Page 2 of 3 FirstFirst 123 LastLast
Results 26 to 50 of 52
Thread: Building the 210mm Diff (e32 v12 - common CES bracket mod for e36M) for 1,000RWHP :)
  1. #26
    Dec 2007
    SF bay area
    1998 M3 / 2000 S2000
    Building the 210mm Diff (e32 v12 - common CES bracket mod for e36M) for 1,000RWHP 😊
    deleted
    Wanganstyle Powertrain
    http://www.wanganstyle.com/
    S54B32 E36 M3 DTA S100 Sedan Street car full swap:
    http://forums.bimmerforums.com/forum....php?t=1437471
  2. #27
    Aug 2012
    CT
    Twin turbo LS E36 M3
    Your right, I should have built a ford.
    328i Sedan Twin s366's, 6.0LS, TH400, MS3 Ultimate
    9.20 at 150 on 22psi
  3. #28
    Manchester, N.H.
    96 332IS 6466 turbo
    Quote Originally Posted by wanganstyle View Post
    You would be surprised at how many people enjoy cutting corners.
    Used parts sourced from a salvage or junkyard are technically junk; crashing a car bad enough to total it is not exactly friendly towards gears or internal components of differentials.
    The risk of a mystery item failure at high speed is something not all are willing to take.
    NEW Diffs are avail from bmw; BMW Sells at the dealership counter new parts yes. At a cost
    NEW Lsd units are also avail aftermarket as well.
    A 25 year old used Oem zf is not = to a brand new 2017 Lsd unit; it’s not new.
    Nobody is buying brand new internal gears for the Lsd unit as parts are NLA.
    The newest Oem bmw 210mm clutch type diff would be 15 years old from a e39m5
    One can apply money/effort/time to make an 188mm handle 50+ passes down the 1320 at 1krwhp over.
    Or apply even more effort to build a 210 for more power.
    Many options ; for many a well setup 188 would do fine.
    The problem isn't the 188mm diff. Its the stub shafts. I never once broke a ring/pinion. But towed many many times for those little stub shafts. They can't handle dead hooking and they twist up like a stock driveshaft.
    Here is a 210mm vs 188mm stub shaft comparison. Even went and had DSS build me custom billet stub shafts. Broke them too. Until that is solved, the 188mm is no good for drag racing.
    Sent from my E6782 using Tapatalk
    1996 332IS
    Built 3.2
    Technique Tuning 80# tune.
    1/4 mile 10.84 @ 136.72
    WWW.CESMOTORSPORT.COM
  4. #29
    Dec 2007
    SF bay area
    deleted
  5. #30
    Aug 2012
    CT
    I pulled the stubs out of my 210 when i parted the car out. Very slight, but still
  6. #31
    Apr 2006
    Minnesota eh?
    86 325es
    Before the days of chromolly aftermarket axles, drag and circle track racers used to pull the axles out of there rear ends and paint a white line down the center and then check them intermittently. When the shaft had twisted two full turns they would throw them away.
  7. #32
    Manchester, N.H.
    96 332IS 6466 turbo
    I’m well aware.
    Not sure what is the current status of Dss products for the 188mm as I have no association with dss;
    Back in the day circa 2012 iirc they had very durable stubs;
    You must mean these beautiful pieces of shit ? I went through 3 sets between myself and another turbo E36. Eventually DSS just refunded us.
    1996 332IS
    Built 3.2
  8. #33
    Aug 2017
    Savannah, GA
    E36 M3 Turbo, 2015 GTI,
    They are beautiful though...
    Ken
    95' Dakar M3
    (GT35) 500whp+ and no clue what I'm doing....
    Steedspeed Twin-scroll Manifold, Wiseco 8.8:1 CR, K1 Rods, Supertech Valvetrain, ARP Main Studs, o-ring block, GTR 12mm head studs, GT35R with 86mm HTA billet compressor wheel (GT3586RHTA) Twin-Scroll 1.06 AR, Schrick Cams, TRM Tuning, 6 Speed Transmission, UUC Twin Disc Clutch, HFS-6 W/M injection, Zeitronix, Coilovers, Chassis Stuffs.
