My mom's car (98 740iL) had only the above symptoms.
Troubleshooting: Fuses had power, plug at MID did not.
I looked up what connections were between the fuses and plug for the MID, and the only ones were in the passenger footwell.
I had seen some water in the passenger footwell once when it had been sitting for 2 years, so I figured maybe there had been a bit of corrosion.
Pulled the carpet; this is what I was treated to:
That's not great, let's open things up a bit:
Oh no . How are the splices (what we came here to look at)?
And this is why the MID has no power:
The wires have corroded right off the connectors.
Cleaning in progress, will update when complete.
OH my god you must have a water leak some where get new used parts and clean it up good and see if there anymore damage
El Cid 1999 ILDUDMD Tune/DINAN CAI/19 in Style 95 Rims/Bilstein's Shocks/Eibach Lowering Springs/OEM Folding Mirrors/Custom Cupholder/Custom Wood Sunshade/Sport Steering Wheel/Euro Center Console/Leather Shifter/Rearview Camera /Luke Custom 10 in Sub Box/Cross Drilled Rotors/Rear view Camera/BMW OEM Monitors/BMW E38 Picnic Tables/Vanity Headrests/OEM Roof Rack/Strut Bar/Dinan MAF and Dinan Throttle Body and Dinan tunning /BM53 Radio upgrade /Custom Innovadrive NXG39 modify and Alpine ILX-W650 touch screen radio.
Holy cow that area is just plain messed up. Pretty much everything in there is shot.
Is there a hump that keep water that fills the rear foot well from getting to this stuff in the front? Because I'm thinking that I better pull the seat and check this out since my rear foot well was pretty full.
It's amazing that the mid is the only problem!
Made some progress today.
Haven't applied power yet (going to thoroughly clean the interior while the seats are out), but everything looks good.
Cleaned up all the splices; here is an example before:
And after:
Cleaned up the hardware in the fuse box:
Fuses back in (all new nuts):
Ordered new splices and splice connectors from BMW:
Replaced the splice and connectors on these primary fuse wires:
This splice didn't clean up too well:
So I replaced it:
And finally, replaced the splice and connectors that had corroded so badly the wires came off completely:
Fuse box in order (all new nuts):
All splices snapped into the trim:
Zip ties prepped on the trim:
I think that if it were me, and I had that kind of history of water damage in the car, I'd consider conformal coating everything just to be on the safe side. Well done, that's really looking promising.
Nice. You have inspired me to pull the carpet and see what's what under the passenger front seat. I had a sunroof leak that filled up my rear well. Really hope it did not make it to that area. No electrical problems but this thread worries me!
First...wow, what a horror to stumble upon! Second, what a terrific clean up job...with DIY pics to boot.
Nice work
- Sean
RIP Blitzkrieg
Looks like some really great work. Good job and glad you got everything working again.
you know, I have the problem of no power to the front passenger door,no door locks, no window and mirror don't work, I wash the car yesterday and after 30 minutes, everything worked, I got to open the door, which I haven't be able to do for a few weeks, everything worked for a bit, now it went back to nothing, now I see this and I think I have to check this, I even bought a door module from a member here. this is on every year e38 or just specific year?
Current fleet:
1999 BMW e36 M3
1999 BMW e36 328is with rotary valve engine head
1999 Oldsmobile Eighty Eight
1990 Jeep Comanche Eliminator
1962 Austin Healey Sprite
Yep. The sunroof's are killing our cars.
Some newer bimmers have two sunroofs! No tx.
You dont have to see water. The carpet is rubber backed and then has thick foam under the rubber. The sunroof leaks travel UNDER the carpet and you do not notice it until you either smell it or you have so much water under the carpet that it finally is higher than the carpet level then it will sit on top.
nice work man. looking good.
Bump an excellent thread. This issue seems to be the flavor of the month.
awesome job and great work. all of these corrosion issues make me want to inspect my car much closer.
how and where does the water get into the car from ?
GearBox Rebuilt at 190K w/ TC & VB Silverline DUO TCU Bluetooth
There are four drain hoses connected to the catch tray below the sunroof that were only installed by push on pressure and they shrink over time and pull off. The way the sunroof is designed, it can leak all it wants since the water ends up in the catch tray below it and then it drains out.
---- Processing Individual ----
Z1XX Upholstery
Seats front and back in Epingle / leather englishgruen,
As Schl.Nr. B9EG.
Front seat backrest in Montana Englishgruen (No. 8 174 861)
Other interior equipment as for Volleder Nappa englischgruen,
Schl.Nr. P5EG
Excellent work. Thank you for the guidance. Great pictures too.
