Page 6 of 6 FirstFirst 123456
Results 126 to 133 of 133
Thread: Just (re)joined BFc, figured I'd introduce myself and my '84 745i
  1. #126
    Jun 2010
    TX
    1983/84/85 745i
    Wow. That is a seriously well prepped car!
    I make E23 parts.
    10/1984 745i
    11/1984 745i
    11/1984 735i (10:1-265/6)
  2. #127
    Dec 2007
    Gilbert, Arizona
    6/83 1984 745i
    That one is rough Dave! Good to see you are still in the mix.
    alpinweiß on anthrazit buffalo 1984 745i, 2014 Fiesta ST, 1984 635csi 1986 635csi 1987 L6 1999 M coupe 2002 M3 1995 325i 1976 200​2, 2001 996 TT 1994 850 T5 wagon 1998 GTi VR6 1983 scirocco
  3. #128
    Mar 2006
    Sacramento, CA
    87 535i/84 €735i/8
    Well that's...interesting...
    --Jay3->Sic gorgiamus allos subjectatos nunc
    84 €735i manual, 88 528e/i
    Motronic 1 and 1.3 wiring
    Transmission & Diff gearing sheet
  4. #129
    Jul 2016
    Chicago, Illinois
    are slow
    Looks like a fun beater.
    Function over form (I guess)
  5. #130
    Feb 2009
    Pittsburgh, PA
    '86 635CSi, '08 128i
    Quote Originally Posted by kojo96 View Post
    What is that Blue piece that the IVC is connected to?
    That's a chunk of eBay silicone hose, with the ICV jammed into it. It's still using the original 735i 059 DME and a rising-rate FPR. No doubt it's been chipped for the M106 parts. There's more than a little redneck engineering going on there, but it runs surprisingly well once it's warmed up.
    Thanks for the welcome back! I'll be sharing more as I explore it. This one is like an archaeological site, it takes a lot of digging to find the treasure. These cars really are rugged - despite all the abuse this poor old POS has seen the doors still close with a solid thunk. If the rust hasn't bitten too deep I might beat it all winter instead of parting it out immediately. The next week or two will decide this car's fate.
  6. #131
    Feb 2009
    Pittsburgh, PA
    More good news! I pulled the DME to see if it had a reputable chip installed. It did! Feast your eyes:
    That's a TCD chip! I'm off to get me some documentation...
  7. #132
    Feb 2009
    Pittsburgh, PA
    In other good news, I'm sure the block is an M106. The only M30 parts from the original 735i are the chipped 059 DME, the engine wiring harness, and most likely the AFM. The radiator is a normal E23 unit too.
  8. #133
    Feb 2009
    Pittsburgh, PA
    The E23 gave up a few more parts to the E24, but it was worth the fuss. After the last ride I got a 1444 "all clear" code for the first time ever.
    Alas, it's a temporary situation. I just tossed that engine in the car to get around for the summer. The compression is low and I suspect that engine has carbonized rings along with weak valve seals. I'll get the head redone over the winter and attempt new rings if required. I've heard good things about Valvoline MaxLife High Mileage semi-synth, might give that a try to see if I can't squeeze a few more miles out of this old lump.