  9. #34
    Vancouver, B.C., Canada
    '97 M3
    Has anyone installed an e46 M3 finned diff cover on their 210 in an e36? I couldn't find anything by searching.
  10. #35
    Dec 2007
    SF bay area
    deleted
  11. #36
    milKt's Avatar
    milKt is offline ßMW///MµrÐêr§þðr†
    Flaccid US Appendage
    95M3t 95M3 92525iT 95525
  12. #37
    Jul 2005
    PEI, Canada
    2001 330i
    Quote Originally Posted by chikinhed View Post
    I found that the diff cover for the E46 M3 hit the E46 non-M rear sway bar. (I ended up having to convert both my front and rear sway bars to M3 pieces)
    I'm not sure the same situation exists for the E36....but it's something to be wary of.
  13. #38
    Mar 2011
    Kingston ,Jamaica
    1997 328i turbo
    Quote Originally Posted by milKt View Post
    Since I’m still on stock m3 axles I’ll give that a try
  14. #39
    Jul 2010
    Stafford, VA, US
    1997 BMW 328i
    if my 210 goes (already sounds like marbles in a bucket when turning) im just going to an 8.8 setup.
    Follow my builds on youtube and IG.
    www.youtube.com/thenameskam
    @thenameskam on IG
  15. #40
    Hagerstown, Md
    1995 M3 Drag C4 Auto
    Quote Originally Posted by Kame36sedan View Post
    If you are going with an auto, 210mm and footbrake would be plenty. Why wouldn’t you rebuild the 210mm before failure?
  16. #41
    Jul 2012
    Atlanta, Georgia
    ∞FX37,M3a/4,94 332
    (already sounds like marbles in a bucket when turning).
    What diff fluid and weight are you using?
    [IMG][/IMG]
  17. #42
    Jul 2010
    Stafford, VA, US
    1997 BMW 328i
    because its cheaper to go 8.8 then to rebuild this thing lol uhhh i have to look. whatever the 210 guys recommended awhile back.
    @thenameskam on IG
  18. #43
    Dec 2007
    SF bay area
    deleted
  19. #44
    Jul 2010
    Stafford, VA, US
    1997 BMW 328i
    time isnt the issue, its price. there are a few folks already running the 8.8 in the e36 subframe. you just grab DSS axles to that length and your golden. It is fairly easy to swap in and now that 210s are more and more rare and costing more and more, this will be the Go to swap very soon.
    @thenameskam on IG
  20. #45
    Nov 2015
    Miami, FL
    2001 325i
    I agree that the 8.8 will probably become more popular as an upgrade. Makes a lot of sense if you can do the fab work yourself.
  21. #46
    Hagerstown, Md
    Looks like the 2015 mustang 8.8 center section will have tons of support
  22. #47
    Nov 2015
    Miami, FL
    2001 325i
    34 spline options also... going to be a lot easier to find parts for the mustang diffs.
  23. #48
    Jul 2005
    PEI, Canada
    2001 330i
    There will still be "purists"....running a BMW engine....BMW transmission....BMW differential.
  24. #49
    Jul 2010
    Stafford, VA, US
    1997 BMW 328i
    i was speaking more towards the Cobra IRS 8.8s from the early 2000s. most used diff in the drag world when it comes to IRS.
    @thenameskam on IG
  25. #50
    Hagerstown, Md
    [QUOTE=Kame36sedan;29951909]i was speaking more towards the Cobra IRS 8.8s from the early 2000s. most used diff in the drag world when it comes to drag racing.
    The new one “seems” to be a titch better. If ford is supporting it, maybe they have some confidence in what they have done. Building a cobra diff isn’t that cheap and quite frankly it doesn’t like 1000 rwhp drag strip launches. You can buy a built modern 8.8 for like $1800 complete. 3.31 and 3.55 are gonna be the ratios that work great with the TH400 conversions. Also with the 34 spline axle options, G Force should be able to build us some 1500 hp axles! No more Dss junk.
    GDM ENGINEERING
