure chamber between the the 2 pistons. force expands in both directions. one applying the brakes and the other driving the (sleeve/piston) deeper into the caliper bore.
  12. #112
    Mar 2012
    Renton, Wa
    98 m3
    Daan I'm sure someone makes one. Have you called anyone?
    1989 535i - sold
  13. #113
    Dec 2011
    Holland, bish!
    Wilwood ap brembo stoptech and then some...
    The problem is that a tandem cylinder operates at same PRESSURE front and back circuit, regardless bore diameter. The difference in bore is just to make sure the stroke of the plungers is the same even though DISPLACEMENT of fluid is different front/back due to caliper piston surface difference. This is important because when a circuit fails the tandems internals make a mechanical coincident after some difference in stroke length and thus braking still works on the other circuit without loss of fluid in the other.
    The only thing that would work in that config is a 'twin' master that looks like a tandem but doesnt have the middle divider piston acting as a membrane but rather a fixed connection. Youll get all sorts of other problems then; the one (piston) for the rear must have a larger surface area because only then hydraulic pressure drops to the rear calipers. However the stroke would be REALLY short due to the large volume displaced per stroke travel. Because it is mechanically lineairy connected to the front pump piston, this will only travel a short distance. Being smaller than the rear pump piston, the displacement is very little. So even though you then hydraulically have the right pressure differential built in, you wont have equal caliper piston travel going on. Problem.
  14. #114
    Dec 2011
    Holland, bish!
    Im not quite getting that. Could you draw what you mean??
  15. #115
    Mar 2012
    Renton, Wa
    98 m3
    Haha I understand them but thanks for the refresh :p it's just crazy to believe there isn't a solution you know?
    1989 535i - sold
  16. #116
    Dec 2011
    Holland, bish!
    And i havent got enough place for twin parallel masters on top of the booster
    Because rms inlet manifold/chargecooler
  17. #117
    Mar 2012
    Renton, Wa
    98 m3
    Reason number 83? To go turbo.
    1989 535i - sold
  18. #118
    Dec 2011
    Holland, bish!
    I will...eventually. but ill keep the manifold.
  19. #119
    Mar 2012
    Renton, Wa
    98 m3
    You should build a new engine for turbo. I accept donations
    1989 535i - sold
  20. #120
    Apr 2012
    Tampa, FL
    E36,E38, and E46
    your sleeve idea: make it a cup idea. everything else as you described. port fluid into the cup rather than around it. the cup is just extra insurance that it wont come out but probably not necessary. the cup just ensures that pressure driving the piston out will also drive the cup in. the pressure drives the piston out, and at the same time it puts force on the cup which is fixed in the caliper bore anyways. but if its not it will be driven back into the bore because the piston cannot push the pad further out.
    we sleeve hydraulic cylinders all the time and a captured sleeve should be fine (your idea). hydraulic pressure will not drive the sleeve out unless the piston mechanically locks to the sleeve. but you will notice the bias towards the rear returns. use the sleeve, its fine but the cup has been done too.
    I assume you are trying to decrease bore diameter to decrease force correct? you know that for 1 inch of master cylinder stroke you get 1 inch of stroke at the slave with 100lbs of force. so the fundamental you are working with is decrease the bore diameter which will decrease force? but you still displace the same amount of fluid from the master so the slave will stroke twice twice the length (just an example). so 50lbs at 2 inches of stroke. correct? it should still get you less pressure on the rear. however the rear pads will touch the rotor sooner than the front.
    another option is to just convert pressure to stroke external to the caliper. leave everything oem in the caliper.
  21. #121
    Dec 2011
    Holland, bish!
    Well the problem is that the oil feed of the caliper is all the way at the bottom of the bore. Exactly in the radius where the bore becomes bottomed out. So preventing fluid from getting underneath the piston is not possible as you described
  22. #122
    Apr 2012
    Tampa, FL
    E36,E38, and E46
    you can cap the feed and put a new one in but really the sleeve is the simplest. for that matter the caliper could really just be a housing to hold a little self contained hydraulic power pack (bore, cylinder, porting) that you can easily change for different bias. the only word of caution would be that you will have to make up for lost thermal absorption capability with something. (heat sink, heat pipe, .....sounds like more cool options you could play with).
  23. #123
    Dec 2011
    Holland, bish!
    It is not physically possible to make a full hydraulic cilinder within the bore and then feeding to it in a different way than with the routing as is.
    A sleeve with the desired thickness will have the same projected surface area thus trying to break loose out of the caliper bore with a force equal to that of the piston pressing the pad against the disc which is a lot of force.
    A piston acting as a sleeve will want to break free with double that force.
  24. #124
    Dec 2011
    Holland, bish!
    Ive figured out a solution that is reliable and doesnt depend on retaining the hydraulic forces or bonding
    Will 3d cad tomorrow
  25. #125
    minneapolis
    tite
    with all the craziness going on in this thread, I have to comment on your floor ha not sure why I never thought of using laminate in the garage. it looks rich lol
    also im blown away by the work put into this car
  1. S. Cal Recommendation of Shop to Shorten the Drive shaft
    By M3Jokster in forum California sponsored by Avus Autosport
    Last Post: 01-10-2008, 01:53 PM
  2. Engine cranks for a sec instead of firing up right away
    By 96cosmosM3 in forum 1992 - 1999 M3 (E36)
    Last Post: 05-12-2005, 05:21 PM
  3. Replies: 22
    Last Post: 03-01-2004, 01:27 AM
