Results 1 to 9 of 9
Thread: O2 sensors proper connection
    Aug 2013
    quebec
    BMW 850i 1991
    Hey guys, my first post on the forum. I just bought an 850i 1991 and having problems with low load acceleration. The car is just choking and smell gaz big time. I'm suspecting that the previous owner inverted the O2 sensors connections (right sensor with left side and vice versa). So would someone have a picture of the O2 sensors with their proper connection underneath the car. Thanks for your help guys. Much apreciated.
    IcemanBHE's Avatar
    IcemanBHE is offline ¿pǝpɹɐʇǝɹ noʎ ǝɹɐ
    Wichita,KS/FortCollins,CO
    (4x7)+8=36
    Welcome to the forum.
    95 840Ci, Calypso Red/Silver, 83k - 99 740i, Black/Black, 185k, Alpina Mods - 01 740i, Titanium/Silver, 40k, Sport Pkg
    Complete Turnkey Diagnostic/Programming systems available...PM for details.
    http://www.8Coupe.com - Please register, spot, and help the project.
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    I only have a pic of the E32 750 1992 M70 connectors, right side goes to right side which is a bit more in front, left to left connector
    http://infinitier.ddo.jp/e32/page/ma...inte_50707.htm
    Or you just swop them under the car and see how the engine runs. I mixed that once up and immy could notice from the engine running, very rough idle.
    Or disconnent one side and test with a multimeter on the Motronic, for the 352 the pins are Lambda on pin 70, and Lambda ground on pin 71.
    Remove the cover plate from the Motronic connector and then connect the connector again, then start the engine and test with a multimeter and it should move within 1 second between 0.1-0.9 volts, the faster the better.
    Here pics for better understanding
    http://img293.imageshack.us/img293/5...onik005tm0.jpg
    http://img167.imageshack.us/img167/2...onik001zi7.jpg
    The one not connected should then show no volts, so you know which one is connected to which Motronic.
    I hope I could explain that understabable with my poor English.
    Aug 2013
    quebec
    BMW 850i 1991
    Thanks a lot Shogun !! I will try this PM and let you know.
    Thanks !
    Quote Originally Posted by shogun View Post
    Aug 2013
    quebec
    BMW 850i 1991
    Thanks Shogun. I will try this PM and let you know!
    Nov 2005
    Langley BC Canada
    91 850 Panzer
    So if you suspect that someone inverted the O2 sensor connectors, take 10 minutes, crawl under the car, switch the two connectors and test. They are either connected correctly or they are inverted. The only other options are they (or one) is not connected, there are broken wires or they (or one) is dead.
    91 850 (Panzer), 2012 Mini Cooper Countryman (WifeMobile) www.wuffer.ca
    Aug 2013
    quebec
    BMW 850i 1991
    Thanks a lot guys for your prompt reply. I just swapped the connector and the car works great now !!!!! I'm an happy man Special thanks to Shogun oncw again.
    Jan 2005
    Japan
    Thanks for the feedback. That even happens to us experienced guys sometimes when in a hurry.
    Therefore I can only recommend to all, to mark the connectors coming from the engine room with 1 and 2 or left and right bank/exhaust when changing oxy sensors before disconnecting the oxy sensors.
    Anyway, if wrong connected, that can be felt immy when engine is started by the poor running of the engine.
    May 2017
    2009 BMW 328i E90 N52B30
    Hello Shogun:
    I have the same problem with my 2009 E90 328i sedan N52. Valvetronic and non turbo.
    I removed the connectors from the fuel rail...so I really dont know which one was in the front and rear side of the rail..
    Please help me out.
    Rod
    Rod Lequerica. - Miami FL
    2009 BMW 328i E90 LCI Sedan Type PH77
    Engine: 6cyl 3lt N52B30A - Auto Trans: GM GA6L45R
    VIN WBAPH775X9NM Plus 5 last serial numbers
    EL_LEQUE_DELAE@YAHOO.COM
    +1 (786) 239 1329)
