Page 12 of 13 FirstFirst ... 2345678910111213 LastLast
Results 276 to 300 of 302
Thread: Instead of knocking up girls, secretly paying a shop to build...... The Zackmobile
  1. #276
    Feb 2009
    Arizona
    1998 e36
    Quote Originally Posted by vollosso View Post
    he ran out of money and couldnt keep paying the shop to finish the car
    Very typical.
  2. #277
    Dec 2011
    Holland, bish!
    Euro e36 M3 3.2 cabrio
    Quote Originally Posted by hakentt View Post
    Very typical.
    Yeah plus I'm not satisfied with the quality of their work tbh. Would you be willing to provide your services since the turbo still needs to be installed and tuned?
    Edit: for the newcomers; this is obviously a joke
  3. #278
    Dec 2011
    Holland, bish!
    Well everyone I think I solved my logistical problem that has been holding me back from doing work in the rare occasions I actually had time to do so; Since the car is nose first into the garage and the engine doesn't fit trough the access door on the opposing side from the garage door, I've been a little stuck. I really didn't feel like remounting the front suspension and wheels and most stuff on the rear end of the car either so there was no way for me to take the car outside and rotate it to put it back in ass first. A friend of mine pointed out there is a cheap solution, kinda like a square frame with wheels and extendable struts that you place under the chassis. So I bought one. Need to modify it a little so it isn't as high as now in fully retracted position and I need to figure out a way to support the car on the shotguns and rear subframe so I can remove the Quickjack from under the sills because that's where the contraption goes. Will work on this tomorrow, pics wil follow. Once that is done I will clean the engine bay, decide on if I wanna go through the process of shaving the strut tower seams (a look I very much enjoy) and finally scanning the engine bay for development purposes. Stay tuned
  4. #279
    Mar 2012
    Renton, Wa
    98 m3
    Less talk more progress!!
    1989 535i - sold
    1999 M3 Tiag/Dove - sold
  5. #280
    Sep 2013
    Tx.
    02 bmw 540
    It's been two years!!!
  6. #281
    milKt's Avatar
    milKt is offline ßMW///MµrÐêr§þðr†
    Flaccid US Appendage
    95M3t 95M3 92525iT 95525
    Let's just hope the Arizona "tuner" hasn't popped Zach's engina.
  7. #282
    Manchester, N.H.
    96 332IS 6466 turbo
    Quote Originally Posted by milKt View Post
    The Arizona tuner knows what he's doing, no need to hope.
    1996 332IS
    Built 3.2
    Technique Tuning 80# tune.
    1/4 mile 10.84 @ 136.72
    WWW.CESMOTORSPORT.COM
  8. #283
    Dec 2011
    Holland, bish!
    Well not much of an exciting update since the last months I've been working a lot outside of the country and the time I did spend in a garage was helping a friend getting his (also Estoril S50B32) e36 convertible on the road.
    Tried my (very dusty) M striped rear seat:
    Gonna look stunning.
    But anyways, I managed to rotate my car in the garage to have the engine bay accessible for the engine via the big door. It was a truly scary operation.
    Taking the quickjacks away from underneath the sills
    Way too high
    Chop chop on my new saw table
    After some more chopping and welding we managed to get the car on the mover
    taking the rear subframe off the car since it had the tendency to make wheelies !! (yes, scary)
    Unfortunately with the previous owner or workshop it was in being a complete retard, as they apparently torqued the RTAB pocket bolts with an impact wrench at max torque for 20 seconds; I sheared off all three bolts of the right pocket trying to undo them. I had to use a 1.5 meter long bar on the socket and all of my strength. This worked -just- on the left pocket but now i have 3 pieces of stuck bolt thread in my car. I bought the most expensive quality extractor kit on the market here in the hope that it will up my chances of success... otherwise it will either be cutting out the threaded bushes to replace them, or welding studs in place of bolts. Will work on this soon, should not forget to spray releasing agent in the holes by the way.
    It comes with counter rotating drill bits and all parts are individually obtainable.
    dissecting the subframe (because it is a bitch to handle otherwise)
    And then came the REALLY scary bit; imagine the chassis of the car (still weighing in at 1000kg or so) loose on top of a square transporter with Chinese plastic castor wheels, and only 2 guys. These wheels just go anyway the gravity or surface leads them to and it was nearly impossible to control the car. Anyways we managed to roll it outside without it toppling off, or banging it into the garage door opening.
    Then an equally scary and even tougher bit, rotating the car on that uneven pavement and getting the car back into the garage, but then up the incline!
    We just BARELY made it without a disaster...
    And finally, spend some time yesterday disassembling/cutting off bits from the RTA's
    Everything seized solid as usual on this car.
  9. #284
    Apr 2012
    Tampa, FL
    E36,E38, and E46
    The venting on the hood looks great!
  10. #285
    Oct 2012
    ottawa
    97 328is 02 e46 330xi
    Easy way to deal with the broken bolts is to cut the shank they are broken in, out as the are welded in from the bottom of the rtab pocket. Then just weld In a new shank. May be a easier rout then trying to extract them all
  11. #286
    Manchester, N.H.
    96 332IS 6466 turbo
    I busted one long time ago, I just cut the dam thing open, did what I needed and sealed it back up.
