Page 3 of 22 FirstFirst 12345678910111213 ... LastLast
Results 51 to 75 of 536
Thread: We need more build threads: 00 Z3MC SG/DBO
  1. #51
    Oct 2007
    VA
    00 Mshoe
    Got my first of two boxes from Germany this morning!
  2. #52
    Lawrenceville, GA
    4 BMWs.
    Very nice rescue job!
  3. #53
    Feb 2013
    Wow! Lovely coup keep up the TLC.Will look super with those wheels.Hope you get some breaks,but take the good with the bad.Have fun getting her in shape!
    Sent from my iPhone using BF.com
  4. #54
    Oct 2007
    VA
    00 Mshoe
    Quote Originally Posted by amancuso View Post
    Thanks!
    Quote Originally Posted by rdsledge View Post
    Wow! Lovely coupe keep up the TLC.Will look super with those wheels.Hope you get some breaks,but take the good with the bad.Have fun getting her in shape!
    Thanks! Slowly but surely it is coming together.
  5. #55
    Oct 2007
    VA
    00 Mshoe
    Coilovers get here Tuesday per Fedex. I'm excited.
    Ordered me some LED's for the 3rd brake light retrofit as well, tired of all the burnt out bulbs.
  6. #56
    Oct 2007
    VA
    00 Mshoe
    Took advantage of the strangely warm December day in the 60's to put in some work in the new garage.
    Gave it a quick wash before it be up on stands for a few weeks:
    Completed the coupe owners right of passage
    Then the suspension came off for coils to arrive tomorrow.
    Got a bit further and removed the mufflers and a few bits to drop the subframe to take to my shop for the weld ins but lost my light and the garage doesn't have power yet. Hopefully I can get the owners to run it soon.
    Ohh and some other shots since moving into the new place (since we all like to look at pictures):
    The new work space
    And the second box of rims showed up 5 weeks after the first from Germany
    And a Christmas present to myself
  7. #57
    Oct 2007
    VA
    00 Mshoe
    Quick test fit while waiting for fedex to arrive with my coils.
    Follow me on instagtam @00clwnshu or #1of1rebuild
  8. #58
    Northwest NV
    Audi B8.5 S4
    Quote Originally Posted by robb1887 View Post
    Like it. Good stuff.
  9. #59
    Oct 2007
    VA
    00 Mshoe
    Third brake light done:
    2 down- 22 to go:
    Getting there:
    All in:
    Resistor:
    Snug fit:
    made my own 12V supply to test it:
  10. #60
    Jul 2004
    SA TX
    E46 M3
    Heheh. Good stuff man.
    M driver, RSV4 Rider, Powerstroke roller
  11. #61
    Miami
    00 M Coupe
    Was it hard to solder in the new lights? I've been nervous to do this myself.. Can I also ask what resistor set up you did?
  12. #62
    Aug 2008
    Sunny SoCal
    E368x2 / F15
  13. #63
    Oct 2007
    VA
    00 Mshoe
    Quote Originally Posted by Bimjam96 View Post
    It was tedious mostly. If you've done electrical stuff before its not too hard. I'd prolly be able to do it under 2 hours my second time start to finish. Resistor is a 7w 22 ohm. And they are 5mm 9k MCD red leds
  14. #64
    Oct 2007
    VA
    00 Mshoe
    Rear suframe was dropped today and taken to the shop for weld in toe/camber adjustments.
    Front coils are in and waiting patiently as well
    And took some clearance measurements. 5mm spacers (thanks Randy!) are used here to fit a "rear" up front with the 7.5" barrels clearing.
    Also dropped in some fresh NGK spark plugs and found that my intermittent cylinder three misfire was most like due to the coil being loose and having a poor ground. Woohoo!
    Let's hope then reinstallation to proper torque solves it.
  15. #65
    Oct 2007
    VA
    00 Mshoe
    Teaser from the work I put in today:
  16. #66
    Aug 2012
    All Over California
    '02 M Coupe x2
    What I wouldn't give to have that kind of space to work in... Or even a water spigot just to avoid some public displays of idiocy trying to wash my car without one...
    Anyway. Flipping nice job going on there, guy. Must be rewarding to see the effort you put into each step paying off with some quality results.
    '02 M Coupe, Estoril Blue on Estoril
    '02 M Coupe, -???-Who knows-???-
    ‘02 M Coupe, Alpine White on Black
    '06 M Coupe, Interlagos Blue/Black Carbon Leather
    ’99 M3 Coupe, Technoviolet/Black
    ’04 VW R32, Reflex Silver/Black Cloth
  17. #67
    Bay Area, CA
    S54 M Coupe, E36 M3(s)
    Great work and beautiful coupe. Can't wait to see it done. What length springs/spring rates did you go with?
    Edit: just added you on Instagram too
    ///M
  18. #68
    Oct 2007
    VA
    00 Mshoe
    Quote Originally Posted by JeffyD View Post
    The space certainly is nice. I'm coming from a downtown apartment with only on street parking so I completely understand. You should try NoRinse Carwash from detailedimage.c For tour washing needs sans hose access.
    Everything is slowly coming together, but I still have a bunch ahead of me.
    Quote Originally Posted by Eson535 View Post
    I got 2000mkoop's old setup. The GC setup for an Mcoupe. He told me 450/600 iirc. Will prolly get pn's and inquire with GC to confirm.
    Edit: accepted
  19. #69
    Oct 2007
    VA
    00 Mshoe
    Ordered:
    Fresh front control arms
    Offset FCA poly bushings
    HD front sway links
    Tie rod ends
    and a bunch of OEM replacement parts ordered tonight
    Woohoo! Excited.
    Picking up my Subframe tomorrow too from camber/toe weld-ins
    Stay tuned!
  20. #70
    Jul 2004
    SA TX
    E46 M3
    Now that's some valentines day love for the coupe right there.
  21. #71
    Oct 2007
    VA
    00 Mshoe
    Putting in some more work
    Subframe back with weld in camber/toe and AKG (trimmed) poly bushings
    Old RTAB pulled
    Stripped and ready for a bit of paint
  22. #72
    Oct 2007
    VA
    00 Mshoe
    Got the garage sorted some
    This came in from Italy
    And got the subframe, rtas, diff and flcas back in.
  23. #73
    Jul 2004
    Houston, TX
    36 Cylinders
    Beautiful Coupe! I was looking at that one last may. Glad it made it to the forums, excellent deal! Now a word of caution, the amount of caster that the offset bushings add on is quite a lot. I'm almost regretting it on my coupe. Massive steering response, keep both hands on the wheel at all time.
    either way, love the restoration, had to do a little to my coupe, definitely not like this, so I'm glad you're passionate!
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
  24. #74
    Oct 2007
    VA
    00 Mshoe
    I also have hybrid GC camber/castor plates. So we'll see how it turns out in the end.
  25. #75
    Jul 2004
    Houston, TX
    36 Cylinders
    Yep, I used my UUC camber/caster plates to dial down the caster, so at least it doesn't rub. We'll see when I get some time, I might put centered ones on, much easier with the tool I made for pulling/putting those on.
    -Abel