    1996 332IS
    Built 3.2
  12. #287
    Oct 2012
    ottawa
    I did the same when I had my first one break. glad I'm not the only one running around like that. Makes me feel a bit better lol, Not all of them are accessible that way though. The front one is almost impossible lol.
  13. #288
    Dec 2011
    Holland, bish!
    I've decided on using keenserts
    Verstuurd vanaf mijn SM-G935F met Tapatalk
  14. #289
    Dec 2011
    Holland, bish!
    Damn... last update from June last year.
    Moved homes, building garage/workshop with underground car lift etc.
    Not much done (if any) to the M3 really. Definitely an itch that needs scratching...
  15. #290
    Apr 2009
    Virginia Beach, VA
    e30 hopefully
    Not sure if this will work but I'd try welding a nut onto the broken bolt and removing. Try hitting broken piece with a punch few times first then welding. May not work but worth a try before cutting it out...
  16. #291
    SW Florida
    99-01 M Cpe & Rdts, X5M
    Quote Originally Posted by philly98540 View Post
    Its like a mad scientist meets motor head. Really neat stuff your doing. 3d tracer and printer just because. Very cool. Be sad when the car is done.
    lol car done? Hahahah.. Haha..
    As someone that took twenty years (twenty-one, but who's counting...) to restore my '57 Austin-Healey, I can not only relate, but I have lived it. As long as you have a supportive spouse__or spouses, two (2) back to back in my case__it doesn't matter how long it takes as long as you enjoy the process.
    When I finished the Healey__a relative term, yes, as I have collected still more parts to fit to it__I took to turning other people's BMWs into projects; far more profitable, and I can spend their money buying tools, equipment and fancy parts!
    Looking forward to continued progress, updates and pictures. Good job.
  17. #292
    Oct 2007
    london
    bmw e36 convert
    Loving the love your putting into this build. Truly exceptional contribution and inspiration to the BMW community.
  18. #293
    Aug 2003
    Holland
    '97 Hellrot euro M3 SMG & '93 dakar yellow euro M3
    Quote Originally Posted by autowa View Post
    This.
    These bolts are 10.8 grade. You get absolutely nowhere with extractors etc. It's even very hard to drill a hole in these bolts. I tied with very high quality cobalt drills and you barely scratch it. Extractor simply snaps off.
    Just cut them out and weld in new pieces, done.
    Also, when these are stuck, never try to loosen them with a bar extender. Just get a big impact wrench and knock them loose.
    E36 M3 S50B32 daily - E36 M3 S54 trackcar
    They Say Money Talks, All Mine Ever Says Is Goodbye
  19. #294
    Dec 2011
    Holland, bish!
    They drilled out no problem and it's fixed with high quality threaded bushings, aerospace grade. I'm not gonna cut and weld my chassis when I don't have to lol... and my heavy impacter didn't budge them.
  20. #295
    Aug 2008
    Panama
    E39 m52tuB30
    updates?
    E39, 523i, 1999, M52TUB30, 5 SPEED MANUAL, UUC SHORT SHIFTER, EURO SPECS, KONI YELLOWS, OEM SPORTS SPRINGS, OEM SPORTS SEATS, ALCANTARA HEADLINER AND /A/B/C PILLARS, OEM M-TECHNIC AERODYNAMIC, OEM M5 FRONT GRILLS, OEM M5 REAR FOLDING MIRRORS, OEM M5 REAR SWAYBAR, OEM M-TECHNIC II FRONT SWAYBAR, REMUS DUAL TIP MUFFLER, TITANSILVER, BIXENON, M PARALLEL SPOKE 66 STAGGERED, OEM M-AUDIO SYSTEM, NAV SCREEN 16:9, INTRAVEE II iPOD INTERFACE, OEM TCM WITH BLUETOOTH, Y RESONATOR DELETE, INTAKE HORN DELETE, CDV DELETE, CHARCOAL TITANIUM BRUSHED TRIM, FAN CLUTCH DELETE, ELECTRIC FAN, 3.15LSD DIFFERENTIAL, ESS TS2+ SUPERCHARGER, AQUAMIST METHANOL + WATER INJECTION
    PANAMA, CIUDAD DE PANAMA
  21. #296
    Mar 2012
    Renton, Wa
    98 m3
    Quote Originally Posted by jdjg View Post
    updates?
    No way. Permabuild.
    1989 535i - sold
  22. #297
    The Netherlands
    DE-spec E36 328i/M3 cab
    His built is in a long pause. He’s building a super duper garage at his new house.
    1998 BMW M3 3.2 Cabrio • Alpinweiß III on Schwarz • German spec • 1 of 12
    IG:
  23. #298
    Dec 2011
    Holland, bish!
  24. #299
    Apr 2015
    Netherlands
    2000 E46 328i
    Are you done?
  25. #300
    San Antonio
    Z3M Coupe & Roadster
    pics of the new garage build or a link to the garagejournal?
  1. S. Cal Recommendation of Shop to Shorten the Drive shaft
    By M3Jokster in forum California sponsored by Avus Autosport
    Last Post: 01-10-2008, 01:53 PM
  2. Engine cranks for a sec instead of firing up right away
    By 96cosmosM3 in forum 1992 - 1999 M3 (E36)
    Last Post: 05-12-2005, 05:21 PM
  3. Replies: 22
    Last Post: 03-01-2004, 01:27 AM
